Old 11-13-2006, 07:40 AM   #16396
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
correct.... will work just fine. actually, the Alternated pulleys were actually orginally listed for the TA05, anyway...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-13-2006, 08:02 AM   #16397
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Tek Nickal
No problem so did it work out for you? what changes did you make/not make?
I used a spool so I didn't change much because I didn't know how it would react. Otherwise, everything else was MRE stock except for:
Front shocks 60wt with AE yellows
Rear shocks 40wt with AE blues
No rear sway bar
4.5 ride height all around
RP30s with Paragon
AND 50 grams of weight on the rear corners (just made weight too) damn, this car is light
Steve Sohl
sohlman is offline   Reply With Quote
Old 11-13-2006, 08:12 AM   #16398
Trader Rating: 21 (100%+)
Default Whew.lol
Thanks,Made my day. Mario.
lotus1 is offline   Reply With Quote
Old 11-13-2006, 08:43 AM   #16399
someone please tell me what is the size of the besring holding the spool? thanks
ioxqq is offline   Reply With Quote
Old 11-13-2006, 12:47 PM   #16400
TryHard's Avatar
Hey guys, just thought I'd direct you lot to the new link in my sig (JAAD Racing). I have a few of their parts for the 415 on order(currently available through Precision RC), looking forward to trying them out, certainly look good.
Oh, and can anyone spell shameless plug???
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-13-2006, 07:45 PM   #16401
tbeardmore's Avatar
Hey Guys... another 415 MSX/MRE "Rookie" Question?
I see there are quite a few different suspension mounting blocks ie:
1A, 1B, 1C, 1X, 1D, 1XB ...etc.
I know they change the front/rear arm sweep/tow-in but, does anyone here have a chart or something showing what each different combination provides as far as tow angle/sweep..?
Thank You!!!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 11-13-2006, 08:00 PM   #16402
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow
Thank You!!!
Click on TryHard's link on his sig.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 11-13-2006, 08:24 PM   #16403
tbeardmore's Avatar
Thanks JR!! --- You too TryHard! That's exactly what I was looking for!
You guys ROCK!!!
Old 11-13-2006, 08:49 PM   #16404
WRXTC's Avatar
I have just got the centre pulley conversion kit from Precisionrc.
I noticed the lightweight centre shaft has nothing for a C clip, like the MSX. I take it that you don't need anything on either end holding the shaft in? Do you just add the bearings and holders on either end and just drop in? or did I miss something with the conversion? Can someone post a pic of the conversion at all? The one that precisionrc have on their website isn't clear enough for me to understand how it works.
WRXTC is offline   Reply With Quote
Old 11-13-2006, 10:56 PM   #16405
Old 11-14-2006, 01:09 AM   #16406
Eirik's Avatar
The bearing is 1510, (10x15mm)
Eirik is offline   Reply With Quote
Old 11-14-2006, 01:12 AM   #16407
maxepower's Avatar
Exclamation Getting the shaft!
The lightweight center shaft is shorter than the original with the c-clips but not long enough to go across the pully mount. The bearing holders that go on the ouside of the original shaft need to go on the inside of the pulley mount in order to reach accross. This is using the Tamiya TA05 lightweight shaft. I don't know if the precision RC one is the same but here is a picture that show what I mean, I'll try and find it and post it asap!
On my conversion!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 11-14-2006, 06:06 AM   #16408
other RC selling JAAD Racing product(spool and out drive).the price is better than precisionrc
http://www.racing11.net/shop/index.p...h=23_28_54_159
initialrays is offline   Reply With Quote
Old 11-14-2006, 02:00 PM   #16409
Hey, any suggestions on what pinion gear size to start with if I am running a Co27 stock motor? The tract is a carpet, with loks of turns. Spur gear is the stock, car is a MSX Rihienhart edition. Thanks!
Interceptor is offline   Reply With Quote
Old 11-14-2006, 02:35 PM   #16410
WRXTC's Avatar
Thumbs up Thanks Mate.
On my conversion!
I thought so, when I finally made it home I tried that prior to looking at your response and pic and it worked ok. Although the centre shaft really doesn't extend that much into the bearings it looks like it should be ok. Now I need shorter screws for my spur gear mount they extend through about 1mm past the spur gear holder where the delrin pulley is
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
