Like Tree2Likes
Tamiya TRF415
Old 11-11-2006, 09:49 AM
  #16366
Core Creations's Avatar
Trader Rating: 99 (100%+)
Any ideas on what the MSX-X will change?
Core Creations is offline
Old 11-11-2006, 10:53 AM
  #16367
sohlman's Avatar
Trader Rating: 89 (100%+)
SEEKING: A decent setup for a MRE 19t indoor carpet with rubber. I went through Try Hard's site (great resource!) and only found stuff from the beginning of the year. Anybody got something from the IIC '06? Thanks.
sohlman is offline
Old 11-11-2006, 11:58 AM
  #16368
tbeardmore's Avatar
Me too - let me know what you find?
Just got my MRE last night! Now I'm part of the "club"
tbeardmore is offline
Old 11-11-2006, 01:14 PM
  #16369
TryHard's Avatar
Originally Posted by stuey
hey ed think there is some confusion here rebound stroke is how far the shock shaft comes out of the body when pushed up droop is a measurment on how far the lower arms are aloud to lift two compleatly diffrent things for eg if you build your shocks with full rebound it doesn't adjust the droop measurment the same apllies if you build your shocks with no rebound or even suck back the measurement will still be the same but the car will react diffrent. i hope this makes sense.
are you at the wars this year bud
Aye at the wars... 19t using my Evo
I'm still pretty sure all the TRF use the rebound stroke box for their droop settings most of the time (Marc R's IIC being an exception), even if they are different things.
Ed
TryHard is offline
Old 11-11-2006, 01:24 PM
  #16370
stuey's Avatar
I'm still pretty sure all the TRF use the rebound stroke box for their droop settings, even if they are different things.
Ed
i just checked reinhards setup sheet on tamiya usa the rebound stoke is 3mm the memo (droop) 5mm im gonna have to say edd but you are wrong sorry
why are you using the evo
im booked in to 19t too cant wait racing at tonbridge tomorow got lots of new bits to try
stuey is offline
Old 11-11-2006, 01:31 PM
  #16371
TryHard's Avatar
check my post again...I'll admit I did edit it, so you probably saw it before that.
I take it your using the 415 then? which one MSX or MRE?
I'm gonna be using the Evo5 for the first round, still haven't sorted out a new chassis for the MRE yet... lack of time at work to lay-up the panels, bit of a bugger, hopefully in the next week I can get some done.
TBH, I'm actually finding it really quick in stock, nothing can keep hold on it out of the turns (simply punches out like nothing else), just a few things to try before the first round, but setup isn't far off.
Ed
TryHard is offline
Old 11-11-2006, 02:47 PM
  #16372
stuey's Avatar
Ed
oh yeah
running the msx car has been altered a lot it is very quick
stuey is offline
Old 11-11-2006, 07:06 PM
  #16373
What to know what is the part number for the MRE front bumper upper graphite plate?
ioxqq is offline
Old 11-11-2006, 10:43 PM
  #16374
Default rear shock tower
anyone know where i can buy a rear shock tower for tamayia 415 msx mre,online store that has them in stock,in the us.
imber is offline
Old 11-11-2006, 10:59 PM
  #16375
nordheim's Avatar
Sent you a pm George!
nordheim is offline
Old 11-12-2006, 06:18 AM
  #16376
hobbipro's Avatar
Trader Rating: 21 (100%+)
Anyone seen the TRF415 blowout on Tamiya USA web sight? $260 for just the kit, and $275 with a legacy body. I picked one of these up, knowing its not the newest refine kit, but when touring cars are all going to the neighborhood of $400+ this is a steal! My last high end TRF was a 414M worlds, I loved that car and regretted selling it. I've had a few high $$$ cars since then, but none were the same quality and drivability. My recent purchase of a TA05 brought my old spark back for TRF products. I really dont care if it is a 3yr old design, it still rocks!
hobbipro is offline
Old 11-12-2006, 01:22 PM
  #16377
Charles Godwin's Avatar
I'm going to be racing 19t next year and i want to make sure i've got everything ready for the new season. I usually run a Mazda6 shell but what other shells do you guys recommend, Dodge 3, Rayspeed etc? I'm going to try and get these painted up after Xmas (not to far away ). How do these shells handle compared to the Mazda 6?
Charles
Charles Godwin is offline
Old 11-12-2006, 02:17 PM
  #16378
WRXTC's Avatar
My MSX with my new GTB Brushless system Took it for a practice on the weekend and stripped a spur gear in two laps I am trying to get a ratio of around 10.0 and was using a 75 spur with a 17 pinion, tried a 16 pinion but the motor will not move back far enough to get the 16 to mesh properly. I thought 17 would be ok but obviously not. Can I get some ideas on what you people run? If I go much larger than 75 tooth spur it may pertrude from the bottom on the chassis but running a 75 tooth I cannot get a pinion to mesh that will give a 10-11 gear ratio?
Another question I have is. I have ordered the spur adaptor, centre pulley conversion kit, with the 16 tooth centre pulleys etc... Do I need to use TA-05 pulleys on my front spool and rear diff to obtain a 2.25 internal ratio?
Attached Thumbnails Tamiya TRF415-11-11-06_1340.jpg   Tamiya TRF415-11-11-06_1341.jpg
WRXTC is offline
Old 11-12-2006, 02:50 PM
  #16379
nordheim's Avatar
Charles
Ride Accord and Stratus 3.0 are 2 of the bodies I like for asphalt racing. Plenty of downforce. Mazda 6 is still my favorite.
nordheim is offline
Old 11-12-2006, 03:13 PM
  #16380
Stein Tumert's Avatar
Yes, one tooth difference from the std MSX pulleys, that is why you get 2.25 instead of 2.187....
Stein Tumert is offline
