Old 08-31-2006, 09:53 AM   #15436
TRF415boy's Avatar
Originally Posted by TimXLB
Carl:
Hi,
I agree with TRF415boy. if the rollout is the same pinion size won't matter. I wonder about the internal ratio of the car though. it seems a higher ratio would be better for stock (everything else being he same). our best stock sedan has the highest internal ratio. having just bought a 415MSX to run on carpet/foams. I have been looking at the TA-05 diff and centre gears for my 415 to raise the internal to 2.25.
also do you guys cut the fronts down at all or just space them out???? I ended up spacing the rims out about .040
so thet won't rub. or do you use a different steering knuckle???
(this is my first Tamiya besides my TA-05. I'm trying to get it ready for Cleveland)
Quite a few people use the HPI front hubs (in accordance with hpi front wheel axles, on which you can put the tamiya dogbones) with foam.
TRF415boy is offline   Reply With Quote
Old 08-31-2006, 10:56 AM   #15437
HarshGuy's Avatar
Damn the bad luck ...I was gonna get TI turnbuckles for "little Jenny's" twin, but left my manuals at home ...does someone have an MRE maual handy and can you post the Qty and lengths of the turnbuckles needed?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-31-2006, 11:03 AM   #15438
3X42mm (steering) X1
3X32mm camber links X4
3X18mm steering linkage X2
Just happened to sit down for lunch and see your post.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 08-31-2006, 11:19 AM   #15439
The Teacher's Avatar
Trader Rating: 49 (100%+)
TimXLB, I'm running my 415msx on carpet with foams and I've found when you just space the wheels out to make the foam tires fit, the car is wider than 190mm. Have you measured the front of your car??? What I did to make the front end work (...with all Tamiya parts) was to run "A" blocks in the front with the short LWT reversible arms (only in the front) with the 6mm hex and 1 red and 1 blue spacer on the axle. This puts the front end just under 190mm and you don't have to cut the tire/rim any. You also don't have to put any other companies parts on your car...i.e...HPI.
The Teacher is offline   Reply With Quote
Old 08-31-2006, 11:23 AM   #15440
JayL's Avatar
Joe are you sure??
I'm prettry sure you need 2 of the 42mm
and 1 of the 23mm
JayL is offline   Reply With Quote
Old 08-31-2006, 11:42 AM   #15441
Originally Posted by kewdawg
TryHard,
What's the part number on the new Short LWT arms?
53928
http://www.tamiyausa.com/product/ite...oduct-id=53928
Fuse is offline   Reply With Quote
Old 08-31-2006, 11:49 AM   #15442
JAY_UK's Avatar
Send a message via MSN to JAY_UK
If this hasnt been sorted by the time i get home ill check the manual and post it for you!
JAY_UK is offline   Reply With Quote
Old 08-31-2006, 11:50 AM   #15443
JAY_UK's Avatar
Guess i should have read the post below yours!
Old 08-31-2006, 11:56 AM   #15444
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Thanks 415boy and TimXLB for the feedback...makes sense. I'll probably just stick with the white diff pulleys...figured I'd ask...always looking for an advantage, especially in stock.
Tim...you can use the 415 locked center pulley with the TA-05 diff pulley...I use the HPI steering knuckles with the LWT arms for my carpet ride. I only use the LWT versus the standard 415 arms because I can adjust the caster with LWT arms...the stanard arms do not allow option caster blocks and you still maintain the option to adjust front track width. With the tamiya knuckles and foams you need to space the front-end out to clear the rim...not very practical.
The only down side with the HPI knuckles are they're weak...and you need to trim the steering stopper off them to gain maximum steering throw. I just ordered 6 sets for the season...someone actually gave me a set of aluminum knuckles which I may try this season.
Thanks for the advice...
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 08-31-2006, 01:14 PM   #15445
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Tamiya makes both 4 and 6 degree caster blocks for the standard suspension, and they clear 28mm foams easily.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 08-31-2006, 01:18 PM   #15446
JayL's Avatar
MRE turnbuckles:
for titanium ones I listed the part#'s
2 of 3x42mm tamiya part#49283
4 of 3x32mm tamiya part#53527
1 of 3x23mm tamiya part#53526
that is what you need!
Jay
Old 08-31-2006, 01:37 PM   #15447
I was looking for the 2 degree, which are available for the LWT
Old 08-31-2006, 02:21 PM   #15448
Oh ok...but for others looking both 4 and 6 are available, and 6 is most popular with carpet/foams.
Old 08-31-2006, 02:40 PM   #15449
HarshGuy's Avatar
Originally Posted by JayL
MRE turnbuckles:
Jay
Kewl ...thanks ..TI turnbuckles ordered, they came in sets of two, so I get an extra 23mm (actually 1", so I can sell 1/10" worth of TI Turnbuckle to you if you want).
Old 08-31-2006, 02:41 PM   #15450
HarshGuy's Avatar
Originally Posted by Fuse
For "some unknown reason" ...they are out, and so is Speedtech
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
