Tamiya TRF415
Old 01-07-2007, 02:35 PM
  #16966
racer43's Avatar
Default what cooling fan
what cooling fan can i use on my trf 415 msx mre? I usually buy from rc-mushroom.
racer43 is offline
Old 01-07-2007, 03:16 PM
  #16967
tamiyarcracer's Avatar
Integy makes a good one that is inexpense, also Much more has one that mounts on the endbell of the motor, with posts.
tamiyarcracer is offline
Old 01-07-2007, 03:55 PM
  #16968
SpeedDesignz's Avatar
I use the Team Tamale clamp on one. Works great and offers different fan mounting positions.
http://home.earthlink.net/~cbradshaw25/id33.html
SpeedDesignz is offline
Old 01-07-2007, 05:04 PM
  #16969
tboned_2002's Avatar
Originally Posted by sohlman
It's always the parts you don't have are the ones you need. Try and build your supplies up to almost having an additional kit. Start with suspension parts, especially the front end...blocks, hubs, arms, hardware, etc. Then work your way to the rear suspension, drive train, turnbuckles, ball cups, ball ends, and the list can go on & on. I'm the type that always has too much. jm2.
hit me up on the celly cell.
tboned_2002 is offline
Old 01-07-2007, 06:13 PM
  #16970
Tek Nickal's Avatar
Originally Posted by SoCalMitch
How close do you think the Tamiya shock oil is to Associated shock oil?
I believe Tamiya shock oil is rated in #, ie: #300, #400. While AE oil is in wt, like 45wt, ect.
Tek Nickal is offline
Old 01-07-2007, 06:25 PM
  #16971
Tek Nickal's Avatar
Originally Posted by Bob Marley
Thanks for all the advice on the Tape vs Plate(battery). I will use tape..
Now my next question for y'all is:
I am gonna be running a stock motor in this MS, It comes with a 102t spur, What pinion size would I use? I realize it could change due to the track, but can you put me in the ballpark? Also, would it be better to switch to 48p instead?
Thanks in advance, Bob
If you have 48 pitch pinions, then it might be wise to switch. Otherwise throw that 102t Tamiya spur out the window. It is not 64p. its .04 module. Which means that 64p pinions won't fit perfectly on that spur.
If you leave your spur at 102t 64p, a 32t pinion would put you in the ballpark for a Monster Stock motor. Although you didn't make it clear what motor you were you using.
Old 01-07-2007, 06:42 PM
  #16972
Originally Posted by Tek Nickal
I was thinking the same thing...just run foams. I would need the 13.5 and Lipo to go along with that to be a complete cheater.
But wow, thats exactly my problem as you described it. It was almost like as if you drove my car and knew that was the problem. Should have told me that earlier, haha.
I told you at the track but you just didn't listen as usual. As for Lipo an 13.5 BL. You can get those but you'll still lose to my old skool Monster stock and 3300s.
Sydewynder is offline
Old 01-07-2007, 07:35 PM
  #16973
Tek Nickal's Avatar
I remember asking "What should I do to my car?", I don't remember getting a direct response. Oh well.
Like I have money to get those things. I'll try to use foam tires though.
Old 01-07-2007, 08:58 PM
  #16974
Want to know what is the part number for the 415 MRE rear diff pulley. thanks
ioxqq is offline
Old 01-07-2007, 09:12 PM
  #16975
53935
Old 01-08-2007, 03:29 AM
  #16976
Wing Chun's Avatar
Hi Guy's
Okay Guy's I need help from the Great MSX Gods again please.
I would love to know what is the difference between running a centre one-way and a direct centre one-way with a front one way.
Also on a smooth fast track with a one way up front which would work better.
And with a diff up front what would work better and with a spool which cente would work better.
God i hope I am making sense here with this question.
Thanks Guy's
addam
Wing Chun is offline
Old 01-08-2007, 04:01 AM
  #16977
TryHard's Avatar
Running both (centre and front) will make for a smoother car to drive. Effectively, the front belt won't spin off power (reducing drag), and you reduce the chance of any difference in the freeness of the bearings of the front one-way unit having an effect on the car.
If you run the direct centre unit, you'll have better throttle response, but you are relying on the front one-way unit to do all the work on turn-in, which can cause problems if the bearings are not close in freeness.
Personally, if I'm running a front one-way, I'll run the centre as well. I just prefer it that way.
For a Diff or Spool, I'd stick with a direct centre unit, simply as otherwise you loose the main advantage for running one of thoose options... braking ability.
HiH
Ed
TryHard is offline
Old 01-08-2007, 04:06 AM
  #16978
bender's Avatar
Originally Posted by TRFMAD
Hi Guy's
Thanks Guy's
addam
When you have both the centre and front one-ways in, you get maximum turn-in from the car, plus maximum drive train efficiency, however brakes are practically non-existant - ie: you'll spin the rear round as soon as you touch them.
If you use a spool up front them you should always run the locked centre pulley. If you run a spool with the centre one-way pulley then you'll have no brakes, therefore losing all the advantage of running a spool in the first place.
If you run a diff up front you should also run the locked centre pulley - because at least you have brakes. If you run a front diff with a centre one-way then again you have no braking, plus you'll also have poor mid/exit corner steering.
In summary, my recommendations on combination are:
Front one-way with centre one-way : maximum turn in + efficiency + speed - no good if you need brakes or can't drive smoothly.
Front one-way with locked centre pulley: a bit less turn-in than above but otherwise similar. When I ran the MSX I always used both one-ways together.
Front spool with centre locked pulley : maximum mid/exit corner steering, strong brakes, but poor efficiency and hard on the drivetrain components.
Front diff with centre locked pulley: good brakes, easier to drive, but generally pretty poor steering everywhere - easiest on the car in terms of drivetrain wear.
Ok, I'm off to bed
bender is offline
Old 01-08-2007, 04:16 AM
  #16979
Wing Chun's Avatar
Thank's So Much Tryhard and bender for your help , that was exactly what info I needed.
Addam
Old 01-08-2007, 04:33 AM
  #16980
Wing Chun's Avatar
One other thing please guy's, I also have a yokomo oneway joint that goes into the Tamiya oneway, it joins onto the other one on the other side making kind of a oneway spool locking both wheels together so if you spin one the other one spins with it. What is the advantage or disadvantage of using this unit in my one way please.
thank's Guy's.
Addam
