Old 01-22-2009, 10:00 PM   #1
dameetz's Avatar
Default Batt connector: Which is the best out there?
What type of batt connector you guys using? I m running Lipo 2 cells with Dean connector (in a TC) and sometimes it gets hot. I wonder if theres a better connector out there.
dameetz is offline   Reply With Quote
Old 01-22-2009, 11:17 PM   #2
Deans are up there. You say the connector gets hot. Does the WIRE get hot too? I know mine do when I have a hard run. It may be an unavoidable consequence of running high-current gear.
Just a thought.....
JR007 is offline   Reply With Quote
Old 01-22-2009, 11:18 PM   #3
HarryN's Avatar
Send a message via AIM to HarryN
Just a thought.....
Either that or you could try going from a 14 AWG to 12 AWG...whichever is thicker and allows more current to flow with less ohms.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 01-23-2009, 09:03 AM   #4
dameetz's Avatar
Just a thought.....
The wires are fine just warm to touch the hottest part is the connector but then again I can still touch it not flaming hot. How about Traxxas connectors? I read somewhere in a magazine, it is supposed to be better.
Dudududududuuuuuu.....
Old 01-23-2009, 09:12 AM   #5
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
I use the Trinity bullet connectors. http://www3.towerhobbies.com/cgi-bin...1&I=LXTJ25&P=K
The only drawback is that if I need to borrow a battery in a hurry many people run Deans Ultra Plugs that came standard with their packs. I try to have at least two lipo packs available just in case.
RCJunkie3000 - Gonzo69 Paints / Lex Tyler Paints / Norcal Hobbies
http://www.rctech.net/forum/r-c-items-sale-trade/344416-rcjunkie3000s-garage-sale-batteries-escs-chargers-cars-accessories-etc.html
rcjunkie3000 is offline   Reply With Quote
Old 01-23-2009, 09:22 AM   #6
Trips's Avatar
Trader Rating: 16 (100%+)
You could solder a couple of barrels to a deans plug... keep it in the pit box for the times you need to borrow a pack.
A pair of bullets spoldered to a deans socket and you could loan a pack to a deans guy in time of need as well...
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-23-2009, 09:45 AM   #7
Frank McKinney's Avatar
It's always handy to have a couple of battery adapters so you can swap batteries with racing buddies or whatever. IMO Deans are probably the best, the only thing I don't like about them is that the plastic can melt (making the metal shift) if I'm too slow with the soldering iron. The various bullet plugs from Orion/Corally/whoever are possibly the most versatile because there are so many brands making them (and in metric sizes too), their main (only?) drawback is that you have two separate bits of wire flopping about instead of one plug.
I'm still a bit baffled why there are so many other types of high-end connectors (Traxxas, Venom and others) when there's clearly 1 or 2 superior ones already available. It just makes it worse for shops and new customers. I understand with the Dean's plugs there may be a license fee in certain countries but the bullet connectors are great and can be ordered OEM by the containerful from China.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 01-23-2009, 11:30 AM   #8
bkspeedo's Avatar
Mechanically 4mm bullet connector provide more surface area therefore less resistance. The only problem is I have seen people plug bullets in the wrong holes and smoke ESC's.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-23-2009, 11:46 AM   #9
dameetz's Avatar
I ve seen it happened and its not pretty, thats why i opted not to use 'em.
Old 01-23-2009, 12:01 PM   #10
Just need to pay more atttention to the polarity...
Ben.C is offline   Reply With Quote
Old 01-23-2009, 12:33 PM   #11
Akhor's Avatar
I also use deans in favor of built.
Mostly because with built, you have two seperate wires that need to be connected.
--Blaine--
VBC D07, VBC D08
www.carcar.ca
Akhor is online now   Reply With Quote
Old 01-23-2009, 12:39 PM   #12
Trader Rating: 41 (100%+)
I personally Use Dean's and Have had good sucess. but Most of the racers at our track direct solder the batteries to the ESC before every race. I don;t think the savings in resistance is worth it but I'm also lazy.
jdeadman is offline   Reply With Quote
Old 01-23-2009, 12:42 PM   #13
Anthony.L's Avatar
Trader Rating: 36 (100%+)
I would not worry about the Dean's melting or not being able to take the amp draw.
To give you a idea I've used Deans in large heli's and planes using 12S lipos with 100+ amp peaks. Besides from the HUGE spark when you plug them in, they have never failed me.
With that said, Deans are starting to annoy me and I'm considering moving to Eflite EC3 connectors. They are effectively 3mm bullet connectors inside a plug so you can't accidentally plug them in wrong. They are much easier to solder and plug-in compared to Deans. Best part is you can buy knockoffs out of China that are dirt cheap and the same thing.
Anthony.L is offline   Reply With Quote
Old 01-23-2009, 01:21 PM   #14
minittrackmann's Avatar
If your running nimh lets say can you solder the pack directly to the esc and then charge with alligator clips while the esc/batt are soldered up?
Cody
minittrackmann is offline   Reply With Quote
Old 01-23-2009, 03:30 PM   #15
Anthony.L's Avatar
Cody
I think every ESC manufacture says do not charge your battery while the ESC is connected. I know some ESC's can be damaged, while some don't care.
With that said, I always ran KO ESC's and peaked my NiMH battery with it soldered to the ESC all the time and it never did anything.
