Old 12-11-2006, 06:06 PM   #16681
TRF415boy's Avatar
Originally Posted by WRXTC
Someone else at my track that drives an MSX told me to try that out to make the front less twitchy? So I gave it a try and it did help the front end out and didn't contribute to the problems I was experiencing with the rear of the car as the rear was doing the same thing before I put the spacers under the front block.
Not really, you're making things worse by increasing weight transfer to the front while coming off power.
If your problem is only off power, then the easy fix is to reduce rear droop.
TRF415boy is offline   Reply With Quote
Old 12-11-2006, 06:41 PM   #16682
Talking msxx
anyone know when the msxx will be released
thanks
skiv is offline   Reply With Quote
Old 12-11-2006, 07:57 PM   #16683
thanks
February 2007
trf_racer is offline   Reply With Quote
Old 12-11-2006, 10:45 PM   #16684
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by trf_racer
February 2007
i still have two months to save some dough for this baby
buboy28 is offline   Reply With Quote
Old 12-12-2006, 07:46 AM   #16685
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
what is the main differences of MSX MRE -->> MSXX????
nikkiesteban is offline   Reply With Quote
Old 12-12-2006, 07:56 AM   #16686
hierog's Avatar
The race-spec chassis used by Tamiya Racing Factory driver Mark Rheinhard to multiple event wins around the world is now available to the masses. Now, R/C fans worldwide can get a taste of the TRF415MSX Mark Rheinhard Edition's awesome performance at a more affordable price. Utilizing more commonly available parts for increased practicality, this chassis still remains faithful to the features of its more potent sibling and is a perfect addition to the weekend racer's arsenal.
About the Model
High-quality assembly kit chassis based on the TRF415MSX Mark Rheinhard Edition.
Equipped with Front One-Way and Center One-Way Units as standard.
Parts for the air scoop to allow for more efficient cooling are included.
A differently shaped upper deck, a lower deck with a different thickness, and steel screws are some of the features that help reduce costs while maintaining race performance.
It doesn't say if the EVO V steering is on it though
hierog is offline   Reply With Quote
Old 12-12-2006, 08:13 AM   #16687
sohlman's Avatar
Trader Rating: 89 (100%+)
From what I know its the same as MRE except:
One-way (both front & center)
Air scoop
Steel axles
Steel screws
Different shape top deck
New front bumper brace (???)
And of course no MRE branding
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-12-2006, 08:47 AM   #16688
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
I'm done...anyone interested in a 415 MSX Sedan let me know. I have two available one is a 4mm foam tire carpet chassis MSX convert and the other is a rubber tire MSX. Both in exceptional conditions as I hardly race anymore. If interested send an e-mail to [email protected]
Given a first look opportunity to die-hard Tamiya fans before posting pictures and stuff on the 4-sale thread.
Regards
Carl
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 12-12-2006, 09:04 AM   #16689
sohlman's Avatar
Regards
Carl
DON'T DO IT CARL!
I ran great this weekend on carpet...no crazy parts' mods either. Basic setup too.
Otherwise, I got first dibs.
Steve Sohl
Old 12-12-2006, 01:05 PM   #16690
chris_morrison_'s Avatar
anybody have the part # or info on the Air scoop
or know where to get it
chris_morrison_ is offline   Reply With Quote
Old 12-12-2006, 03:20 PM   #16691
Charles Godwin's Avatar
At this point in time i don't think the air scoop is available. It'll probably be available when the MSXX comes out.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-12-2006, 03:53 PM   #16692
Wing Chun's Avatar
Hi guy's
Do any of you guy's have a picture of your MSX with the Cool Can Fan on it. There is no picture on there site with the MSX.
I think Tryhard and Charles use them.
Addam
Wing Chun is offline   Reply With Quote
Old 12-13-2006, 12:12 AM   #16693
Na, i use the MuchMore Endbell Fan kit. Cheap and extremely effective . I'll try and get a pic up tonight. Here's one on the coolcan website, it's the older MS car , but you get the idea
Charles
Old 12-13-2006, 07:21 AM   #16694
TryHard's Avatar
I'm now using a Tamale mount. I found that the CCF mount can tweak the car a little after a crash, simply because of the mountings.
However the fans supplied with the CCF are the best around, albeit a little expensive.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-13-2006, 08:37 AM   #16695
kewdawg's Avatar
I am really struggling to get rear end grip. The car is oversteering lots when backing off to enter a corner. Under throttle it is very stable. The front end is planted and awesome just the rear likes to step out when I lift off the throttle. I have attached my current setup, would really appreciate it if someone can give me some tips regarding setup and how to make the rear more stable off throttle. I have tried the yellow springs on the rear and no stabilizer bar and it's even worse.
Thanks Jay.
Using spacers under the front block will decrease the amount weight being transferred, to the front, from the rear - a good thing, in dusty conditions. Reduce the front upper arm spacer to 1mm. Move front camber link to the #3 position. Reduce the front camber to -1mm. Reduce the rear droop 1 - 2mm. Reduce your rear shock oil to 30 wt.. If, your track isn't bumpy, reduce your ride height to 5mm front and rear. If, bumpy, set ride height to 6mm. Using a softer rear tire will definitely help, as long as the set up is right. These changes should lock in the rear end and keep the front end stable.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
