Like Tree2Likes
Tamiya TRF415
Old 10-26-2006, 02:57 PM
  #16216
Trader Rating: 21 (100%+)
Default Thanks
Originally Posted by TryHard
Which parts are you looking at?
The LW suspension is the same as that supplied with the MRE.... except that the MRE comes with 46mm driveshafts (I believe the re-released LWS comes with 48mm), and 0deg alloy rear hubs (plastic 1deg for the LWS).
The differing part number might be the short LWS arms... they are around 1-1.5mm shorter than the std LWS... and seem to be good for carpet work.
HiH
Ed
Was curious what LWS meant...found it tho.Starting to understand "tamiya speak",in terms of parts and options. Mario.
lotus1 is offline
Old 10-26-2006, 03:24 PM
  #16217
Lightweight Suspension
trf_racer is offline
Old 10-26-2006, 04:03 PM
  #16218
maxepower: I was lived in L.A. and run my TC3 at so cal raceway. I get into A main almost everytime. But this time I get into trouble. I already using the thickest sway bar on the rear to genereate more front traction. Lee drop on front, ok I will try to decrease drop on front. I didn't really measure how much drop I have. But i think I am using not much. Anyway, will try less drop. thanks
ioxqq is offline
Old 10-26-2006, 04:27 PM
  #16219
Max-- thanks for the loan of the Li-po charger @ the 24hr Enduro. I returned the favor and sent some stuff down to Chris for the Tamiya event.
Iox-sounds like you are working in the right direction. Max's suggestion works well I would try moving the front suspension link also. I think somewhere in there without seeing your full setup you are losing mechanical grip. that is causing the imbalance.
Difuser is offline
Old 10-27-2006, 10:56 AM
  #16220
maxepower's Avatar
Talking Enduro SIR....Enduro So.Cal.
Hey,
Anytime my friend. So how did the 24 hour Enduro turn out? Did you
break the record? So what was the tire and insert of choice. What tires lasted the longest and for how long did they last. Sorry if there was a thread on all this but I never saw one!
Any info would be great being that our Enduro is tomorrow!
Thanks!
Max
maxepower is offline
Old 10-27-2006, 11:03 AM
  #16221
tamiyarcracer's Avatar
Originally Posted by maxepower
Hey,
Thanks!
Max
Under the regional forums, northwest racers. there is a thread.
WE ran the Speedmind, premount Sorex 36R
the tires had plenty of life left when we took them off the car, the issue was that the tire was seperating from the wheel after about 1.5 hours.
The record was set. There was no previous record.
What other info are you looking for??
We ran a Novak Brushless 8.5 in a TA05.
What chassis will you be running.
tamiyarcracer is offline
Old 10-27-2006, 12:20 PM
  #16222
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hey,
Thanks!
Max
max..swing by the pit tomorrow. you'll see the tires Dan, Troy and the SIR guys used. i also have your charger. they look practically brand new.
Hebiki is offline
Old 10-27-2006, 12:25 PM
  #16223
JayBee's Avatar
Trader Rating: 31 (100%+)
Does the 'short' LWR suspension arms work on the MRE? If so, how will the handling be affected?
JayBee is offline
Old 10-27-2006, 01:08 PM
  #16224
Yes the fit Jaybee.
Old 10-27-2006, 02:40 PM
  #16225
JayBee's Avatar
Originally Posted by tamiyarcracer
Yes the fit Jaybee.
...and the 2nd question?
JayBee is offline
Old 10-27-2006, 03:04 PM
  #16226
Korey Harbke's Avatar
Shorter arms will make the car more reactive overall.
Korey Harbke is offline
Old 10-27-2006, 03:51 PM
  #16227
Hebiki's Avatar
jaybee.. what the sushi boy said man you better be ready come TCS... im coming for ya
Hebiki is offline
Old 10-27-2006, 07:10 PM
  #16228
maxepower's Avatar
Talking RE: Enduro
I thought there was a previous record set for 24 hours in the Ginneasse book for an RC car. So many miles did you all turn in 24!
I'll look for the thread when I get a chance!
Max
Old 10-28-2006, 02:39 AM
  #16229
JayBee's Avatar
Sushi Boy- THANX!!
Hebiki- THANX too but Dude you're in for a SHOWDOWN!! Can't wait to see ya up here
JayBee is offline
Old 10-28-2006, 10:03 AM
  #16230
If I remembwr correct it was 340mi or something like that. I had way too much time on the drivers stand.....
I know it is another chassis but the TA05 held up wonderfully. We lost 2 rear belts only because we did not have quite enogh belt tension 3 clicks minimum with the brushless. We also lost 1 shock tower all in 24hrs......
Good luck today sorry for the tardy reply. I was out of the office all day yesterday.
Difuser is offline
