Like Tree2Likes
Tamiya TRF415
Old 09-01-2006, 04:29 AM
  #15466
kewdawg's Avatar
Originally Posted by CIVIC91
Oh ok...but for others looking both 4 and 6 are available, and 6 is most popular with carpet/foams.
Can you list the part number for the 6 degree caster blocks?
kewdawg is offline
Old 09-01-2006, 04:34 AM
  #15467
Wing Chun's Avatar
Thank's Smokin
The reason I asked is that a new track is opening on the gold coast and is outdoor sticky asphalt (long and flowing) and I run rubbers and one way and also a new track at beaudesert is indoor concrete. So I may get away with one tyre/diff setup for both track's.
Thank's Mate
Addam
Wing Chun is offline
Old 09-01-2006, 05:18 AM
  #15468
Core Creations's Avatar
Trader Rating: 99 (100%+)
Core Creations is offline
Old 09-01-2006, 05:28 AM
  #15469
Originally Posted by TryHard
Eh? Why did you shave them?
Mine fit fine.... if there a little tight to get on and off, well thats by design.
Cause the MRE instructions says to shave off a little off there...Just following the instructions. Oh well....Whats done its done...
Ben.C is offline
Old 09-01-2006, 07:38 AM
  #15470
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by xtrememadness
hey carl. i run the lwt arms with 4 degee hubs on carpet. just curious how does the car handle with 2 degee. does it calm down the steering a little. thanx.
I found the 2 degree blocks increased initial turn-in steering...I usually use them on really tight tracks. Horsham is on my list of stops this year...see you guys there.
Carl Giordano is offline
Old 09-01-2006, 09:08 AM
  #15471
FYI...my 32T pulley project failed..the belts are just too loose. Going back to the 36T...
Old 09-01-2006, 09:20 AM
  #15472
TRF415boy's Avatar
I'm not surprised to be honest, tried to warn you
TRF415boy is offline
Old 09-01-2006, 09:53 AM
  #15473
Does anyone know the Hot Bodies part# for the wheel axles? I am running HPI knuckles for my carpet conversion. I am currently using the axles from the original 415 suspension. They work but require alot of shimming and the Hot Bodies parts fit perfectly, obviously because they are made for them.
Thanks in advance,
JoeGlover is offline
Old 09-01-2006, 11:18 AM
  #15474
kewdawg's Avatar
53458
Thanks!
kewdawg is offline
Old 09-01-2006, 11:22 AM
  #15475
kewdawg's Avatar
Looking forward to it, Carl. Your 415 looked good last indoor Season at Mimi's! Let me know when you're coming down.
kewdawg is offline
Old 09-01-2006, 04:39 PM
  #15476
Thanks!
Just double checking that you are using these on the Non-LW suspension correct?
For the LW it is 2 and 4d only. If you want 6 you have to add kick up to the front toe block.
Difuser is offline
Old 09-01-2006, 04:44 PM
  #15477
I hate DV Took a hit of newbie and killed a bearing and bearing holder.
Know anyone who has them in stock in the uk? As this is a really odd part to fail.
Smoking motor.. is offline
Old 09-01-2006, 06:25 PM
  #15478
xtrememadness's Avatar
hey joe the part# is hb75187 for the axles. i just bought the last pair from speedtech. they are so hard to find. i hope speedtech gets more in as i need an xtra set. seems to be the only place i was able to find them.
xtrememadness is offline
Old 09-01-2006, 06:28 PM
  #15479
thanx carl. i'll pick up a set to try. see ya at the track.
Old 09-01-2006, 08:31 PM
  #15480
Originally Posted by HarshGuy
Kewl ...thanks ..TI turnbuckles ordered, they came in sets of two, so I get an extra 23mm (actually 1", so I can sell 1/10" worth of TI Turnbuckle to you if you want).
HarshGuy,
Where did you order your turnbuckles from?
croy is offline
