Old 11-09-2006, 11:52 PM   #16351
Originally Posted by kewdawg
Any pics, yet?
Heard from a very good scource that the MSXX is just a 'cheaper' version of the MRE... Like no Titanium screws, those gold hinge pins/shock shaft , spool....
But it does comes with the airduct & one-way unit that we MRE owners are waiting for.....
Ben.C is offline   Reply With Quote
Old 11-09-2006, 11:58 PM   #16352
dodo's Avatar
Send a message via Yahoo to dodo
hmm sounds like it's the 'missing link' between MSX refine2 and the MRE.
dodo is offline   Reply With Quote
Old 11-10-2006, 12:03 AM   #16353
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Exclamation
When your source mentioned "airduct", you're talking about the alum piece that screws onto the bottom deck? The same piece that Mark & the rest of the TRF drivers were using at the 2006 IFMAR ISTC races?
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 11-10-2006, 12:53 AM   #16354
Tek Nickal's Avatar
Although the MSX R2 had everything, the titanium nitride coated shock shafts and hinge pins, no titanium screws though.
If Tamiya were to come out with a budget MSX/MRE it would probably have plastic diffs, nylon arms instead of graphite, ect.
Tek Nickal is offline   Reply With Quote
Old 11-10-2006, 01:21 AM   #16355
Yes....I suppose so...
Old 11-10-2006, 01:23 AM   #16356
Hi Tony,
Let me reliterate...titanium nitride coated shock shafts and hinge pins is not sure...Maybe they will put it in.Maybe not...But I sure they will.
But no Ti screws is a fact. So is the one way unit & alu airduct ....
Old 11-10-2006, 04:57 AM   #16357
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by JAY_UK
I havent ground mine down and i havent broke a belt........YET!
oh, ok maybe i'll let it be for a while or until i'll have a broken belt before i'll grind it
buboy28 is offline   Reply With Quote
Old 11-10-2006, 05:01 AM   #16358
buboy28's Avatar
Probably grinding the steering is due to the usage of larger spur gear where you need to flip over the cams to accomadate the larger spur. This probably raise the belt higher and the steering could hit it.
i'm still using the 102T spur gear, but do you think that if i use say a 100T spur gear the belts wont be touching the steering anymore
Old 11-10-2006, 06:30 AM   #16359
Charles Godwin's Avatar
Nope. Just add 0.2mm of shims where the silver shim goes under the steering system (the shim closest to the deck, or on it)
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 11-10-2006, 10:26 AM   #16360
need to loose this stupid front one way. Anyone have a parts list to install a ball dif in the front of a 415 MSX? Thanks!
Interceptor is offline   Reply With Quote
Old 11-10-2006, 11:06 AM   #16361
Stein Tumert's Avatar
Art.-Nr.: 53921
Alu Diff komplett Front
Stein Tumert is offline   Reply With Quote
Old 11-11-2006, 03:12 AM   #16362
I see ther is no downstop memtioned in 415 setting:
http://www.tamiyausa.com/articles/ln...er%20setup.pdf
Or I missed somewhere?
ioxqq is offline   Reply With Quote
Old 11-11-2006, 03:19 AM   #16363
Tek Nickal's Avatar
If your talking about droop, I think its in the memo part, 5mm front and 4mm rear. Although I don't know where on the suspension he measured it.
Old 11-11-2006, 03:26 AM   #16364
stuey's Avatar
Originally Posted by TryHard
stu.. aint' that similar to droop...
I'm pretty sure thats what most of the TRF drivers treat it as anyway... the longer measurements you see are it being measured off the top of the axle (a more accurate method, see here, David Jun Droop method )
Ed
hey ed think there is some confusion here rebound stroke is how far the shock shaft comes out of the body when pushed up droop is a measurment on how far the lower arms are aloud to lift two compleatly diffrent things for eg if you build your shocks with full rebound it doesn't adjust the droop measurment the same apllies if you build your shocks with no rebound or even suck back the measurement will still be the same but the car will react diffrent. i hope this makes sense.
are you at the wars this year bud
stuey is offline   Reply With Quote
Old 11-11-2006, 03:28 AM   #16365
stuey's Avatar
droop = memo
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
