Old 11-12-2006, 05:44 PM   #16381
Tek Nickal's Avatar
Originally Posted by WRXTC
My MSX with my new GTB Brushless system Took it for a practice on the weekend and stripped a spur gear in two laps I am trying to get a ratio of around 10.0 and was using a 75 spur with a 17 pinion, tried a 16 pinion but the motor will not move back far enough to get the 16 to mesh properly. I thought 17 would be ok but obviously not. Can I get some ideas on what you people run? If I go much larger than 75 tooth spur it may pertrude from the bottom on the chassis but running a 75 tooth I cannot get a pinion to mesh that will give a 10-11 gear ratio?
Another question I have is. I have ordered the spur adaptor, centre pulley conversion kit, with the 16 tooth centre pulleys etc... Do I need to use TA-05 pulleys on my front spool and rear diff to obtain a 2.25 internal ratio?
Wait, why a ratio of 10-11? Thats really low, I even gear my stock motors around 6-7, and 19t around 5-6.
Are you using 48 pitch gears or 64 pitch? Can't tell from the picture.
Also, yes you would need to use the pulleys from the TA05 or the new alternated pulleys from the MRE to obtain the 2.25 drive ratio. With the center pulley conversion, the number of teeth on the gears stay the same, at 16t.
Tek Nickal is offline   Reply With Quote
Old 11-12-2006, 06:06 PM   #16382
WRXTC's Avatar
For the track that I race at (using the Novak BL 4.5R velocity motor) I have been advised to gear between say 9.5 and 11 to avoid any thermal issues. So I figured 10-10.5 would be my best bet. I am using 48p spurs and pinions.
WRXTC is offline   Reply With Quote
Old 11-12-2006, 07:32 PM   #16383
tbeardmore's Avatar
Need Help!
I just bought the 415MSX/MRE and see that it comes with the front spool as standard equipment. I am planning on running it indoors carpet rubber.
Question:
1) Will the spool work on Carpet?
2) I'm thinking I'll need a front diff. (Where can I get one?)
Anyone with a good Rubber/Carpet setup please let me know - Your help would be appreciated!!
Thanks!
Todd
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 11-12-2006, 08:13 PM   #16384
WRXTC's Avatar
As far as I know a spool isn't needed on carpet because of the amount of grip. A diff or a one way would be recommended imo. Front ball diff can be found here.
http://www.precisionrc.com/nv/car/pr...oduct_id=34533
Old 11-12-2006, 08:30 PM   #16385
What to know what is the part number for the MRE front bumper upper graphite plate?
ioxqq is offline   Reply With Quote
Old 11-12-2006, 08:41 PM   #16386
nordheim's Avatar
TAM4304074
Tamiya Bumper Support
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 11-12-2006, 08:44 PM   #16387
Tek Nickal's Avatar
Originally Posted by tbeardmore
Need Help!
Question:
Thanks!
Todd
http://img.photobucket.com/albums/v2...6/MSXsetup.jpg
A one-way may work, but it has too much steering.
I've found both tires to be good, if you need more rear grip try RP30s or CS27s in the front.
Edit: I used Jack the Gripper traction compound all around.
Old 11-12-2006, 08:45 PM   #16388
sohlman's Avatar
Trader Rating: 89 (100%+)
Need Help!
Question:
Thanks!
Todd
I ran 19t carpet with rubbers today and it worked OK with the spool. A one-way would probably be better. Basically stock setup with harder AE springs and heavier shock oil and it felt pretty good. I need more time with it...but it was a blast to drive.
Is there a new one-way coming out for the MRE? When?
Steve Sohl
sohlman is offline   Reply With Quote
Old 11-12-2006, 08:47 PM   #16389
sohlman's Avatar
Tek, thx 4 the setup last night.
Steve Sohl
Old 11-12-2006, 08:49 PM   #16390
Tek Nickal's Avatar
No problem so did it work out for you? what changes did you make/not make?
Old 11-12-2006, 08:53 PM   #16391
The one way will be out either somewhere this month or early Dec.
Ben.C is offline   Reply With Quote
Old 11-12-2006, 09:30 PM   #16392
tbeardmore's Avatar
Thanks WRXTC ...!
My maiden voyage will be this weds.... Can't wait to try it out! I've been running an RDX for the last 2+ years - and have been obcessing about owning on of these ever since I came back from the IIC.
Obcessive / Compulsive disorder - I think?? I guess it's part of the Hobby?
Thanks again!
Old 11-12-2006, 09:41 PM   #16393
WRXTC's Avatar
I used to run the Mi2 and when I bought the TRF415MS and added the upgrade to make it an MSX I just looked at it and dribbled like Homer Simpson when he thinks of beer. Awesome car you will not be disappointed Good luck with the first outing!!
Old 11-12-2006, 10:42 PM   #16394
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Thanks WRXTC ...!
Thanks again!
hey Todd.. if you are gonna add a diff, may as well use this:
http://www.tamiyausa.com/product/ite...oduct-id=53921
very nice, matches the rear!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-13-2006, 07:28 AM   #16395
Trader Rating: 21 (100%+)
Default I'm A hopin'
Tell me this will work....Need a front diff pulley gor the MRE.Can only find the TAO5 36 tooth pulley.It's not the wide spacing but......Work with a little friction???Thanks,Mario.
lotus1 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
