Old 01-23-2007, 04:01 PM   #17191
Sean T Guy's Avatar
http://shopping.rcmodel.hk/product_i...oducts_id=5151
http://shopping.rcmodel.hk/product_i...oducts_id=5150
They are ally , they dont break.
Schumacher Racing UK
Team Scream UK
eXpress Motorsports UK
FTQ Models
Sean T Guy is offline   Reply With Quote
Old 01-23-2007, 04:03 PM   #17192
Tek Nickal's Avatar
Well there is a chance that they will bend. Not exactly break. Looks real nice though.
Tek Nickal is offline   Reply With Quote
Old 01-23-2007, 04:07 PM   #17193
Sean T Guy's Avatar
Tek , I aint no Marc R.. and I havent bent any. They do look great and are also very strong (they have to be for me)
Only down side is that they are only available in 4degs. Speedtech is also great place to buy but I always get stung for living in the sunny UK for import.
Team Scream UK
FTQ Models
Old 01-23-2007, 07:04 PM   #17194
hierog's Avatar
Originally Posted by Tek Nickal
Nice, but those look expensive to break.
i have aluminum knuckles and hubs on my evo IV and i've never broken them. i break the arms, bend the swingshafts and shock shafts first!
vic
hierog is offline   Reply With Quote
Old 01-23-2007, 08:48 PM   #17195
pug 205 gti's Avatar
until my car arrives im stuck as to know the part numbers for the mre etc
im currently looking into getting some ceramic bearings for the layshaft and diffs. possibly some diff balls too?
boca bearings have these sizes for the msx (mre?) could someone help with identifying these sizes and their application
od id width
8x 9 5 3 ??????
4x 15 10 4 ????
2x 8 4 3 ????
2x 8 5 2.5 ??????
i dont know the sizes of the diffs balls required or how many to build two diffs
thanks again chaps i,d be lost with out ya!
pug 205 gti is offline   Reply With Quote
Old 01-23-2007, 10:03 PM   #17196
LBSR415's Avatar
it has something to do with that whole granting of independence thing
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 01-24-2007, 12:42 AM   #17197
I have got an MRE and am goin to put a one-way in for running foams on ashphelt, Will the kit setup be a good starting point? will I need to change pivot blocks etc. A staring ratio for 12t would be good to. Cheers
jnrtin is offline   Reply With Quote
Old 01-24-2007, 12:45 AM   #17198
Stein Tumert's Avatar
The diffballs are 3mm and you need 9 per diff for the MRE
If you PM me your email I can send you the msx/mre manual and you will have all the original part numbers...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-24-2007, 12:59 AM   #17199
thanks stein i will send you pm
Old 01-24-2007, 02:11 AM   #17200
TryHard's Avatar
od id width
8x 9 5 3 Hub Bearings - 950 size
4x 15 10 4 Front and rear Axle Bearings - 1510
2x 8 4 3 centre layshaft bearings - 840
2x 8 5 2.5 internal Diff bearings - 850
added the sizes and so on into your quote above (in red )
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-24-2007, 03:15 AM   #17201
Wing Chun's Avatar
Hi Guy's
Again, I am a knob and need to know a couple of anwser's on the MRE/MSX issue I have please.
Okay here I go.
Say you guy's that have a MRE and want to run the MRE one way. What do you do with the direct centre shaft and fixed TA05 pullleys. Do you change the centre unit over and if so to what?
Do the TA05 pulleys last longer or shorter and are they more efficient.
Also is the MRE top graphite chassis the same as the MSX or different.
Any help would be great.
Thank's again for all your support with my enquires.
Addam
Wing Chun is offline   Reply With Quote
Old 01-24-2007, 03:54 AM   #17202
Post
Originally Posted by TRFMAD
Hi Guy's
Okay here I go.
Addam
I am currently running my MRE with the MRE fixed center shaft and a MSX one-way up front (had to shave off 0.5 mm on each side of the MRE pulley - same also with TA05 pulleys - If you run the MRE one-way you do not have to do this)
Do you run MRE pulleys (with half the teeth) or TA05 pulleys (with all 36 teeth)?
No idea if the TA05 pulleys last longer...
I think the MRE pulleys were designed for better efficiency...
The MRE top deck is different due to the different steering...
Stein Tumert
Old 01-24-2007, 04:07 AM   #17203
proceed5's Avatar
Hi Guy's
Okay here I go.
Addam
Hi Addam,
IMO, To run Front and Center one-ways on MRE, you will need to get the Front MR One-way housing unit and for the center one-way you will either need (i) use the entire MSX-center shaft one-way system or (ii) get the TA05's center shaft, pulleys, spur holder n TA05 center one-way then add shims & modify from there to fit, OR best -(iii) wait for the MSXX system.
(hmmm, I remembered I posted this question some pages back, BTW, I think the Guys have advised to use the MSX system)
Top decks of the MRE and MSX are different at the steering crank position.
The plastic TA05 center pulleys have been on my TA05 for 9-10 months without much signs of wear.
Cheers
proceed5 is offline   Reply With Quote
Old 01-24-2007, 04:23 AM   #17204
Hi guys,
new to this forum, looks like a great source of info.
Been running my trusty 415 for a long time now, could anyone help me find a new chassis for it?
Think its about time to give the girl a make over
Thanks,
oldschool_415 is offline   Reply With Quote
Old 01-24-2007, 05:10 AM   #17205
First port of call for me when looking for bits would be THE eBay...
This guy seems to have a few bits including a brand new chassis, enter this number in the search box... 320074142386
Good luck with the search, shouldn't be hard to find one, escpecailly if you don't mind importing, pm if you need a list of the shops i use.
jakeburns is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
