Tamiya TRF415
Hey Chris and Harshguy the cars look great.
Thank's Veecee
Addam.
Thank's Veecee
Addam.
Thank's Veecee
Addam.
Thank's Veecee
Addam.
Originally Posted by Nexus Racing
impressive! Your friend is a nice guy, that is probably a few hours of work .
Does anyone have the part number for the titanium axles for a 415 (I have an MRE but assuming it's the same number) ....I literally snapped a rear axle off into the whell hex at yesterdays race, wheel went left, I went into the wall
Light Weight Axles- TA-53939 (come in pairs i think), Ti Axles- TA-53718, Normal Steel Axles- TA-51094.
Charles
Charles
I finally broke a plastic outdrive for the spool yesturday,,,what a relief,I've been wanting to replace the bearings for a while and I could'nt get the out drive off after the blue sleeve was installed,,,all is good,,3 wheeled it to TQ,,,the steel out drives from the ta05 fit fine
p.s one more tip guys,,,,if youre local shop does not have the plastic blades that protect the swing shafts corrally makes the same thing
Help with Diff
Hi There Guy's
I have a big problem with my MSX diff's. I changed the front and rear pulley's to the TA05 wide pitch ones and there great. The broblem is when i put the diff's back together and raced the car the diff's are slipping. I adjusted them at the track but still slipping. I want to pull them appart today and rebuild them, can you guy's give me some advice on setting them up right please. I want so much to get the car running right. The instructions are no good in this area because all it say's is DO NOT OVERTIGHTEN. DEEERRR
Any help would be great.
How do you guy's know when the diff's are just right.
Thank's Guy's
Addam
Thank's Guy's
Addam
Hi There Guy's
Thank's Guy's
Addam
Thank's Guy's
Addam
Originally Posted by LBSR415
Did ya replace the diff balls? I tighten mine till snug and then back off 1/2 turn,,,check the diff balls first I think the 05 uses a larger ball being that the plastic is thicker in the middle of the pully,
Originally Posted by Tek Nickal
Actually this isn't true, I replaced the stock MSX pulleys to the TA05 puleys and used the same size diff balls. When you check your diff, take 2 wrenches, stick one in each outdrive, hold the wrenches, and try to turn that middle pulley. It should be really hard to almost impossible to turn.
I use the Xenon Ceramics, seem really good and fit really well in the pulley
Charles
Charles
Thank you All
Thanks So Much Guy's for your help. I have alway's used a one way and man was the car so much easier to drive with the diff in the front. The car is handling so well now and i still have a issue with keeping on the motor wires with the Orion V2, But besides that everything is great. I am so wrapped to get on here to ask advice from all you guy's. It really make racing so much better.
I hope you all have a great Christmas and god bless you all.
Regard's
Addam
Regard's
Addam
One more thing.
I went to a bearing place and bought 100 ceramic 3mm bearings for $8.00 Australian dollars. The last time I paid $11.00 from a hobby store for 10 Tamiya 3mm Ball's.
Best wishes
Addam smith
Best wishes
Addam smith
One more thing.
Best wishes
Addam smith
Best wishes
Addam smith
Cheers,
Vincent
I wouldn't mind that info either Adamm
Got to get some for my Evo & 501x
