Old 08-23-2006, 09:00 PM   #15241
JAY_UK's Avatar
Send a message via MSN to JAY_UK
Originally Posted by TacticalTimbo
so Jay UK what radius should I cut the blade to?
Looking at the size of screws on my MRE chassis im gonna say between 3-4 mm, no more!
JAY_UK is offline   Reply With Quote
Old 08-23-2006, 09:03 PM   #15242
JAY_UK's Avatar
There is one other thing you could try first - use the equivalent size imperial allen key, they are usually slightly larger than metric! May work and save you from having to cut the screws!
Old 08-23-2006, 09:07 PM   #15243
jakster's Avatar
i have also used a very small pointed punch , to walk the screw around, but this is much harder tech
jakster is offline   Reply With Quote
Old 08-23-2006, 09:09 PM   #15244
TacticalTimbo's Avatar
Send a message via MSN to TacticalTimbo
Jay you don't think my chassis being 1mm thinner than the MSX i.e. 3mm instead of 4mm will make a diffrence do you?
TacticalTimbo is offline   Reply With Quote
Old 08-23-2006, 09:10 PM   #15245
JAY_UK's Avatar
make a difference to what mate?
Old 08-23-2006, 09:17 PM   #15246
the thickness of the screw?
oh and you no you say use a grinding stone, do they come with it and how do you use them?
Old 08-23-2006, 09:21 PM   #15247
JAY_UK's Avatar
Screws shoud be samew thickness as mine, only difference would be thread length (which is actually the same)
Grinding stone doesnt come with it, they are used for sharoening chisels etc.
Its a flat stone so turn fremel on, put the cutting disc onto the stone until its worn to a perfect circle.
Old 08-23-2006, 09:24 PM   #15248
By thinkness I mean depth
the screws are BA4 3x8mm
Old 08-23-2006, 09:27 PM   #15249
JAY_UK's Avatar
Exactly the same as the MSX so no difference!
Hope you appreciate this i just got out of bed to read the manual to check that!
Old 08-23-2006, 09:29 PM   #15250
You can't understand how much, no really you can't!
You're the best Jay!!!
Old 08-23-2006, 09:34 PM   #15251
JAY_UK's Avatar
No probs mate. Anyway its 4:30 am and i gotta go to work in 3 hours, ive pmd you my msn address in case you need anymore help so im off to sleep now! TTYL
Old 08-23-2006, 09:39 PM   #15252
yea me to i'm recked! nite
Old 08-23-2006, 10:03 PM   #15253
darchard123's Avatar
Default 415 diff
Hi
I have got myself a used 415 that i just re-built now its almost new with the spare parts i got in the deal...anyway i have a alloy ball diff for the front (carpet racing) and I also have the option of running ether the stick plastic rear diff or an alloy rear diff. which would be better? i did notice the front alloy diff is very smooth compared to the rear plastic diff...
also to add i will be running int both mod (5 to 7 turn) and 19turn class...
any help would be great.
also is that module suspension any good for carpet racing?
darchard123 is offline   Reply With Quote
Old 08-24-2006, 12:06 AM   #15254
Originally Posted by darchard123
Hi
Use the Alloy diff halves...Its much smoother as the plastic ones do warp over time.
Are you racing rubber on carpet or foams?
Ben.C is offline   Reply With Quote
Old 08-24-2006, 07:00 AM   #15255
Boultspeed's Avatar
Originally Posted by Smoking motor..
Were you running the DJ rear end at DV?
Yep , thats me
___________________
www.boultspeed.com
MB models (leeds)
Titanium Racing
Boultspeed is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
