Like Tree3Likes
Tamiya TRF415
Old 09-17-2006, 11:06 AM
  #15691
HarshGuy's Avatar
Originally Posted by Eirik
I tested with both D-D blocks up front and B-A and ended up running the later as it gave me more steering! (used 6mm hexes)
In the rear I used the stock D-XB.....
The long arms runs too tight on carpet (stops in the corners) The short arms makes the car allot freer and it steers better, even when it slides
I have even been running the short arms outdoors lately, FASTER!!
I 3rd that ...on carpet rubber anyways, was using the regular long arm on asphalt ...never tried the short arms.
HarshGuy is offline
Old 09-17-2006, 12:39 PM
  #15692
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by TRF415boy
yep, 2 degrees rear toe in total, well enough for 19T...
was going to put 1mm shims under pivot blocks to raise the roll centre (to act faster)
but then i remembered i have the evo 4 blocks here so i`m using them instead
2.5 rear toe in & -5 degree toe out i`m trying ,i should be in the evo 5 thread but i`m talking to you now ,so here i`m am
MR JOLLY is offline
Old 09-17-2006, 02:02 PM
  #15693
Charles Godwin's Avatar
Cheers people, when i get some more 'moneys' i might give the short arms a try ,also is there anything i should watch out for in the MRE build.
Cheers, Charles
Charles Godwin is offline
Old 09-17-2006, 03:28 PM
  #15694
Tek Nickal's Avatar
Which suspension blocks do you use to run the short arms? All numbers for the blocks get confusing.
Tek Nickal is offline
Old 09-17-2006, 04:06 PM
  #15695
Ok I don't know if anyone has asked this but here goes on marc's vegas setup he has a 2.2mm swaybar on the front what brand is this or did he make it himself.
al jones is offline
Old 09-17-2006, 05:19 PM
  #15696
TRF415boy's Avatar
what car is this for ?
TRF415boy is offline
Old 09-17-2006, 09:27 PM
  #15697
Jimmy Jacobson's Avatar
2.2mm Sway bar was a prototype and has never been made production. You can make you own. Good Luck with that
Jimmy Jacobson is offline
Old 09-17-2006, 09:31 PM
  #15698
Randy Just get somes spares from your roomate LOL I heard David Jun may drive out Tuesday to give you clowns a hand, since he knows alot about foam tires LOL
Old 09-17-2006, 11:05 PM
  #15699
rtypec's Avatar
Originally Posted by Jimmy Jacobson
Randy Just get somes spares from your roomate LOL I heard Flywheel may drive out Tuesday to give you clowns a hand, since he knows alot about foam tires LOL
And when you ask for parts, you ALWAYS ask for "New-Type"
As for me...I get to run "Old-Type"
I just loaded my new ipod with some junk so I can be anti-social in Vegas! J/K...if anybody needs help, please introduce yourself. I promise that I am usually not as busy as I look.
rtypec is offline
Old 09-17-2006, 11:29 PM
  #15700
MR JOLLY's Avatar
Evo 5
MR JOLLY is offline
Old 09-18-2006, 12:26 AM
  #15701
Wing Chun's Avatar
Default Please, I need the best shop for 415 parts URGENT
Hi Guy's
I really need your help fast I need several parts for my 415 MS and some square parts.
Does anyone know a shop that sends fast to australia and must take Pay pal
I need aftermarket Bumper and suspension arms number Tamiya 51104 Plus some suspension mounts
PLEASE PLEASE HELP
Thanks Addam
Wing Chun is offline
Old 09-18-2006, 12:34 AM
  #15702
Originally Posted by TRFMAD
Hi Guy's
PLEASE PLEASE HELP
Thanks Addam
You may try RC Champ. They are from Japan and have very swift service.
Drop them a mail: [email protected]
Ben.C is offline
Old 09-18-2006, 12:53 AM
  #15703
Eirik's Avatar
I use the Stock MSX MRE blocks for the short arms, just widen the car out by 1.0mm shim on the hex front and rear.
The blocks are 1B - 1A in the front and 1XB - 1D in the rear....
Eirik is offline
Old 09-18-2006, 01:22 AM
  #15704
Wing Chun's Avatar
Default Thanks Mate
Thank you for your prompt help Ben.C
Addam
Old 09-18-2006, 01:34 AM
  #15705
Addam
Your welcome... I guess Japan will be fast. Since they are in our Asia Pac region.
Ben.C is offline
