Old 01-19-2007, 04:43 AM   #17101
pug 205 gti's Avatar
so i take it the msx mre is not that good on carpet out of the box?
pug 205 gti is offline   Reply With Quote
Old 01-19-2007, 05:14 AM   #17102
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by Stein Tumert
With the EVO 5 shorter arms you can still run 46 mm, but is maybe a bit tight (front). I have right now 46mm rear and 42 mm in front (with 415 MSX oneway - on carpet) on my car and that has worked OK for me...
ok thanks, will try that also
buboy28 is offline   Reply With Quote
Old 01-19-2007, 05:50 AM   #17103
sohlman's Avatar
Trader Rating: 89 (100%+)
The MRE is fairly good out-of-the-box with rubber tires on carpet. A couple minor adjustments and you'll be planted. Foam on carpet is a bit more challenging. But once you get the car stiffened up and to rotate quicker, it can hang with any car.
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-19-2007, 05:54 AM   #17104
kewdawg's Avatar
Originally Posted by TRFMAD
Hey Kewdawg
What type of modes have you done to your MSX?
Addam
NONE. Haven't found a need to...yet. Although, I did try the Shooters top deck a couple of weeks ago. Can't say I noticed a big difference (maybe, a little more stabe / less lateral flex in the corners?). I made a bunch of changes that day, so I'll need more time with it.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-19-2007, 06:09 AM   #17105
kewdawg's Avatar
I take this back. I did install JET Racing - Pro 4/Cyclone blue aluminum steering knuckles and Hpi univeral axles. I'm using this set-up for running foam tires and to keep my steering knuckle expenses down. I don't crash a lot, but when I do... Sorry about that. I had to think about it for a minute. Too eary in the morning, I guess.
Quinn Moon
Old 01-19-2007, 06:37 AM   #17106
thanks sohlman for the reply
i will be running rubber tires lrp 24
what is the difference with the mss mre and the refine 2??? which has what etc
i have searched the thread but ever time the question gets asked no one seems to reply??
Old 01-19-2007, 06:41 AM   #17107
another worrying factor is to read posts where peaple are using yoko hpi and other bits???
are the over expensive tamiya msx mre not good enough standard??
why spend hundreds of dollars on the kit if the parts in it arnt up to the job?
im not slating the car im after learning about it thats all
Old 01-19-2007, 07:37 AM   #17108
Stein Tumert's Avatar
MRE and Refine 2 is the same car...no idea why they have 2 names...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-19-2007, 07:39 AM   #17109
It is common to change to HPI parts if you run foams (wider) as that does not work with the standard Tamiya steering parts....
Also some like to have bigger BBs than in the new Tamiya steering parts...
Stein Tumert
Old 01-19-2007, 07:54 AM   #17110
ive got a price for the mre at 520 us dollars
and a price for the refine 2 399 us dollars
this seems a little worrying as there is a lot of difference in price??
if i post the tamiya model number for both cars could you identify the kits?
cheers
Old 01-19-2007, 08:27 AM   #17111
TryHard's Avatar
Order of 415 kits goes;
TRF415;
Original kit, with 3mm chassis, one-piece bulkheads, front and rear centre braces, dual one-ways, 414 style suspension, Original black belts, and diff pulleys, plastic rear diff outdrives. Steel screws.
TRF415 MS;
Second kit, based on Marc R's '04 worlds winner (Limited edition). 2.5mm chassis, LWT reversible suspension, alloy rear hubs, blue shocks, low friction white belts, new lower shock towers with extra hole in rear, Dual-oneways, delrin rear diff outdrives. Ti Screws
TRF415 MSX Refine2;
Third kit, as MS, but with lower top-deck, two piece bulkheads with integrated camber link mounts, alloy rear diff (using replacable drive pin protectors). Steel screws.
TRF415 MSX Marc Rheinard Edition (MRE);
Forth kit; was the second MSX kit. Limited edition, with the new steering system, 36t delrin diff pulleys and new (longer) black belts, new one-piece centre layshaft (with replacable plastic pulleys) and front spool, new alloy centre brace and centre shaft bearing holders, and a lower deck with extra cooling holes (to utilise the still unreleased cooling duct). Also Ti coated shock shafts & hingepins, Ti Screw kit
TRF415 MSXX;
Coming soon, based on the MRE (so includes new steering system etc). Steel screws, new dual one-ways, new top deck, possibly a 2mm chassis plate, and the aluminium cooling duct. Effectively a non-limited edition MRE, though not quite.
That is a big price difference between the two cars though... who are you looking at buying from??
Hope that helps
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-19-2007, 08:51 AM   #17112
Sorry, I thought refine 2 was used about the MRE
Then the refine 2 is the MSX as rightfully noted...
Stein Tumert
Old 01-19-2007, 08:54 AM   #17113
the refine 2 kit was on ebay as a "buy it now".but its gone now so thats that!!! didnt buy it last night because when i put the model number in the tamiya usa site search function it didnt reconise the number.
but ive found msx mre at 430 us dollar plus shipping.??
try hard many thanks for your thorough reply a great help
i also to the time to read your web page.very nice work!!!!
damn you dont mess about do you..im impressed!!!
another concern i have is should i hold out for the latest release???
Old 01-19-2007, 08:57 AM   #17114
cheers
As we now have established that the refine 2 is the MSX , it should be cheaper than the MRE, but that is still a big price difference. However these cars have had videly varying prices at any time depending on where you get them from. My MRE was a tad over 300 Euro from RC Champ in Japan and at the same between 400 and 500 Euro in other shops around the world...
If you want a very good price you may want to send Masa at RC Champ an email... I would go for the MRE before the MSX if you can get one...
http://www.rc-champ.co.jp/Champ_Inte...onal_index.htm
Stein Tumert
Old 01-19-2007, 09:02 AM   #17115
proceed5's Avatar
I reckon go for the MRE, comes with a Protoform Mazda6 bodyshell and as well Titanum Screw set, in all, worth it. Furthermore, it is a Limited Edition kit
proceed5 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
