Old 11-07-2006, 07:52 AM   #16306
hierog's Avatar
has anybody had any luck finding any 3x42 mm titanium turnbuckles? i used to buy them from Speedtech R/C, but they don't have them listed anymore. and Tamiya USA is still out of stock
vic
hierog is offline   Reply With Quote
Old 11-07-2006, 08:23 AM   #16307
TryHard's Avatar
you can order them direct from Lunsford, I think it's 1"5/8ths (same length). I ordered two sets (one for MRE, one for Evo5), and they were here witihin a few days Not bad if you ask me.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-07-2006, 08:57 AM   #16308
Johnny Wishbone's Avatar
Default MSX
Anyone know if there is a parts supplier for MSX cars in Canada? Names and numbers or links please.
Thanks,JW.
Old 11-07-2006, 09:41 AM   #16309
dbmartin's Avatar
I noticed there are no setup sheets for the mre, does anyone know if the msx setup sheets from the reedy race would transfer correctly to the setup of the mre, or do i just build the car according to the manual and that is the setup to run.
thanks
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 11-07-2006, 11:18 AM   #16310
Can anyone who races a TRF 415 MSX on indoor carpet email me a copy of their set up sheet please? [email protected]
Thanks for any help!
Interceptor is offline   Reply With Quote
Old 11-07-2006, 11:25 AM   #16311
Charles Godwin's Avatar
thanks
Probably because Numan and Marc were running the newer steering then.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 11-07-2006, 07:34 PM   #16312
WRXTC's Avatar
I was told that to run the spool I need a fixed centre pulley? As I have just received my parts order from rc_champ and it wasn't on the order is there a way I can fix my centre one way pulley temporarily until I need to order more parts? and what effect will running the centre one way pulley with a spool have?
Cheers
WRXTC is offline   Reply With Quote
Old 11-07-2006, 09:28 PM   #16313
Mason's Avatar
I have searched the thread in reference to the difference in height of the upper deck between the original 415 and the msx to no avail. Does anyone know how much lower the msx upper deck is vs the original 415??
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-07-2006, 10:07 PM   #16314
Cheers
You'll probably get lots of understeer...
Ben.C is offline   Reply With Quote
Old 11-07-2006, 10:59 PM   #16315
ljohnson's Avatar
Measuring says 34mm on the 415 and 25 mm on the MSX, so nine mm lower.
ljohnson is offline   Reply With Quote
Old 11-08-2006, 12:07 AM   #16316
For a quick fix for the centre pulley you could maybe flip the one-way around (so it spins backwards not forward), not sure if this would work but you could give it a try.
Charles
Old 11-08-2006, 12:51 AM   #16317
Charles
That could be very damaging to the one way isn't it??
Old 11-08-2006, 12:54 AM   #16318
dodo's Avatar
Send a message via Yahoo to dodo
not sure if it's damaging but basically you're accelerating with the rear wheel only. which i feel won't work the same as fixed center pulley.
if it can be done in the first place, tamiya won't come out with a center fixed pulley in the first place....
dodo is offline   Reply With Quote
Old 11-08-2006, 02:36 AM   #16319
Charles
Doing this with a spool makes out a 2WD car with 4 wheel braking.
So basically when you install the center one-way backwards you don't get any power transferred to the front wheels, except braking and reverse.
Finnitro is offline   Reply With Quote
Old 11-08-2006, 02:51 AM   #16320
maxepower's Avatar
Unhappy Carpet Madness!
Fellow racers,
I'm looking for a good set-up for carpet using rubber tires. RP's mostly.
I got a couple of tips from previous posts and saw the Mark set-up online but this is with Foam tires so I would like a complete set-up for carpet.
I have the MSX using the 3mm chassis. Come on now all you Nor Cal guys up there! You know who I'm talking about. Past TCS champions, etc. etc.
I'm hoping to get responses from back east would be nice and the U.K.!
All suggestion will be appreciated! Anybody......Anybody......Anybody!
Thanks in advance!
A loyal Tamiya racer!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
