Old 10-23-2006, 04:08 PM   #16171
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by WRXTC
Thanks mate.
just make sure you set up the servo horn, so that when the wheels are straight, the servo horn is 90 degs to the steering linkage. You dont want the servo horn straight up when the wheels are straight.
Im so unbeleiveably happy with the MRE on carpet. Im still using the std suspension, and its dialled. with old batts and an old motor, i was able to rip of some really quick laps. Seems to work better with my slight changes. Who said the MRE wouldnt be good for carpet.... you have a nice set of LWS ready for asphalt, and with a few cheap std suspension parts (couldnt even buy an old TA04 of ebay if your keen) and your set for carpet. you can notice flex in the chassis when pushed, but for all intensive purposes, im hooked. Love this car.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-23-2006, 04:28 PM   #16172
TRF415boy's Avatar
Originally Posted by Sean T Guy
If I was to use the new short wishbones (53928) would it be better to change the blocks as to regain track width? If so what blocks would work on the MRE , Thank you to anybody who can advise.
Originally Posted by LBSR415
you would want to use the larger blocks in a combination to restore your toe in or out,,,for example,,,,,,,with the long suspension you could use an A block and a B block to achieve 1 degree of toe,,,with the short arms you could us a d and and e to maintain track width,,,,,,,you may have to switch to 42mm driveshafts
I run my car with the short wishbones and the standard MRE blocks (B-A on front and XB-D on the rear) without any problem. Track width is on the low side (183mm on the rear) but there's not much you can do about that apart from going to 6mm hexes and using shims, going for the E block instead of the D will only make 1mm difference in total...
By the way LBSR415 you have it wrong, it's only half a degree of toe between blocks, so having A-B is 0.5 toe and not 1 as you wrote.
46mm driveshafts are fine too by the way, they go deep in the diff halves but still fine, however if going for a narrower track you might have to go for the old style 42mm driveshafts.
I'm using the car with the short arms on carpet and loving it. It's not a MRE so my setup won't help you but I would think if you reduce the ackermann you could use a similar setup to mine. Those arms have finally got me round to using my MSX on carpet rather than my standard 415...
TRF415boy is offline   Reply With Quote
Old 10-23-2006, 05:08 PM   #16173
Burlap's Avatar
Send a message via MSN to Burlap
One thing I did notice with the short EVO V arms and the standard MSX with the front one way, is that the 46mm driveshafts are too long, you have to go to 42mm.
Burlap is offline   Reply With Quote
Old 10-23-2006, 05:12 PM   #16174
TRF415boy's Avatar
I would think so if you're using the standard MSX blocks B-XB
Old 10-23-2006, 05:22 PM   #16175
TRF415boy's Avatar
By the way for those interested, here's my top 5 updates to get a MSX to handle properly on carpet with rubber tyres:
SHORT LW wishbones
HPI front hubs
Tech Racing top deck
4mm chassis
hpi rear hubs (purely for the bigger bearings though)
After putting the first 2 (in order) the car started handling right. After putting the Tech top deck the car started handling real good (note 2 top decks one of top of each other might do the trick, but I'd be worried about tweak issues).
The 4mm chassis is mainly because I'm going to go to some high grip carpet track and want to make sure my car's not gonna suffer from being too soft (one of the main problems with the MSX on carpet IMHO).
With the MRE i wouldn't think the HPI front hubs would be necessary as the new steering allows you to modify the ackermann (and frankly the stock setting has way too much ackermann by the way), whereas the MSX has very little ackermann and the hpi hubs provide slightly more.
By the way I've been told Marc used a MS with the 4mm chassis at Vegas.
Old 10-23-2006, 09:48 PM   #16176
WRXTC's Avatar
Originally Posted by axle182
just make sure you set up the servo horn, so that when the wheels are straight, the servo horn is 90 degs to the steering linkage. You dont want the servo horn straight up when the wheels are straight..
I just put it together and set it up as per the manual and it works fine just looked a little off!
WRXTC is offline   Reply With Quote
Old 10-24-2006, 12:00 AM   #16177
badboy's Avatar
Trader Rating: 14 (100%+)
what parts do i need to build a front one-way for the MRE? thanks!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 10-24-2006, 12:56 AM   #16178
Or you can wait for the one way to be release sometime next month....
Ben.C is offline   Reply With Quote
Old 10-24-2006, 01:07 AM   #16179
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Tamiya will be releasing a front one-way for the MRE but if you cannot wait try the following parts:
MRE front pulley
415 front one way housing - TAM 1059
415 LW one-way drive cup - TAM 3704
plus the bearing
buboy28 is offline   Reply With Quote
Old 10-24-2006, 04:02 AM   #16180
Does Tamiya makes a better sway bar mount for the MRE? The stock one has too much slop.
ioxqq is offline   Reply With Quote
Old 10-24-2006, 05:31 AM   #16181
LBSR415's Avatar
same as trf 415 msx,,,,tao5 works too just got to cut them down a bit,,,,,
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 10-24-2006, 07:29 AM   #16182
veecee's Avatar
Trader Rating: 34 (100%+)
MRE front pulley
plus the bearing
One way housing for the MRE will be shipping late Nov according Tamiya Japan website - part #:53947. Time to buy an MRE...
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 10-24-2006, 08:03 AM   #16183
buboy28's Avatar
oh, ok thanks for the update although we are also located in Asia our LHS sometimes get these parts a little bit late
Old 10-24-2006, 09:24 AM   #16184
Charles Godwin's Avatar
Good that a proper one-way for the MRE is coming out soon but, when is the air duct coming out?
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-24-2006, 09:32 AM   #16185
I need the oneway!
I'm running the MRE and I see the car is big push and lots of steering getting out of concer. I think this is mainly due to the front solid diff. I have tried about everything. eg, change roll center, 2 deg caster, front toe out, added front kick up, higher rear ride height 6mm R and 4.5 F, F & R white springs, auto break, smaller spoiler, min. rear drop, blue (thickest)sway bar on rear and med (stock) sway bar on front, .... car still push. I'm going to put a harder spring on rear AE red while maintain white on front. I'm sure this will help a lot. What is your recommendation, what else should I try?? PS, I'm new for front solid diff.Thanks
BTW, I always like put a harder spring on rear to give me faster direction change and more sterering over all. But how come I see most people use Front harder and Rear softer? I just can't set my car right if I use rear softer and harder on front. This has been my experience since TC3. I'm sure if your car is not lose then harder on rear is always faster setup. How come this is not seems right statement for everyone?? Is people lazy to try something new or my car setup is rare?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
