Old 01-26-2007, 10:11 AM   #17266
pug 205 gti's Avatar
Originally Posted by trf_racer
TRF415MSX Marc Rheinard Edition is discontinued now, wait for the MSXX next month.
read the last 3 pages
pug 205 gti is offline   Reply With Quote
Old 01-26-2007, 10:13 AM   #17267
Charles Godwin's Avatar
It might be discontinued but you can still get them on ebay
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 01-26-2007, 11:02 AM   #17268
J Stark's Avatar
Rocket Racer: Yea, (definetly) get the MSXX over the MSX. If you do some research you might be able to find a MRE somewhere out there. MSXX is coming out real soon!
J Stark is offline   Reply With Quote
Old 01-26-2007, 11:14 AM   #17269
RocketRacer's Avatar
Stark, i am trying to find one and it is proving to be a mission found one on e-bay. i think i will just have to wait....
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 01-26-2007, 11:21 AM   #17270
stellamodles on ebay has one
i hope that helps
if your still struggling let me know and i will pm you the link
Old 01-26-2007, 11:36 AM   #17271
post the link
RocketRacer
Old 01-26-2007, 11:43 AM   #17272
http://cgi.ebay.co.uk/49394-TAMIYA-T...QQcmdZViewItem
merci
Old 01-26-2007, 12:26 PM   #17273
This is where i got mine from $449
http://www.precisionrc.com/nv/car/pr...oduct_id=33907
damo666 is offline   Reply With Quote
Old 01-26-2007, 12:44 PM   #17274
proceed5's Avatar
Guys,
Thanks for the earlier posts.
For stock class, I want a smooth 'easy-revving drive-train' and double one-ways and a second car specifically setup for stock class would be a nice to have item.
I just blew away a 2-week old Orion Katana derived Stock motor, not sure why.. it just stopped running after 5 minutes or so!! (no response from throttle inputs) and rear diffs came loose as well, so something must be binding somewhere .
Cheers to all
proceed5 is offline   Reply With Quote
Old 01-26-2007, 08:22 PM   #17275
Originally Posted by chris_morrison_
tryhard
my first race is Saturday with my msx mre 19turn carpet rubber Tamiya
Type A tyres is the spec tyre.
do you have any set up and driving advice or tips?
this is my third race on carpet ever with rubber the first two were stock and this one is 19turn.
also this is the list of parts i have got in the last two weeks for spares
what else shuld i get
TAM51213 Tamiya TA05 Center Pulley (16T)
PRCS415MS Mechanica Bearings TRF415MS/MSX/MRE Bearing Set
TAM53869 Tamiya 5mm Aluminum Short Ball Nut (Blue / 10pcs)
TAM53899 Tamiya Reversible Light Weight Suspension Set for TA04/5, TRF415 & TB02
TAM53876 Tamiya Aluminum Damper Retainer (1mm Down Type)
PRC415JDFD36 Precision RC TRF415 Front Ball Diff Set w/ 36T Pulley
TAM53842 Tamiya TA05 Front and Rear Stabilizer Set
TAM53439 Tamiya Anti-Wear Grease (3g)
TAM53890 Tamiya Swing Shaft Protector (4 pcs) for TRF415MSX
TAM53642 Tamiya 5mm Aluminum Ball Connector (Blue)
TAM53640 Tamiya 5mm Aluminum Ball Nut (Blue)
TAM53573 Tamiya TRF Damper Piston (3-Hole / 4 pcs) for TRF Shock Set 53571
TAM53601 Tamiya Low Friction 5mm Adjuster (8 pcs)
TAM53724 Tamiya 46mm Light Weight Swing Shaft
TAM53933 Tamiya Alum. Suspension Mount Spacers 1.0mm (4pcs)
TAM53932 Tamiya Alum. Suspension Mount Spacers 0.5mm (4pcs)
TAM51103 Tamiya Front Upright for TRF415MS/TB EVO IV
TAM5014AO Tamiya AO Series Ball Diff Screw and Nut
TAM53574 Tamiya TRF Damper Rod Guide&O-Ring (4 Sets)
TAM51068 Tamiya Suspension Mount D for TRF415
TAM53936 Tamiya Wide Pitch One Way Pulley (36T Size) for TA05
TAM53586 Tamiya 4mm Shim Set (3 Types / 10pcs Each)
TAM53935 Tamiya Wide Pitch Ball Diff Pulley (36T Size) for TA05
TAM53588 Tamiya 10mm Shim Set (3 Types / 10pcs Each)
TAM53602 Tamiya Turnbuckle Wrench
TAM51065 Tamiya Suspension Mount A for TRF415
also parts I'm getting at the track are
2 pair of 4 degree castor blocks
3 pair front hubs
1 set of arms
1 suspension block 1c
thanks in advance
chris morrison
hi chris it would be good to hear how you got on with the car good luck
Old 01-27-2007, 12:56 AM   #17276
chris_morrison_'s Avatar
I will let you guys know how the car is
all i was wondering what else for spare do you 415 vets thought i shuld get.
chris_morrison_ is offline   Reply With Quote
Old 01-27-2007, 02:03 AM   #17277
Tek Nickal's Avatar
I've been running the 415 for a while now and I don't have even half the stuff you're getting. You should be good with spares for a long time, since half that stuff doesn't break especially if your running carpet all the time.
Tek Nickal is offline   Reply With Quote
Old 01-27-2007, 02:04 AM   #17278
maxepower's Avatar
Exclamation
Wheel bearings, spur gears,front belt and a spare diff already built and ready to switch. If you are running mod or brushless all these parts will wear quickly. But, if you run stock no rush to buy these spares! Oh, and shock delrin and o-ring rebuild kit. The delrin makes for a smooth shock action but will wear overtime if you drive hard. Dirt getting into the moving parts is a large part of the wear\factor!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-27-2007, 02:12 AM   #17279
i have all the parts i listed
thanks for responses
im runing the car on carpet for 6 races then going out side it will spend its whole life in 19 turn class
im going to get the msxx for mod racing latter in life.
belts are a def must have same with a front diff.
so i will get both.
also im having a problem finding the stock front axles in stock any where.
any one seen these pleas send me a link .
and yes im stock piling parts since my local hobby shop does not carry tamiya rc stuff.
thanks
Chris Morrison
Old 01-27-2007, 04:44 AM   #17280
Sean T Guy's Avatar
Chris,
Speedtech have stock front axles.
JR-RC also using link below.
http://cgi.ebay.com/53499-Tamiya-Whe...QQcmdZViewItem
Schumacher Racing UK
Team Scream UK
eXpress Motorsports UK
FTQ Models
Sean T Guy is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
