Old 12-21-2006, 12:17 AM   #16786
Big B's Avatar
Thanks, is there a fan mount for or on the heat sink
Big B is offline   Reply With Quote
Old 12-21-2006, 12:25 AM   #16787
To my limited knowledge,I don't think Tamiya makes fan mounts. Usually we make our own fan mounts or some other 3rd party manufacturer's fan mount.
Ben.C is offline   Reply With Quote
Old 12-21-2006, 04:28 AM   #16788
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Eirik
I use 1D-1XB in the rear and 1B-1A in the front on asphalt, for carpet I use 1D-1D in the front.
6mm hexes front and rear, + 1mm shims in the front....
I normally run my car at 189mm in the front and rear.
Sometimes 187mm in the front to get more steering.
Thx Eirik/Steen. I'm running the same block combo as Eirik at the moment so I might give the short arms a try. You guys running 6mm hexes and one way as well on asphalt also?
Cheers,
Vincent
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 12-21-2006, 04:40 AM   #16789
veecee's Avatar
Originally Posted by TryHard
Don't use a servo saver myself either.
If you look closely, the front driveshafts look like MIP style CVD's.. my guess they are the TiR Worlds ones.
anyway, some more...
Rick Howarts car
http://www.rcinfos.com/2006/2006_07_...pub=1&idt=gb-0
Marc's
Check out the swaybar holders. Looks like they ran the EVO5 holders with an additonal dampener between the swaybar and the bulkheads.
Old 12-21-2006, 06:01 AM   #16790
Eirik's Avatar
Cheers,
Vincent
Vincent,
I have not used a one-way since 2004 I think..... In Modified, spool is the way to go, no doubt!!
Oh yeah, I use the same track width outdoors as well, 6mm hexes always with the short arms!
Eirik is offline   Reply With Quote
Old 12-21-2006, 06:04 AM   #16791
TryHard's Avatar
I think they are the Evo4 ones. They are a exact fit for the front bulkhead, but need the centre section chopped out to fit the rear.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-21-2006, 09:21 AM   #16792
freekthefreak's Avatar
Originally Posted by TRFMAD
Thank's so much guy's for the Links to some great pictures that I was after. Also thank you Stein for the Pictures you sent to my email. I was blown away by some of those pics and link's.
Best wishes
Have a safe and merry Christmas
Addam smith
could you send me those from the email?
thnx
freekthefreak is offline   Reply With Quote
Old 12-21-2006, 12:37 PM   #16793
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Post TRF415 Front Diff with TA05 Diff Pulley
Quick question to my fellow 415ers.
Has anyone used the recently released TRF415 alum front diff with the TA05 std/wide pitch pullies on either their MSX or MRE?
Thanks.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 12-21-2006, 12:50 PM   #16794
sohlman's Avatar
Trader Rating: 89 (100%+)
Thanks.
Yes sir. Only on carpet with my MRE. The first time I used it, it loosened up a lot. I tightened it and now it works perfect.
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-21-2006, 12:57 PM   #16795
mike jones's Avatar
what sup soulman
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 12-21-2006, 12:59 PM   #16796
sohlman's Avatar
Originally Posted by mike jones
what sup soulman
Sup BT? So what do you know about electric cars? I hear you want one...hit me on the pm.
Steve Sohl
Old 12-21-2006, 01:27 PM   #16797
moshmike's Avatar
Much more makes some motor posts, Marc's sponser.
http://teammuchmore.com/product_info...roducts_id=424
I've heard they are not ROAR legal in the U.S.
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 12-21-2006, 02:31 PM   #16798
Big B's Avatar
Thanks picked up a set of MMR endbell posts in blue
Old 12-21-2006, 06:00 PM   #16799
rtypec's Avatar
On Marcs motor heat sink there is a fan mounted is that availible or just a mod
It's a modified motor heatsink. How it was made:
Take a heatsink.
Drill a 3mm hole into heatsink.
Tap 3mm hole in heatsink.
Cut down a Dark Impact beam.
Tap 3mm hole in beam.
Use a 12-15mm droop screw with loctite to attach both pieces to each other.
Make sure that there is clearance so that the beam does not hit the motor (dremel beam material if necessary)
Screw fan to beam.
It would be an easy update to the heatsinks if Tamiya Japan wishes to create such a hop up.
Here's one we made at the KO Race...the Dark Impact beams were in the warehouse so we couldn't get to them...we ended up cutting down a 415 beam.
Also, please note that if you get T-Boned or have an accident that causes a hard object to impact the motor side of your car...you can kiss the fan good bye.
rtypec is offline   Reply With Quote
Old 12-21-2006, 06:57 PM   #16800
quantum's Avatar
Take a heatsink.
Screw fan to beam.
actually, there is a way to do that with less work... you can buy this
endbell fan kit
quantum is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
