Old 03-30-2004, 12:10 PM   #1546
Hebiki's Avatar
Trader Rating: 26 (100%+)
jeff!!!
dont you have all those beautiful tracks in asia? btw how did you do at TCS with the mini? see u soon dude! summer parking lot racing season is in full swing here. the TRF415 will get lots of exercise with the 19T class in full race mode! at least 4 heats at every parking lot race
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-30-2004, 01:06 PM   #1547
Martin Crisp's Avatar
Default Fixed Diff - Foam Tire
Hi,
I just got back from the ROAR carpet nats (foam tire) race where I brought both the evo and the 415. I did terrible but it was a good test session for the 415 on foam. I made a front diff from HPI Pro2 outdrives and it worked well. I also made a fixed center pully, based on some ideas from Dan and Troy.
To make the center pully you need two set screw based pullys. you will need to sand down the alloy spur adapter so that the side that would normally butt up against the center one-way, is sanded down so that the alloy is flush with the spur gear. This provides the required room on the shaft to accomodate the set screw based pully. You will also need to sand down a flat spot on the pully shaft so that the set screw on the new pully has a point to grab onto. It fits perfectly.
I did find however that with the center pully locked and the front diff on the car, that the car tended to hop under acceleration. This hopping was reduced by running the center one-way with the front diff. In the end I think this hopping was caused by the front diff creating a vibration.
The mistake I made at the race was splitting the limited practice time and the qualifiers between the two cars, so I did not maximize the setup on either car. Having said that, the 415 on average was 3 tenths quicker per lap then the evo. I think this is mainly due to the stiffer chassis. My car had a huge push in the main so I was about 4 tenths a lap slower in my main than during my qualifiers. oh well.
My Setup for the 415 was as follows. It worked well with 57 to 58mm tires. But in the main I ran a 55mm tire which is why I think it pushed so much. D'oh!
Front:
Springs : Assoc Purple
Anti-dive : about neg 3 degrees (spacers under rear hinge pin block)
Caster : 8 degree caster -> producing about 5 degrees with the anti-dive.
Sway bar : blue
Shock position : outer hole on arm and shock tower.
uptravel : betwen 0.5 and 1.0 mm
Tire : Speedmind Multi-Compound (52/35) (28 mm wide, cut to 57.5mm). Glued outer verticle edge.
Ackerman : forward hole on steering knuckle
Upper Links : stock spacers on upper deck. Used outer hole in the c-hub (Cut off the verticle tab)...to allow for a longer upper link.
Front hinge pin block : D block
Rear hinge pin block : A block
Rear:
Shock Position : Outer hole on arm and shock tower
Sway bar : none
Anti-squat : a .07 mm spacer under the front hinge pin block
Tire : Speedmind 35 (28mm wide, cut to 57.5mm). Glued outer verticle edge.
Rear Upright : 1 degree alloy.
Upper Links : Stock spacers on upper deck. Inner most hole on the rear upright (ie. short rear link).
Martin Crisp
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 03-30-2004, 01:33 PM   #1548
over gear's Avatar
Trader Rating: 15 (100%+)
Martin Crisp: please check your PM
over gear is offline   Reply With Quote
Old 03-30-2004, 05:20 PM   #1549
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by Hebiki
jeff!!!
Dude, I haven't even driven anything since I left! I've been busy at work and the beautiful tracks are no good when raining!!! The TCS is not until 4/25 so I haven't even built my car but got some tips from difuser and am looking forward to it.
SoCal is still the best!
jeffreylin is offline   Reply With Quote
Old 03-30-2004, 08:40 PM   #1550
racer's Avatar
Kai has a preview of their new light weight chassis for the TRF415. it's on their main webpage.
here the link:
Kmodels
they also mention something 6mm??? not sure what is it.
my appologizes if this has already been posted.
racer is offline   Reply With Quote
Old 03-30-2004, 09:23 PM   #1551
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default 415 set up sheet
Can someone please post a link for a blank setup sheet in pdf, also from top racers.
Izzy
izzyracer is offline   Reply With Quote
Old 03-30-2004, 09:37 PM   #1552
JimmyMac's Avatar
http://www.tamiya.com/japan/products...f415/index.htm
Scroll to the middle. There are 3 files. The last one is the Blank sheet.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-31-2004, 08:53 AM   #1553
izzyracer's Avatar
Thank you!
Izzy
Old 03-31-2004, 12:50 PM   #1554
Hebiki's Avatar
yah i saw that too..
lightweight chassis.. 6mm? and 35g?
Hebiki Design Works
Old 03-31-2004, 03:58 PM   #1555
PaulG's Avatar
Default Spur and Pinion
Could some help with a couple of questions I have.
1. What Spur gear comes with the 415 (size and pitch)
2. What size pinion gear come in the kit
3. What is the internal gear ratio
I am still waiting for my kit but need to start working on some setups.
Cheers
Paul Griffin
Losi 8ight-T
NitroX Fuel : RB Concept Motors
Spektrum DX3R : ACE Servos : Proline Tires
Hobbytime.com.au
PaulG is offline   Reply With Quote
Old 03-31-2004, 04:22 PM   #1556
Registered User
64 Pitch Size:102
No pinion
GraphiteMilitia is offline   Reply With Quote
Old 03-31-2004, 04:28 PM   #1557
Registered User
Also People who dont know the gear that comes with the car is a 64 Pitch Metric Not a normal 64 pitch. They look like they fit but there a little off. So buy a real 64p
I run
Motor: Monster Stock
Gear: KM 104t 64p[after market gear]
34 Pinion
Old 03-31-2004, 04:31 PM   #1558
izzyracer's Avatar
Originally posted by GraphiteMilitia
64 Pitch Size:103
No pinion
huh! I tought the stock spur was 102?
Izzy
Old 03-31-2004, 04:58 PM   #1559
JimmyMac's Avatar
It is a 102 spur. I run a RW 104 spur. 2.187 is the internal.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-31-2004, 05:48 PM   #1560
Registered User
MONEY MONEY/......
Is some one has a 415 and is willing to take some parts off and make me scale drawings i will pay 10.00 Paypal
Parts:
Upper Deck
Front Brace
Rear Brace
Front Shock Tower
Rear Shock tower
AIM: graphitemilitia
When done im me
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
