Old 10-07-2006, 05:40 PM   #15961
Tsquare's Avatar
Originally Posted by CarKing
For medium traction outdoor asphalt, what kind of tires are you guys running? I am looking at the RP tires, but don't know what tires are for what.
If outside temp is 85 degrees or lower, RP30's, if over 85 degrees, RP 36's or Sorex 36's
Tsquare is offline   Reply With Quote
Old 10-07-2006, 08:18 PM   #15962
Default MRE Aluminum Upper Brace
Does anyone know where I can get the Aluminum Upper Brace for the TRF415 MRE that works with the new center layshaft bearing holders? That is the last item I need to complete the conversion of the drivetrain.
Part# 3454404
R/C Champ was out of stock and says it is sold out for a while as of 7-10 days ago.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-07-2006, 08:49 PM   #15963
SpeedDesignz's Avatar
Send a message via AIM to SpeedDesignz
Are more MRE msx's going to be produced or was the last batch the final run of the car ?
NYC Hobbies / Eurotek motorsports / SpeedDesignz / BackBreaker Racing !!
SpeedDesignz is offline   Reply With Quote
Old 10-07-2006, 08:53 PM   #15964
Trader Rating: 21 (100%+)
Default MRE
Got one.Thanks to Doug(tamiyarcracer) at seattle indoor raceway.He saw my plight and stepped in.Great guy/service.Looking forward to running it.Beware of some possible "dumb" questions as I build it.lol.Mario.
lotus1 is offline   Reply With Quote
Old 10-08-2006, 01:31 AM   #15965
Tek Nickal's Avatar
What parts do I need to fit the TA05 center pulleys onto the MSX?
Tek Nickal is offline   Reply With Quote
Old 10-08-2006, 10:58 AM   #15966
I just got my TRF MSX MSE. I need to get spur and pinion gears for it (64 pitch). Which ones should I go for to cover the most used range of gear ratios? What biggest+smallest spur & pinion gears to buy? Probably I am going for kawada, is it advisable?
halayli is offline   Reply With Quote
Old 10-08-2006, 12:43 PM   #15967
Charles Godwin's Avatar
Got back from the first carpet race of the championship and the MRE feels amazing in stock rubber. It feels a lot more flatter through out the corner, more responsive but at the same time safe to drive. All i changed was to put 0.2mm shim under the front suspension mount (1B i think is the mount). I used the corally jack the gripper additive (tc-4 stuff, specially made for rubbers on carpet apparently) and left it on for 5mins (front tyres 0.5 covered) then 55*C on the tyre temps. Through out the day i used the proto mazda 6, was thinking about changing to a Ride Honda (type A) Accord for some more mid-exit steering but by about the 3rd round of quali the car was fine.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-08-2006, 02:18 PM   #15968
stuey's Avatar
just bye the mre one from precion rc
stuey is offline   Reply With Quote
Old 10-08-2006, 02:30 PM   #15969
Stein Tumert's Avatar
Have a look at post 13606 in this thread...
http://www.rctech.net/forum/showpost...ostcount=13606
Stein
Stein Tumert is offline   Reply With Quote
Old 10-08-2006, 06:10 PM   #15970
Lotus, small clarification, Troy=tamiyarcracer (2006 Mini nat'l champ)
Doug=rchoudini-- SIR shop owner
Both great guys. Enjoy the chassis.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-08-2006, 07:12 PM   #15971
Tek Nickal's Avatar
Stein
I totaled the price for the parts....and it comes out to $60+ dollars. Pretty expensive if you ask me. The locked center pulley is much cheaper, even though it may not work as well.
Old 10-08-2006, 07:22 PM   #15972
Please can someone help me here?
Old 10-08-2006, 07:41 PM   #15973
What kind of motor are you planning on running?? If you're going to run those single turn motors, you're ok with the 102 spur that comes with the MRE. Pinon wise, get a range from 20-30 teeth for starters. That could cover you well.
Ben.C is offline   Reply With Quote
Old 10-08-2006, 07:56 PM   #15974
I have the 10x1 revolution motor.
These are the ones I ordered as their combination covers a wide range of ratios.
Spur gear, 64 pitch
Kawada, 100T,101T, 102T, 103T,104T
Pinion gear, 64 pitch
Kawada, 27T,28T,29T,30T,31T,32T
Old 10-08-2006, 08:04 PM   #15975
Spur gear, 64 pitch
The 10X1 V2 is a good motor to start with. Kawada makes very top notch gears.Good choice.
I'll say start with a ratio of 8.5,which can be done using 102/27. Then if you're not happy with the top speed, you can either go up on the pinon or go lower on the spur.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
