Old 09-13-2006, 01:36 AM   #15646
TryHard's Avatar
Originally Posted by drew85
I know its a old post but...why would you have to use the old style pully? are they diffrent sizes? I mean the finial drive is still going to be 2.5?
You don't have to use the old pulleys for the diff, just either take some material off the pulley or bearing holder.
For the centre, if you want to run dual 1-ways (front and centre) you do need to use the old style layshaft with the seperate pulleys etc, simply beacuse the TA05 one wont work, as the belts are in the wrong position (ie, you would have the oneway on the Rear belt, instead of the front).
Regardless, the ratio would still be 2.25, as the centre pulley size hasn't changed. The ratio has only changed as the diff pulleys are 1 tooth larger.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-13-2006, 03:25 AM   #15647
With aliitle luck i should get my hands on a TRF415 MR edition in a weeks or so time, about time i upgraded from my old and tired standard 415 .
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 09-13-2006, 10:25 AM   #15648
Hey everyone. So, my first experience with new 415 MRE in carpet was awsome.
Here in Finland ( me inc.) some drivers decided to switch the new Tamiya415 and i think nobody are`t disappointed
Car looks good and feel fast
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 09-13-2006, 01:01 PM   #15649
kentech's Avatar
Arrow MSX MR building tips
Just to let everyone interested in the MSX MR know i have written some detailed building tips with lots of photos on my blog.
I'll be adding some more tips and info in the future once I work more on the car and start running again when the indoor season starts.
Check it out and let me know if you have any comments.
http://kentech.blogs.se
I have added the photos to an album as well:
http://www.blogs.se/srv/media/media_...lbum_ID=105010
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 09-13-2006, 02:55 PM   #15650
Mi2_Tastic's Avatar
Default Couple of questions
Just wanted to know where the UK 415 racers source their spares from, Also what make of turnbuckles are you guys using, having never broken a turnbuckle ever I broke 2 this weekend and I want to replace them for something a little stronger.
Many thanks in advance for your help.
Mi2_Tastic is offline   Reply With Quote
Old 09-13-2006, 02:58 PM   #15651
Charles Godwin's Avatar
RcChamp is where i get my spares etc from and i use titanium turnbukles from 3racing (i think), but the tamiya ti turnbukles are fine.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 09-13-2006, 06:03 PM   #15652
Marty Peterson's Avatar
R/C Tech Charter Subscriber
Yep that is where I am getting my parts as well and they have Great Prices as well.
Here for the fun of it!
Selling HPI F10 Front Knuckles and Complete Rear Axles W/Diffs Ball and Gear.
W/12mm TC Hubs & W/14mm F1 Hubs Good for std bearing Pans cars. STD Bearings!
eBay item number: 200947192161,200947193175,200947187493
Marty Peterson is offline   Reply With Quote
Old 09-13-2006, 06:51 PM   #15653
maxepower's Avatar
Another spool?
I bought the new wide pitch pulley for the one-way and tried to bolt it to the Tamiya spool and the holes don't line up. Is the MRE spool different from the original? How can I make it work without buying the MRE spool? What's the deal?
Am I missing something?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-13-2006, 07:43 PM   #15654
dodo's Avatar
Send a message via Yahoo to dodo
2 possibilities:
- the wide pitch pulley that you bought might be intended for TA05.
- the spool is different (which i doubt, can anyone confirm?)
dodo is offline   Reply With Quote
Old 09-13-2006, 07:51 PM   #15655
Originally Posted by dodo
2 possibilities:
The wide pitched pulley is intended for TA05 and the MRE. And yes the MRE spool is a liitle different from the MSX's one in terms of dimensions...
Ben.C is offline   Reply With Quote
Old 09-13-2006, 08:10 PM   #15656
Tam
where did you guys buy your rheinard editions from??
Tam is offline   Reply With Quote
Old 09-13-2006, 08:19 PM   #15657
dodo's Avatar
i see... thanks, Ben
in that case if using MSX spool then we need to do some work on the holes...
Old 09-13-2006, 08:28 PM   #15658
In order to use the pulley, you must remove some material from the pulley or the bearing holder,so you can fit into the MSX...
As for fitting the pulley onto the spool, just try some force...The screws will thread the pulley holes somewhat.
Old 09-14-2006, 03:38 PM   #15659
ok I know it has already been posted but could someone please give me a foam tire carpet setup for the msx, Second question what is my gearing for stock 64p co2.
al jones is offline   Reply With Quote
Old 09-14-2006, 04:05 PM   #15660
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Best bet is to use a small round hobby file and elongate the holes, otherwise you could either snap a screw or crossthread the spool. I was worried mine would be out of round, but take a little material off each of the three holes slowly and when you can just get the screws in, your set. Mine is perfectly centred on both cars.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
