Old 12-14-2006, 04:53 AM   #16726
BrainTeased's Avatar
sounds to me like you have tweaked the chassis by not screwing the screws in sequences
try lossening all the top deck screws and place the chassis on a flat surface and tighten the screws from the inside out.
Originally Posted by TRFMAD
Hi Guy's
I don't no what the hell happened, I pulled my car down and cleaned it and put it back together and now when I put the car under power looses the tail end to the left.The car want's to spin out to the right. Prior to this the car was so good.
I checked my ride height thats fine 6 at the back 5 1/2 at the front.
Droop 3 mm front and back
I did not change anything at all except pulled down the front and back diff and cleaned and relubed them. I have checked the camber front and back and toe in and out and all exactly the same as they where before.
Is there anything I should check over that I am missing or have could the diffs be to tight or loose but I set them up right I think.
Also when I stop the car and try to do a full lock turn under power to the left the car pushes , but when I turn the car to the right and do a full lock and power the car does a donut easy with no pushing.
Really strange,is there a christmas gremlin in my car. Ha ha.
Any input would be great.
Thanks Guy
Addam
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-14-2006, 05:25 AM   #16727
Wing Chun's Avatar
Thank's Guy's
I pulled the diff out and checked the bearings and they were fine then I checked the rear uprights and the left hand side bearings were Stuffed. I replaced them and Flash , she is back on track. No pull at all.
Thanks bender thats 4 lesson in golf I owe you now.
Also thank you to Brainteased I will also tommorrow do what you said and see if there is any tweek there as well.
Thanks Guys
Addam
Wing Chun is offline   Reply With Quote
Old 12-14-2006, 06:25 AM   #16728
kewdawg's Avatar
Originally Posted by Eirik
I agree with TRF415boy, running Kick-Up will give allot more turn inn and can cause the rear end to step out!!
Also, running too much camber change in the rear will upset the balance, understeers on power and oversteers off power!!
I am running 2mm washer under the link on the innside and only 0.5mm on the outside. This gives a nice balance and makes the rear end much more controllable.
The car is too loose in the rear. The entire front-end set-up I gave will help reduce weight transfer to the front and nullify any addl. steering gained by using spacers under the front block. Its not the "end all" to the the problem -just one of many tuning options. Reducing rear droop is the single most effective change, but not the only changed needed. You have to factor into the equation, the amount and speed of "roll" the rear end exhibits. Also the camber gain or lack there of. On another note, setting the front outboard toe to 0 degrees, will also help with having too much steering going in the turn.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 12-14-2006, 11:39 AM   #16729
stuey's Avatar
Hi Guy's
Thanks Guy
Addam
check you have put your diffs back in the car correctly make sure the assentric belt tensioners on the diffs are in the same slot ie diff not slightly twisted
stuey is offline   Reply With Quote
Old 12-15-2006, 04:42 AM   #16730
Wing Chun's Avatar
Thank you Stuey
Best wishes
Addam
Old 12-15-2006, 05:51 PM   #16731
Wing Chun's Avatar
Hi Guy's
What after market mods have you guy's made to your MSX/MRE cars and how have they improved the performance of the cars handling of look.
Me I added the TA05 front and back pulley,Square bumper and post guard.
Made such a difference in smoother drive. Xray Battery strap.
Let us know about your car.
Thanks Addam
Old 12-16-2006, 06:35 AM   #16732
Send a message via MSN to Pop.
Hey guys, im gonna join the 415 msx club
I have not received my Mre yet, but i need to know some things :
What is its internal drive ratio (with tao5 pulleys) ?
What is the spur (how many tooth) ?
Pop. is offline   Reply With Quote
Old 12-16-2006, 07:44 AM   #16733
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
IDR = 2.25
Spur = 102T Tamiya Spurgear .06 module (change to 102 or
higher aftermarket 64P spurgear)
Welcome to the 415 club!
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 12-16-2006, 10:31 AM   #16734
thanks
Old 12-17-2006, 09:51 PM   #16735
Want to know what is front tyre rear suspenion mount block for the 415MSX?
ioxqq is offline   Reply With Quote
Old 12-17-2006, 10:47 PM   #16736
JRRobiso's Avatar
Arrow
The answer to your question is....Block XB (upside down with 3 x 3mm alum spacers - based from the MSX manual).
Old 12-17-2006, 11:27 PM   #16737
What's your front suspension block??
Usually I use f(1A/1B) & r(1A)...
Ben.C is offline   Reply With Quote
Old 12-18-2006, 02:21 PM   #16738
HarshGuy's Avatar
Damn the bad luck!! ...got my replacements in and I apparantly ordered the wrong part number for the long belt on an MRE ...the part I got was a white belt (part number in the "big manual") ...can't seem to find a part number for the long belt in the MRE supplement ...anyone know the part number?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 12-18-2006, 03:03 PM   #16739
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by sohlman
chris_m: Here's my MRE setup. It really worked for me in 19T with foams on carpet. Mod, you will need to stiffen it up even more. The best thing about this setup...no hpi, old MS or any other front end parts. I used the stock front knuckles and carriers. The catch is, you do have to run 26mm front foams. I cut PARMA CYAN to 26mm and left the rear MAGENTA 28mm. They worked great. I hope this helps.
You're on your own Steve...I sold out this weekend
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 12-18-2006, 03:40 PM   #16740
sohlman's Avatar
Trader Rating: 89 (100%+)
Quitter.
I bet you buy an MSXX for asphalt...
Steve Sohl
sohlman is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
