Old 11-20-2006, 03:01 PM   #16486
robsxxxs's Avatar
i am trying to find my internal ratio on my msx stock is 2.187. i am running the black pulleys front and rear and have the wide aluminum 16 tooth in the center.
AE FT TC5
Losi 8ight B
Losi 8ight T
Losi XXX MF2
AE FT T4
Tamiya 415 MSX
Losi JRXS
Losi XXXS
robsxxxs is offline   Reply With Quote
Old 11-20-2006, 06:36 PM   #16487
29TC's Avatar
Send a message via ICQ to 29TC
kentech,
thanks a bunch.
cheers.
29TC is offline   Reply With Quote
Old 11-20-2006, 08:22 PM   #16488
tbeardmore's Avatar
Does anyone know if this TAO5 Steering block will work on the 415 MRE?
http://shopping.rcmodel.hk/product_i...oducts_id=7460
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 11-20-2006, 09:04 PM   #16489
Tek Nickal's Avatar
The internal ratio is actually the same, you didn't change anything by running the fixed pulley. The internal ratio is calculated by dividing the big pulley, by the smaller one, in this case 35/16 = 2.187
Also you can make that internal ratio change on the MSX, just run the new alternated pulleys that are for the MRE. It fits, just set the bearing holders to make the belt as loose as it can be.
Tek Nickal is offline   Reply With Quote
Old 11-20-2006, 09:13 PM   #16490
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Lightbulb RC Hard Turnbuckle Shaft Set - DF-03 3x42mm Item #53942
Is this set of HARD turnbuckle set for the DF-03 just like titanium or black steel w/ the blue alum collars? Thinking of getting this instead of the 3x42mm Ti turnbuckles (which are hard to find aside from what Lungsford has avail & 3Racing - which are out of stock on their website).
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 11-20-2006, 09:44 PM   #16491
Originally Posted by JRRobiso
I'm the same as well w/ you Ben. Just waiting for the alum airduct too. That's the only thing that's missing right now on my MRE. A week ago I tried a mock-up for the electronics to see if everything was working properly w/ the batt in it & was tempted to put my ESC & RX (Hara Twister 2.1 & Spektrum combo) w/ dbl sided tape but could not find enough contact surface for the ESC due to the small footprint of the unit. Was thinking of making an airduct myself w/ lexan (somebody has done it, I think a few pages back) but held off. I'll just wait for alum airduct instead & also thinking of installing/changing my Spektrum RX to the Micro version (which even has a smaller footprint than my ESC). Might as well find someone who carries the Titanium turnbuckets for the steering arms while I wait for the release of the airduct.
I've done a lexan airduct...But would want the alu one. In terms of strength "Aluminium VS Lexan", this is a no brainer.Wouldn't it to come a part in a hard crash sending my expensive ESC dragging on the tarmac.
Ben.C is offline   Reply With Quote
Old 11-20-2006, 11:48 PM   #16492
robsxxxs's Avatar
thanks that helps me out alot.
AE FT TC5
Losi 8ight B
Losi 8ight T
Losi XXX MF2
AE FT T4
Tamiya 415 MSX
Losi JRXS
Losi XXXS
Old 11-21-2006, 04:30 AM   #16493
kentech's Avatar
Here are a couple of more pics of the MSXX.
I noticed that it will sell for ~40000 yen in Japan which is around 6000 yen lower than the MRE.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-21-2006, 07:45 AM   #16494
tbeardmore's Avatar
Anyone......?????????????
Old 11-21-2006, 08:15 AM   #16495
TryHard's Avatar
thoose are for the std suspension, not the LWT suspension that comes with all the cars from MS onwards (MS, MSX, MRE, MSXX....)
| THard.co.uk | Xray | MuchMore |
Old 11-21-2006, 08:18 AM   #16496
sohlman's Avatar
Trader Rating: 89 (100%+)
I personally like the look of the new top deck. It gives the car a little extra character. And look how far the cut-out goes back on it...looks like lots of flex.
Steve Sohl
sohlman is offline   Reply With Quote
Old 11-21-2006, 01:36 PM   #16497
Can someone verify if the MSXX lower deck is the same as MRE? The bumper mount is new so I want to know if it uses the same lower deck. I was about to order a new MRE lower deck but when I heard about the MSXX, I need to know if I should order one now.
trf_racer is offline   Reply With Quote
Old 11-21-2006, 02:09 PM   #16498
TRF415boy's Avatar
See for yourself : save the pictures, edit them in photoshop, do a vertical flip. You now see the bottom of the car.
TRF415boy is offline   Reply With Quote
Old 11-21-2006, 04:10 PM   #16499
LBSR415's Avatar
no it is for the standard suspension,,,,you don't want to use aluminum parts they just bend or the ball studs sheer off,,,believe me i've been there
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 11-21-2006, 08:14 PM   #16500
Not very sure about whether the MSXX chassis is machined differently from the MRE. But quite sure that the quality of the MRE grahite weaving is better than the MSXX chassis.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
