Old 01-18-2007, 08:31 AM   #17086
proceed5's Avatar
Originally Posted by Rogier
can anyone tell where I can buy new belts for the MR? I broke my front one and don't know the partnumber...
THANX!
Try here perhaps :
http://www.speedtechrc.com/store/ebp...?catmainid=521
proceed5 is offline   Reply With Quote
Old 01-18-2007, 10:01 AM   #17087
Setup for shorter arms
OK, just ordered a set of reversable short arms for my MRE has anyone got an awesome setup sheet they can forward me for carpet and rubber running 27t or 19t with a oneway.
I have also read somewhere that you have to change the suspension blocks to make the car wider when running the short arms as the driveshafts will not fit in. This sounds a little contradicted as you are making the car wider again? Unless you get more arm movement or something.
Paul
blue247carz is offline   Reply With Quote
Old 01-18-2007, 10:04 AM   #17088
Default MRE Belt part no.s
Originally Posted by proceed5
Here are the belt part numbers: 6245013 Front
6245014 Rear
Thats from the manual
Cheers
Old 01-18-2007, 11:38 AM   #17089
Rogier's Avatar
6245014 Rear
Cheers
Thanx! I couldn't find the partnumbers from the manual at any shop. With the link above I do now! Do the 'regular' MSX belts also fit on the MR??
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 01-18-2007, 01:05 PM   #17090
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Originally Posted by TRFMAD
Hi there
Can some one please tell me what part number for the metal outdrives for the MRE/MSX tamiya Spool. I keep breaking mine and was wondering if there is a outdrive in metal or titanium, or what other brands fit onto the tamiya spool.Also with all the guy's using metal out drives have you had no problems with them.
Thanks in advance
Addam
Hey Addam, Maybe this will help. I just bought these metal outdrives for the spool:
http://www.rcmart.com/catalog/produc...ducts_id=19311
Good place to order Tamiya stuff.
Happy Racing!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 01-18-2007, 01:14 PM   #17091
Kwikvdub's Avatar
The belts are different because the MSX is 35T and the MRE is 36T. Here's a place you can find belts for both cars and the prices are real good. I get my stuff here all the time: http://www.rcmart.com/catalog/produc...ducts_id=19311
Hope this helps!
Alex Valdes
Old 01-18-2007, 01:21 PM   #17092
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Belts work on both. Im using MSX belts on my MRE, until my new MRE belts come in. Its been discussed a few pages back, from memory, the differences were a slightly different shaped tooth, but both work just fine. I have a lineup of diffs (so i dont have to rebuild at anystage at the track) and some have the MRE pulleys and some have the TA05 pulleys, but either will work. Cant recall if there is a difference in length (i think there is) but the adjusters will take out the difference no matter which belt you go for. HTH
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 01-18-2007, 03:55 PM   #17093
SpeedDesignz's Avatar
Send a message via AIM to SpeedDesignz
Happy Racing!
Look at Alex trolling the Tamiya thread !!!
good to see you joined Big Blue
good luck with your new ride.
NYC Hobbies / Eurotek motorsports / SpeedDesignz / BackBreaker Racing !!
SpeedDesignz is offline   Reply With Quote
Old 01-18-2007, 04:36 PM   #17094
pug 205 gti's Avatar
which model 415 trf would be suited to a small indoor carpet track?
or is the trf suited to larger tracks?
what parts would be essential to have in my spares box too?
sorry about the questions but the trf thread is huge i would be here for weeks reading
thanks
pug 205 gti is offline   Reply With Quote
Old 01-18-2007, 05:46 PM   #17095
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by Eirik
The car will square up better and your laptimes will be faster
I am using the short arms on both carpet and asphalt with rubber tires.....
if using the revrsible short arms, will the 46mm swing shaft work or do you have to change it also to 42mm
buboy28 is offline   Reply With Quote
Old 01-18-2007, 06:47 PM   #17096
Kwikvdub's Avatar
Thanks Bro!!......... I'm Hooked!........... And now I have 2 of them. MRE and the MSX.
Can't wait to run them outdoors. Two set-ups, Spool and the other One-Way.
See you at the track!
Alex Valdes
Old 01-18-2007, 06:58 PM   #17097
xtrememadness's Avatar
Send a message via AIM to xtrememadness
alex valdes in the house whats up bro. welcome to team blue im not givin up on my 415 for carpet just yet. i found some strong ball studs gonna test em out when they arrive.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-18-2007, 07:00 PM   #17098
Kwikvdub's Avatar
Very cool Bro!!.......... We have the new layout down at SSH............ Madness on Sat. and SSH on Sunday.......... Isn't life grand.
See you soon!
Alex Valdes
Old 01-18-2007, 07:12 PM   #17099
cool. good luck at madness. see ya sunday. i love new layouts. and yes, life is grand
Old 01-18-2007, 11:45 PM   #17100
Stein Tumert's Avatar
With the EVO 5 shorter arms you can still run 46 mm, but is maybe a bit tight (front). I have right now 46mm rear and 42 mm in front (with 415 MSX oneway - on carpet) on my car and that has worked OK for me...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
