Old 08-23-2006, 04:44 AM   #15211
CRASH's Avatar
Trader Rating: 26 (100%+)
What the best parts to use for rebuilding your diffs. Thrust bearing and diff balls.
Thanks,
CRASH is offline   Reply With Quote
Old 08-23-2006, 05:57 AM   #15212
Eirik's Avatar
Originally Posted by TRF415boy
I asked the same question, the answer is no, only the top bit is lower, so no changes to the RC.
Hmmm, why would they change that?
Eirik is offline   Reply With Quote
Old 08-23-2006, 06:03 AM   #15213
TryHard's Avatar
Lowering the outer pick up point lowers the Roll Centre, so that's pretty much whats happened there.
| THard.co.uk | Xray | MuchMore |
Old 08-23-2006, 06:06 AM   #15214
HarshGuy's Avatar
Originally Posted by <TAMIYA_TRF>
is the only difference between the MRE msx and the regular MSX the steering set up?? i know that it comes with the Mazda 6 and Marcs signature on the motor mount. but is there any thing that much better?
It's not his signature, unless he signs in block letters
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-23-2006, 06:12 AM   #15215
Eirik's Avatar
Jupp, know that, but you could just add a 0.5mm washer on the inside, same thing!!
But, if they lowered the the pin height, we would be able to even feel the difference
Old 08-23-2006, 07:10 AM   #15216
TryHard's Avatar
Less washers, less weight
Old 08-23-2006, 07:14 AM   #15217
Boultspeed's Avatar
Hi Guys,
Iam having a problem with my MSX steping the rear end out on initial turn in, I've tried various set ups and still have the same problem.
Any idea's ?
Paul.
___________________
www.boultspeed.com
MB models (leeds)
Titanium Racing
Boultspeed is offline   Reply With Quote
Old 08-23-2006, 07:22 AM   #15218
Eirik's Avatar
Originally Posted by Boultspeed
Hi Guys,
Any idea's ?
Paul.
Try a shorter front camberlink and/or rise the inner ballstud by 1.0mm
Old 08-23-2006, 08:04 AM   #15219
Boultspeed's Avatar
Thanks Eirik i'll give it a try
___________________
www.boultspeed.com
MB models (leeds)
Titanium Racing
Old 08-23-2006, 12:50 PM   #15220
TryHard's Avatar
Actually, got home and checked this. The axle IS 0.5mm lower, got my calipers out and measured from the bottom of the hub. This means rear droop settings will be different on the MRE to MSX. The MRE would have more droop if set off the same arm height. (ie 4 on a gauge of the MSX is about 3.5 on the MRE)
Might contribute to the extra steering...
Regards
Ed
Old 08-23-2006, 01:37 PM   #15221
Hi Guys,
Any idea's ?
Paul.
Were you running the DJ rear end at DV?
Smoking motor.. is offline   Reply With Quote
Old 08-23-2006, 01:37 PM   #15222
Eirik's Avatar
Hey Ed,
Thats what I thought
Lowering the axle height would actually give more traction!!
Because the steering is moved back, the chassis will be slightly stiffer.... have you noticed that Ed?? (Harder to "twist the car" )
Also the new steering with the loooooong links and all, should give more steering as well.
Old 08-23-2006, 02:02 PM   #15223
TryHard's Avatar
Hey Ed,
Yup, I think it's all combination of the steering links and the changes to the rear. Have to admit though, hadn't noticed the car being any stiffer, but that does make sense.
Ed
Old 08-23-2006, 02:13 PM   #15224
Is there any change in the ackermann geometry?
Old 08-23-2006, 06:41 PM   #15225
TacticalTimbo's Avatar
Send a message via MSN to TacticalTimbo
Default rounded off allan screw!
See below |
TacticalTimbo is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
