Old 02-03-2007, 05:33 AM   #17386
m3ndo5a's Avatar
I want would go with an alternative for the aluminum wheel axles....for I have broken two on acceleration alone and that with a stock motor.
m3ndo5a is offline   Reply With Quote
Old 02-03-2007, 05:36 AM   #17387
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by GuyIsDamGood
I`ve read that a few of you guys say that the Aluminum Wheel Axles(Item # 53939 - $23.50 for 2) will bend.....Wow.
-I`ve seen those Axles; they`re thick(the exact same) as the Steel Axles(Item # 51094).
- -Did anyone crash with those axles on their kit/car? I think that`s the only way they`ll bend.....?. . . . .Tell me what`s up.
I`m thinking about getting those Aluminum Wheel Axles for My TB Evo 5; you guys could save me $47.00.....Thanks.
Take Care
if you race and is already a very good driver and seldom crashes hard or never hit anything very hard, then by all means get those lightweight wheel axles but if you hit boards and crashes often then get the steel ones i already bent my two wheel axles which are located in the rear when i spun and chrashes the board now i have to replace all the axles with the steel ones #51094
buboy28 is offline   Reply With Quote
Old 02-03-2007, 06:39 AM   #17388
hierog's Avatar
a second for changing out the hardened aluminum ones! my buddy bent one yesterday, along with a broken arm. i broke THREE times yesterday (3 arms) and all of my axles are fine. i'm using the steel axles
vic
hierog is offline   Reply With Quote
Old 02-03-2007, 07:45 AM   #17389
HarshGuy's Avatar
Originally Posted by hierog
hmm, didn't know that. tamiya's site doesn't specify that it is 0 degree, however it does show a 0 on the hub
vic
On the MRE it's a dirrent rear hub the 0H one has the bearing sitting lower in comparison to the regular 0 ...I know cause I had to replace one (yep I bent one) and got the "normal ones" and they were different, so I got the 0H ones from champ.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-03-2007, 07:46 AM   #17390
HarshGuy's Avatar
Originally Posted by AARON YOUNG
Check your shock towers ..there is enough slop up and down to cause 1mm .Just loosen and either pull up or push down and tighten.Might help you.
I thought you liked them sloppy?
Old 02-03-2007, 07:48 AM   #17391
HarshGuy's Avatar
Take Care
It's not the "axle" that bends, it's the part that goes on to the dogbone that get's all bent and jacked up ...I was replaceing my front ones only, then started running a 4300 brushless and I guess because of he added torque I literally snapped 2 rear ones off right at the axle part, would be driving around the track, hit a corner and my wheel would fall off with the axle, wheel nut holder and whell nut still attached to it ...so I went to all steel axles all the way around on my 4300 car.
Old 02-04-2007, 05:16 AM   #17392
pug 205 gti's Avatar
how do chaps
been building the mre the last few days.im gutted i didnt buy a tamiya first time round.its a dream to build and all the cast plastic parts are to a very high standard.shame some of the other companies dont follow their example.
also the anodizing is spot on.diffs have gone together silky smooth!
anyway back to it,as theirs still much to do!
pug 205 gti is offline   Reply With Quote
Old 02-04-2007, 05:24 AM   #17393
chris_morrison_'s Avatar
so today 19 turn foam practice my car was almost perfect but a little lose
i was running pro 4 hubs and steel axles up front aluminium rear i managed to bend the rear Axel luckily i had the tamiya steel ones to change to
i was surprised how easily they bend
i definitely shuld have changed them earlier.
besides that the car has been flawless
i wish i got a tamiya for my first car 5 years ago when i started in this hobby
or as a fellow tamiya driver locally said to me you have been bitten. lol
chris_morrison_ is offline   Reply With Quote
Old 02-04-2007, 09:31 AM   #17394
proceed5's Avatar
Yup, those MRE Alum Axles bends too easily. Today I bent all 4 axles (and this is my second set!) whooosp!. Steel ones are heavier, i am thinking of replacing it with the Titanum ones, but it is a bit pricey .. Regards
proceed5 is offline   Reply With Quote
Old 02-04-2007, 03:00 PM   #17395
anyone know a date yet for the msxx i know its febuary but i cant wait any longer lol
skiv is offline   Reply With Quote
Old 02-04-2007, 03:47 PM   #17396
hierog's Avatar
how in the hell did you order from champ? i can't read japanese!
Old 02-04-2007, 05:18 PM   #17397
HarshGuy's Avatar
Email him what you want, he emails you back within a day or two, paypal him and your stuff shows up about 3 or 4 days later
Old 02-04-2007, 05:31 PM   #17398
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Looks like Feb 15th Japanese release
tamiyarcracer is offline   Reply With Quote
Old 02-04-2007, 05:32 PM   #17399
look on the left of the main page to where it says overseas. there are english instructions there.
Old 02-04-2007, 10:06 PM   #17400
http://translate.google.com/translat...&hl=en&ie=UTF8
rcchamp translated
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
