Old 12-20-2006, 12:53 PM   #16771
TRF415boy's Avatar
Originally Posted by sohlman
Hey Ed, Curious...does it feel more precise? Reduce slop? Why take the chance? Thx.
Because it makes the car turn left when you want it to turn right
Sorry Ed couldn't resist, but I have to say I use kimbrough servo savers and had no problems at all. I wouldn't use a direct link indoors, but I have used them outdoors in the past. Now i'm too lazy to change it all so once my steering is setup for one type I can't be bothered changing it all over again
TRF415boy is offline   Reply With Quote
Old 12-20-2006, 01:03 PM   #16772
sohlman's Avatar
Trader Rating: 89 (100%+)
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-20-2006, 03:26 PM   #16773
Default Need a bit of help
Hi.
I am in need of a bit of help in making a decision. The 415MSXMRE as it is as kit. Whats it like on carpet? I would be looking at changing the spool in the front to a diff or one way. Just want to know how many of you use it on carpet? and roughly what needs to be changed on the car. I know that the MRE has got its own one way and doesn't use the standard 415 one, but what about the alu. diff joints? do they fit these diff housing?
Cheers.
blakeyx is offline   Reply With Quote
Old 12-20-2006, 04:40 PM   #16774
Stein Tumert's Avatar
Thumbs up
Originally Posted by blakeyx
Hi.
Cheers.
The MRE works very well on carpet with the shorter LW EVO5 arms (rubber tires).
I run the MRE with the MSX oneway as the new MRE one-way was not available when I set up the car (you have to shave off about a 1 mm of the pully), however now it should be easier to get the new MRE one-way right away...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-20-2006, 04:46 PM   #16775
Thanks you stein
Old 12-20-2006, 04:53 PM   #16776
Wing Chun's Avatar
Thank's so much guy's for the Links to some great pictures that I was after. Also thank you Stein for the Pictures you sent to my email. I was blown away by some of those pics and link's.
Best wishes
Have a safe and merry Christmas
Addam smith
Wing Chun is offline   Reply With Quote
Old 12-20-2006, 05:28 PM   #16777
Big B's Avatar
If you want to get the MRE you better do it quick cause they are discontinued and all the distributers are low on stock, they were a limited run, to be replaced by the MSXX
Big B is offline   Reply With Quote
Old 12-20-2006, 05:36 PM   #16778
TryHard's Avatar
Originally Posted by Charles Godwin
I think that servo arm is a Sanwa one.
Charles
Correct, had one on my ERG WRX... before I hit the wooden pit wall at cotswolds.. doh! Currently using the ones that come with a Yokomo BD, on both the MRE and Evo5, and work fine.
Personally, I used to find the Kimborough servo savers rubbed on the chassis when running my sanwa servo, so switched to the solid to stop that happening. I still have the kimboroughs as a fall back in case I break the solids again, but haven't yet tried it with the 9550's I now run, so may be different.
The curent metal geared servo's can take a hell of a loading before they break... and your more likely to break another part of the car before them (wishbone, servo horn etc), so the risk is minimal. Thats just my view though.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-20-2006, 05:42 PM   #16779
Charles Godwin's Avatar
You're ment to stay off the walls Ed
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-20-2006, 06:17 PM   #16780
racer43's Avatar
Default trf 415 msx mre
I got a question concerning the rear differential. How tight the two differential joints have to be in relation to the white pulley?.Shouls this differentials rotate around the pulley?
thanks for your help
racer43 is offline   Reply With Quote
Old 12-20-2006, 06:22 PM   #16781
Easiest way to tell if a diff is tight enough is to build it and install it in the car, then hold one wheel and hold the spur at the same time. Try and rotate the other wheel whilst holding the spur and the opposite wheel. If you can turn the wheel then it is to loose, tighten until ou can't move the rotate the wheel. I haven't had a problem with any diff using this method.
Charles
Old 12-20-2006, 10:49 PM   #16782
Big B's Avatar
Originally Posted by freekthefreak
On Marcs motor heat sink there is a fan mounted is that availible or just a mod
Old 12-21-2006, 12:00 AM   #16783
Big B's Avatar
Anybody know what tamiyas heat sink beam is for
Old 12-21-2006, 12:06 AM   #16784
Tek Nickal's Avatar
Looks like he attached one fan mount to the motor heatsink, then made a plate to put the fan on.
Tek Nickal is offline   Reply With Quote
Old 12-21-2006, 12:13 AM   #16785
Thats the middle piece of alumunium that connects the rear bulkheads together and its finned.
Ben.C is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
