Old 01-21-2007, 02:35 AM   #17146
Looking through the DHI cup thread I saw that marc r seems to be running a 415 ms of sorts.... any ideas why
http://www.rctech.net/forum/showpost...&postcount=158
jnrtin is offline   Reply With Quote
Old 01-21-2007, 08:00 AM   #17147
Charles Godwin's Avatar
Originally Posted by hyena boy
there is too much to read to try to find the info i am looking for so i am hoping someone can hook me up.
i have just picked up a 415msx and am looking for a set up for foam carpet tight layout. i have a few hop ups but not much.
thank you for the help.
jeff
If you are running foams i'd suggest you go onto the tamiya USA website any download Marc R's Vegas set-up, click here. Hope that helps.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 01-21-2007, 09:02 AM   #17148
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Marc's car @ the DHI was the 415MS w/ std susp arms/hubs & 415 MRE drivetrain (front & ctr 1-ways) based on that picture
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 01-21-2007, 09:06 AM   #17149
old 415 chassis is a lot stiffer for carpet and the ta04 arms and hubs work much more consistantly than the LW plus bigger hub bearing keep the corner speed up. and easier to fit 28mm foam on without clearance issues.
Smoking motor.. is offline   Reply With Quote
Old 01-21-2007, 09:29 AM   #17150
i have started running a diff on indoor carpet rubber. I am running the Reinhard lrp indoor setup on it i like the diff for the smooth turn in on high speed corners and the feel it has but I get a lot of of power under steer on the hairpin bends do i have to change my aproach to the bend or do i need to try a tighter diff. Note i don't like lots of steering I just want it to turn it a bit more off power.
Old 01-21-2007, 10:43 AM   #17151
Eirik's Avatar
Originally Posted by TRF415boy
I don't know what hole you're using on the front hub but you should use the rear one, it decreases the ackermann and makes the car easier. If it's still too much add some spacers under the steering ball studs to further decrease the ackermann. The reason I use the HPI front hubs is that it gives a tad more ackermann than the tamiya hubs (that, and the fact that I cba changing bearings all the time, lol). More initial steering and a bit less mid corner steering.
I tried raising the blocks before too but with the car being too soft I didn't like it. Then I put the Tech Racing top deck, which stiffened the car up, and then the car's handling improved instantaneously. I used the car with the blocks flat on the chassis but was having grip roll issues, which i resolved by raising the blocks.
I got Ed to raise his blocks by 1mm all round on his Evo 5 last sunday for the last final and he'd dropped nearly half a second off his laptimes, said the car was a lot better.
Using the rear hole on the spindle makes the car allot easier to drive, but it gave me less cornerspeed and slower laptimes!
I seriously think that the old steering would be better, we will see....
I will try raising the susp. blocks again and see what happens!
Cheers mister,
Eirik
Eirik is offline   Reply With Quote
Old 01-21-2007, 11:25 PM   #17152
Stein Tumert's Avatar
Here are some close ups from Marc's hybrid 415 car (thanks to Alexander Hagberg)
Tamiya TRF415-marc-r-415-dhi-2007-3.jpg   Tamiya TRF415-marc-r-415-dhi-2007-4.jpg
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-21-2007, 11:32 PM   #17153
dodo's Avatar
Send a message via Yahoo to dodo
what now? TRF415 MS MRE?
j/k...
dodo is offline   Reply With Quote
Old 01-21-2007, 11:45 PM   #17154
Tek Nickal's Avatar
Did the MS have the LW suspension? Then what was the difference between the original 415 and the 415 MS? Marc's car just looks like a 415 with the addition of the aluminum rear diff, wide pitch pulleys, center one-way pulley and the blue shocks.
I also noticed in the different pictures he has both white and black belts.
Tek Nickal is offline   Reply With Quote
Old 01-22-2007, 01:43 AM   #17155
I don't remember the MS coming with the LW arms. They come as an option.
The belt belts could be the MRE belts?
Ben.C is offline   Reply With Quote
Old 01-22-2007, 03:47 AM   #17156
TryHard's Avatar
Yup, MS was the first car to come with the LWT suspension. The chassis was 2.5mm and had re-drilled suspension mount block holes (closer together). The orginal car used 48.5 mm hinge pins, the MS onwards 46mm.
Thats why the old style suspension is such a tight fit on the MS versions onwards.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-22-2007, 08:31 AM   #17157
TRF415boy's Avatar
That's exactly what it is, a std 415 with just an updated drivetrain. If you notice the hinge pins are not the Ti ones, simply because they don't exist in 48.5mm...
TRF415boy is offline   Reply With Quote
Old 01-22-2007, 09:04 AM   #17158
pug 205 gti's Avatar
i would just like to thank tryhard,trf415boy etc for helping me make a decision to buy the msx mre.i must admit i was close to buying the 007 and the moore speed but i could resist joining the trf club your all so help full!
ive choosen the futaba 9550 servo its a decent servo at a decent price
pug 205 gti is offline   Reply With Quote
Old 01-22-2007, 09:44 AM   #17159
are there any web pages of interest regarding the trf msx etc
ive seen tryhards any others out there? thanks
Old 01-22-2007, 10:27 PM   #17160
Trader Rating: 23 (100%+)
If anyone knows of a clean 415MS for sale - please PM
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
