Old 04-06-2004, 12:19 PM   #1681
Hebiki's Avatar
Trader Rating: 26 (100%+)
so old MR4TC diff.. with F201 dog bone in the front.. and wa-la! front diff for the 415?
let us know please!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-06-2004, 01:38 PM   #1682
alan1467's Avatar
let us know please!
Is it the front or rear MR4TC diff that you use for the conversion?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 04-06-2004, 01:44 PM   #1683
RandyB's Avatar
What all does the TRF 415 Come with? Sway bars etc. can you put other manufactures gears on the car without a spurgear adapter?
RandyB is offline   Reply With Quote
Old 04-06-2004, 02:30 PM   #1684
izzyracer's Avatar
Trader Rating: 27 (100%+)
yes
Izzy
izzyracer is offline   Reply With Quote
Old 04-06-2004, 02:31 PM   #1685
Turbonium's Avatar
Send a message via Yahoo to Turbonium
sure... the spur holder will take most anyones gear. i used a Xenon 100T.
and the front set i mocked up were from the MR4TC Belt car, part #ZS-501, i think. they are centered. there is a lil slack on either side, but should be able to use spacers. it uses the same bearings inside of the diff, but the drive rings prolly hafta match.... might be able to use the Tamiya hardware, thrust assy, bolt, etc. and i think the F201's cvd's should take care of it. ill grab the stock dogbones/axles and mock it up this eve and shoot some pix to see where we are.
this is one of those times it pays to have a bajillion cars... and parts!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-06-2004, 03:41 PM   #1686
JimmyMac's Avatar
Crossing my fingers!! I should just order a set of F201 universals anyways for my F201. If they do work... they may work their way into the 415 when I need it. I don't need a diff for the 415 as I love to race with oneways... but once we go indoors for carpet.. a diff would be hella nice. Plus I could actually use this car at the Snowbirds next year.....
Randy it comes with a full set of swaybars. All the rear toe blocks. And a few extra shims for camber/roll center adjustments. All you really need are 2 sets of tuning springs and you are ready to go. Minus the body, tires, electronics.. etc. I run an RW 104 spur right now.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-06-2004, 05:46 PM   #1687
over gear's Avatar
Trader Rating: 15 (100%+)
The MR4tc front diff is centered?? I'm look at the MT4tc front oneway and the pulley is offset to one side.....
over gear is offline   Reply With Quote
Old 04-06-2004, 07:30 PM   #1688
Turbonium's Avatar
well, maybe these were the rear. they come as a set. here is a pic:
the F201's wont work, i dont think. those of you with them will notice that the inner bearing is huge... like the diff bearings. havent looked at the rear yet, tho... figure its the same. in this pic i have a set of unknown MIPs. might work, except i have to use a spacer between the cv and the inner bearing... not sure how that would affect the geometry...
Wes
Team Novak
Old 04-06-2004, 07:48 PM   #1689
RandyB's Avatar
what springs would you suggest? and are any of the parts prone to breakage?
Hows the car handling in mod can anybody give me props
Old 04-06-2004, 10:20 PM   #1690
PaulG's Avatar
Default Tamiya 0.4 Pinion Sets
Quick question. Are the Tamiya 0.4 Pinion Sets the pinion gears sets that you need for the 102 spur gear that comes in the kit.
Cheers
Paul Griffin
Losi 8ight-T
NitroX Fuel : RB Concept Motors
Spektrum DX3R : ACE Servos : Proline Tires
Hobbytime.com.au
PaulG is offline   Reply With Quote
Old 04-06-2004, 10:22 PM   #1691
PaulG's Avatar
Default Internal gearing
Can anyone give me the internal gear ratio 2.XX
Cheers
Paul Griffin
Sorry I got the ratio 2.187
Losi 8ight-T
Hobbytime.com.au
Old 04-06-2004, 10:27 PM   #1692
JusBox's Avatar
Is tamiya seriously not coming out with a front diff for this car? talk about bone headed.
JusBox is offline   Reply With Quote
Old 04-06-2004, 10:31 PM   #1693
JimmyMac's Avatar
Tamiyadriver, you are not gonna use the F201 axles... just the bones. So it doesn't matter how big the F201 bearings are. Just rebuild the 415 axles with F201 bones and you should have a longer universal set.
Randy, I haven't tried the car in Mod.. yet. But so far nothing broken on the car except a body post. I did have a rear suspension block slightly bend. But that was because a Nitro car ran dead smack into the back of me during practice. Nothing broke. But the block got tweaked. That's what you get for moving over down the straight-a-way running stock to let a nitro go by.
I dunno about the pinions. I run Robinson pinions with RW Spurs. But usually with Tamiya their pinions might "fit" better with the kit spurs.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-06-2004, 10:45 PM   #1694
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Tamiya 0.4 Pinion Sets
Cheers
Paul Griffin
Yes, the 0.4 pinon gears are the same as standard 64 pitch pinon gears.
The internal ratio for the 415 is 2.1875
jeffreylin is offline   Reply With Quote
Old 04-06-2004, 11:05 PM   #1695
rccarracer's Avatar
Default Re: Re: Tamiya 0.4 Pinion Sets
Actually they are not.....
It is only out by a small margin, but they are different. I would change to 64 pitch spurs.....
I use a 100 tooth in mine.
rccarracer is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
