Old 01-10-2007, 09:23 PM   #17026
simini80: I'm using the roller ball bearing on the rear hub. It last like forever and able to take hard side crash no problem. You can get it in here http://rc-mushroom.com/product_info....ducts_id=10450
ioxqq is offline   Reply With Quote
Old 01-10-2007, 09:42 PM   #17027
Difuser, TryHard, Ben.C and TRF415boy, Thank you all for spending your valuable time on helping my problem.
OK, I know the soft spring = the more weight transfer. But I want to know does it mean:
1. The soft spring on rear = more weight transfer to front when off throttle or
2. The soft spring on front = more weight transfer to front when off throttle?
Second question, I still not sure on this. When on throttle, if I use stiffer spring on rear then I get more weight transfer on rear. So, I get better traction on rear. Right? Vice versa, if I use stiffer front spring when off throttle. I will get more front traction but less traction when on throttle. Because stiffer front spring is easier to move weight to the rear. Isn’t this correct too? Hope I can get the straight so that I can working on rc in the right way.
Old 01-11-2007, 01:46 AM   #17028
TryHard's Avatar
In answer to your first question, its 2.
A softer spring will allow more weight transfer to that end of the car.
Your second Q;
You'll get less weight transfer, so less traction.
I sounds like your looking from a full scale perspective. One thing to rememeber is that with our cars, we have down travel limiters (the droop screws), which effectively overide the effect of the sping on the opposite end of the car. For example, On-power, if the front arm is resting on it's drrop screw, then the front spring effectively won't contribute to the traction level, that will be down to the rear spring.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-11-2007, 02:19 AM   #17029
TRF415boy's Avatar
This is mainly right but as ed pointed out, droop stops limits the influence of spring stiffness on the unloaded end of the car.
As for the first question, it's very simple, it works the same way on the rear when it's on power as it does on the front when it's off power. I'll resume things so it's clear:
Front:
stiffer springs --> less on AND off power steering
softer springs --> more on AND off power steering
But at this end, droop has more effect than springs when coming on power
less front droop --> more ON power steering
more front droop --> more ON power stability
Rear:
stiffer springs --> more on and off power steering
softer springs --> less on and off power steering
less rear droop --> less OFF power steering
more rear droop --> more OFF power steering
TRF415boy is offline   Reply With Quote
Old 01-14-2007, 12:16 AM   #17030
Wing Chun's Avatar
Hi Guy's
My friend want's to order parts to convert his MSX centre into a Reinhard TA05 centre.
Can someone please give me the part numbers to convert the centre pin, centre hub and anything else he will need please.
Both he and myself have the TA05 wide pitch hubs but he wants the centre as well.
Thanks Guy's
Addam
Wing Chun is offline   Reply With Quote
Old 01-14-2007, 12:26 AM   #17031
chris_morrison_'s Avatar
http://www.precisionrc.com/nv/car/pr...oduct_id=31809
chris_morrison_ is offline   Reply With Quote
Old 01-14-2007, 12:51 AM   #17032
Wing Chun's Avatar
Thanks Chris
Addam
Old 01-14-2007, 02:58 AM   #17033
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by TRFMAD
Hi Guy's
Thanks Guy's
Addam
Addam, Here is the Tamiya instructions for the MRE, if you want to do it with tamiya parts.
tamiyarcracer is offline   Reply With Quote
Old 01-14-2007, 03:03 AM   #17034
proceed5's Avatar
I dont think the Center shaft has been released yet right ?
Regard,
John C
proceed5 is offline   Reply With Quote
Old 01-14-2007, 03:33 AM   #17035
Regard,
John C
I have it in stock at my shop here in the US. #3454395
Old 01-14-2007, 03:39 AM   #17036
Wing Chun's Avatar
He wants to do it in tamiya parts.
Do you have pay pal and can you send me a price to my email address for him, he said he would pay it into my pay pal.
Can you send me atotal to
[email protected]
including postage to
Gold Coast, Queensland, Australia.
Thanks mate
addam
Old 01-14-2007, 03:41 AM   #17037
Wing Chun's Avatar
Also tamiyaracer I can't find the link to the MRE link you said.
thanks
addam
Old 01-14-2007, 10:34 AM   #17038
thanks
addam
http://www.tamiya.com/japan/rc/rcman...4trf415msx.pdf
Sorry about that.
Old 01-14-2007, 03:05 PM   #17039
Wing Chun's Avatar
Thank's Troy
So If I use all the pieces do I still use scott's MSX bearing hoders and bearings? Also how does it stay in , It's just that with the MRE it looks like it just sit's in and stays there with the top alloy mount holding it in. and with the MSX it is held in by a cerclip at one end and a grub spacer with a allen bolt at the other end.
Can you please verivy that with just these parts it will fit.
# 3454395 RC Direct Center Shaft: 49394
# 3455643 RC Spur Holder Plate: 49283
# 50589 RC 5mm E-Ring: # 51213 RC TA05 Center Pulley 16T
# 53534 RC 3x8mm CSunk Hex Head Screw Titanium.
I will have to tell him how much it will cost him with all the Part's.
Thanks Mate
Addam
Old 01-14-2007, 03:38 PM   #17040
Thank's Troy
Thanks Mate
Addam
I will verify with an MSX, and the MSX MRE before I order the parts, but the I think that it is the same on both, just the MRE uses a alloy bearing support.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
