Old 03-28-2004, 01:02 PM   #1516
kewdawg's Avatar
Hey guys!
I just ordered my 415 yesterday, from Ultimate Hobbies in Cali. USA. I should have it by tuesday. I need a carpet set-up. As we're still running indoors, here in the northeast: PA, NJ, etc. . Any help would be greatly appreciated!
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 03-28-2004, 01:22 PM   #1517
As i have the car running so well indoor with oneways i see no reason for not using them as a starting point for setup outside. The car just flows so well with them, its outstanding. Rick
Rick Draper is offline   Reply With Quote
Old 03-28-2004, 01:32 PM   #1518
im so jelous
Evo_Uk is offline   Reply With Quote
Old 03-28-2004, 01:36 PM   #1519
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Belt Tightening?
how many clicks is everyone running with their cars broken in now?
mine is at 2 clicks front and back.
Rick D. did you adjust your belt tension since you did the every other tooth clipping? curious to see if it'll affect tension.
a friend at the track yesterday clipped the belts too much, and had the rear clicked 3 times, and his belt snapped.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-28-2004, 03:17 PM   #1520
ngo8's Avatar
Send a message via ICQ to ngo8
i would love to get a trf 415 the only problem is we run here on carpet with foams and the 415 does not yet have a diff for the front so ill wait till next year its one more month left to the indoor season anyway why bother i love my evo3 right now anyway .
ngo8 is offline   Reply With Quote
Old 03-28-2004, 03:26 PM   #1521
JimmyMac's Avatar
I've been running my rear at 3 clicks. Yesterday was the first time I ran the belts clipped. No problems. I was actually thinking of goin to 4 clicks in the rear and 3 for the front. I'll let ya know if it snaps.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-28-2004, 03:27 PM   #1522
Send a message via ICQ to Cobra81li200
you should try to get Kawada diff outdrives. They're a perfect fit on Tamiya diff gears and plates. If you can make 10mm diameter spacers to prevent the play (as they're made for a car that's only 15mm wide on the bulkheads) they'll be perfect.
Cobra81li200 is offline   Reply With Quote
Old 03-28-2004, 04:42 PM   #1523
Hebiki's Avatar
wow 4 clicks? i think ill move mine to 3 clicks each with the clipped belts. since i have an extra set of belts.. i wont mind if it snaps.
someone explained this earlier..
but a looser belt has different characteristics over a tighter belt right? i think a tighter belt has more rip out of a corner? am i right? i dont remember what the earlier post stated.
Hebiki Design Works
Old 03-28-2004, 04:51 PM   #1524
I have one car with std belts and one with clipped belts, so far unclipped one is one click tighter front and rear and clipped one is two clicks tighter front and rear. Got loads of spare belts anyway so if they let go i will just learn from my lessons and fit std belts back on it.
Ordered 2 of the new frotn A blocks today to hopefully cure the driveshaft issue i had. Rick
Old 03-28-2004, 05:16 PM   #1525
JimmyMac's Avatar
Yeah, a tighter belt will accelerate faster. One that is looser will have more "slack" to pull out of the belt before it graps or reacts on the pulleys. A belt with less tension has more top end.
I too have spare belts. I'd just hate to have one snap while racing haha. But I see no use in switching to a new belt until this one does snap. I could leave mine with 3 clicks rear and 2 front. But I'm looking for more snap out the turns. Those TC3's are pretty quick! So I'm gonna try out 4 clicks rear and 3 front. I think my belt is still breaking in.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-28-2004, 07:57 PM   #1526
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
hey guys,
any one measured the belts??? was it the same as those used either in a 04 or 414???
thanks.
Windtalkers is offline   Reply With Quote
Old 03-28-2004, 08:07 PM   #1527
Sorry to ask a "stupid" question - what does "clipping" the belts do - and what is it exactly?
I have a 414 MII - will clipping the belt help?
duckman996 is offline   Reply With Quote
Old 03-28-2004, 08:34 PM   #1528
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally posted by tamiyadriver
had a question... anybody come up with the easy way to build a front diff yet? and did you lock the center pulley? i usually like diffs better. my 415 should be here monday (thanks Steve!!), and i wanna be prepared....
Tamiyadriver, I have an Idea on how to lock up the center shaft, but I have to wait till Tamiya USA gets in the spare parts. I'm pretty sure I can do it with all Tamiya parts.
As for the front diff. I know that Martin Crisp found a way to make it from HPI parts. I looked at an old Kawada SV10, but no go there.
tamiyarcracer is offline   Reply With Quote
Old 03-28-2004, 10:11 PM   #1529
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
cool.. thanks! keep me posted on the middle shaft idea. in the meantime, ill just hafta make do. maybe it will speed me up!!! i could sure use that...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-28-2004, 11:24 PM   #1530
Hebiki's Avatar
rick
is the wheelbase so wide in the front that the drive cups for the one way are popping out? i put those pink sponge thingymabobs from the shocks in the drivecups to help make the fit a little bit more snug. try that see if it works for you. Or i could be completely WRONG about what your mentioning
Hebiki Design Works
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
