Tamiya TRF415
Originally Posted by TryHard
Yes you can, you just need to have the belts tensioner set looser. I'm pretty sure the main difference between the two is just the tooth count.
I'm still not sure there is a pitch difference between the belts, I need to have a close look at two new belts to tell. IF there is any difference, it's minscule. Put it this way, I ran a spare white MSX belt on my MRE the past weekend (after the front belt snapped), and it was fine. Just have to set the tensioners looser.
HiH
Ed
HiH
Ed
Originally Posted by xtrememadness
will the front ball diff outdrives for the msx work with the new pulleys on the mre. thanx
it should work as long as the 53935 pulley is used. the rear outdrives are from the msx and they are the same size. i guess we will find out when its all together. i run my msx on carpet with foams and 4mm chassis and i want to try the pulleys.
i want to try mark reinhards carpet foam setup from vegas. on the setup sheet it says he used a 2.2mm front sway bar. the thickest in the set is the blue sway bar and it measures 1.6mm. does anyone know which one he used or if one will fit from maybe another car. just want to try it. thanx.
TiR 415MSX Spool
Where can I get the TiR (Titanium Racing) spool? The only place I can find is the TiR website, and thats not US based.
Besides the tamiya steering knuckle, what other knuckles from other cars work with the msx? I know that the HPI pro 4 works but how is it better than the stock one? Thanks for your help
Eric
Eric
Originally Posted by maxepower
TryHard,
Is it true the new belts for the MRE are one tooth longer than the MSX. Plus, I heard the teeth on the pully are a new design.
Again,
Again,
The pulley only has 18t on it.... it's still classed as a 36t though, as every other tooth has been removed.
I'm still not convinced the pitches are different on the belts either.
you can get a TIR spool in usa from Team almighty
www. teamalmighty.co.uk
we have a usa store too
thanks jimmy m
thanks jimmy m
Look up Schumacher USA or PM Adrian Martinez from Schumacher. They're the US distributors for TiR.
Leonard.
The new belts are longer, simply to fit better with the larger pulley.
does it work anyway? obviously... but i do remember Rod C. mentioning something about the pulley conversion, and he is a TRF USA driver.
here is the quote from Rod...
For those doing the TA05 pulley conversion...keep in mind that the tooth design on the belts/pullies you see in pictures are different to the ones that are used with the standard 415. I'm waiting for the "open bag, install parts" conversion sans dremel or any other modification
vic
My comment was on the belt tooth design...but then again, that too may have been changed from prototype to production. In any event, I'll be running the prototype belts on my production pulleys this weekend
yes, the MRE pulley WILL work with the new front ball diff, remember you are using a rear MRE ball diff pulley not the MRE front one-way/spool pulley...also remember you need 9 balls, hehe
Hi
I wanted to know where i can get the TRF 415 MSX rheinard edition - with a Novak 3.5R brushless system + servos + accessories + Batts
Checked speedtech they are out of stock....
Any good sites who can accept cr.cards and send all this quickly.. I need to setup and take up a race with this guy who kinda ! gettin to me now !
Thanks guys in advance....
Regards
Ziizo
Regards
Ziizo
