Old 09-07-2006, 08:42 AM   #15586
Eirik's Avatar
It's 1.0mm
Eirik is offline   Reply With Quote
Old 09-07-2006, 10:02 AM   #15587
thank you Eirik
benoitrdv is offline   Reply With Quote
Old 09-07-2006, 11:21 AM   #15588
maxepower's Avatar
Switch pullys!
Can anybody give me a parts list of everything I will need to convert my MSX pullys to the white delrin TA05 pullys, including the center pully. Or do I have to wait for Tamiya to start selling spare parts for the MRE?
Thanks in advance!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-07-2006, 11:28 AM   #15589
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Thats an easy one. Your looking for just the pulleys. If your looking for the MRE centre, i think youd be better off waiting for the MRE all in one alloy centre setup. Very light weight and looks awesome. Just a quick look between my MSX and MRE and looks like it should be a direct swap. You can get the TA05 centre setup if you need it now tho. I dont think Tamiya has released the centre alloy mount as a hopup yet. I know they have both the one way and the ball diff MRE pulleys (which are different to the TA05 pulleys) I love the dirt cover on the MRE diff pulley too!
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 09-07-2006, 11:52 AM   #15590
JayL's Avatar
for the MRE part#'s check the pdf Harshguy posted a few pages back..
You can run the MRE center shaft and pulleys and front and rear pulleys on the MSX ..I ran them fine on mine with the stock white belts..It def works better than the conversion center from the ta-05 we used to run...
JayL is offline   Reply With Quote
Old 09-07-2006, 11:59 AM   #15591
maxepower's Avatar
RE: PULLY CONV>
JayL>Tamiya is already selling parts for the MRE?
axle> What diff covers? Tamiya has diff covers or is it
an aftermarket part your referring to?
Old 09-07-2006, 12:15 PM   #15592
TryHard's Avatar
The Rear diff pulley has a lip on it that is very close to the outdrives, effectively covering the diff plates and balls. Also it use 9 3mm balls verus the 8 of the 05 or MSX...
Champ has parts for the MRE in stock already.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-07-2006, 12:20 PM   #15593
maxepower's Avatar
Part#s
HiH
Ed
TryHard> you wouldn't happen to have a PDF file on your website for MRE parts?
That way I can e-mail RC champ with part#s of what I need.
Old 09-07-2006, 12:36 PM   #15594
axle182's Avatar
HiH
Ed
I didnt even notice it took 9! i was rushed putting it together so i assumed i must have lost one as they always come in a pack of 10! Good to know. Well new order of MRE pulleys, new suspension parts etc, should have enough spares to last the winter for the MSX and MRE. Felt weird building the MRE with old std suspension...... looked so much nicer with the new LWS on it, but itll be running carpet Looking forward to really identifying the handling differences between the MRE and MSX
Aaron "AJ" Freind
Old 09-07-2006, 01:01 PM   #15595
TryHard's Avatar
Parts for the centre pulley;
TAM3454395 Direct centre shaft )one piece layshaft/mount)
TAM9804263 Aluminium Bearing Holder
TAM51213 16t plastic pulley x2
TAM50589 5mm E-Ring Clip
Parts for Rear Diff
TAM53935 Ball Diff Pulley (36t or 18t pulley, which way you look at it)
(all other parts as per MSX, bar 9 diff balls)
Parts for Front Axle
TAM53936 Front One Way Pulley (36t or 18t pulley, which way you look at it)
TAM3454401 Direct Holder (Front Spool)
TAM9804268 Direct Cup (Delrin drive Cup)
TAM9804267 Direct Coupling (Alu Drive cup sleave)
HiH
Ed
Old 09-07-2006, 01:13 PM   #15596
axle182's Avatar
Ed, are you sure that the alloy bearing holders for the centre will work on an MSX? I think you will need the new centre top plate, as it isnt flat, it takes the new bearing holders. I was going to look into these parts also when the MRE has been around a little longer, so i can update my MSX a little.
Aaron "AJ" Freind
Old 09-07-2006, 02:38 PM   #15597
TryHard's Avatar
Quite correct... apologies.
IF you don't want to get the new top deck, you just need to reverse the position of the other current bearing holders, making the bearings face inwards.
HiH
Ed
Old 09-07-2006, 07:42 PM   #15598
maxepower's Avatar
RE:Pully conversion
Parts for Rear Diff
HiH
Ed
TryHard,
Is it true the new belts for the MRE are one tooth longer than the MSX. Plus, I heard the teeth on the pully are a new design.
Again,
Old 09-07-2006, 08:04 PM   #15599
xtrememadness's Avatar
Send a message via AIM to xtrememadness
will the front ball diff outdrives for the msx work with the new pulleys on the mre. thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 09-07-2006, 08:10 PM   #15600
maxepower's Avatar
RE:Pully conversion
I was just thinking the same thing! I bought the front diff outdrive kit, but it doesn't come with the pully. I haven't bought the pullys yet but I would imagine so!
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
