Old 01-22-2009, 09:24 PM   #1
Send a message via AIM to TomElEctric!
Default Rc12R5 VS GenX 1/12
What car do you choose? Tell me Why you like this car
Pros cons of these cars
Price:
Racing:
Handle:
Overall:
What you think about and witch 1 is better
Tc4 Stock / 1/12 pan car! /
Selling tc4 160!
Tom :D
TomElEctric! is offline   Reply With Quote
Old 01-22-2009, 11:05 PM   #2
roadkill's Avatar
Trader Rating: 139 (100%+)
Send a message via Yahoo to roadkill
I like the 12r5 shocks,way cool.
I hate the material the front end parts are made out of, you tag a wall or two,and the front end gets sloppy,steering blocks get sloppy,piviot balls get sloppy upper eyelets get sloppy, the only way to fix it seems to be,to buy new front end parts,or stay away from the boards(yea right).
the gen x front end,you can take up the slop.
so in my book it's crc or go home.
Keeper of the check book, Pit butler,(for hire) President and life long member of the Black Flag Club,
roadkill is offline   Reply With Quote
Old 01-23-2009, 09:14 AM   #3
Hmmmmm. Very interesting, however, at the track I race at just the opposite is true. The CRC is the most popular chassis but more people break front ends than the 12R5. I'm not the best pilot and have managed to tap the wall way too many times at speed yet my 12R5 survived with only the loss of one spring. Unfortunately the same can't be said for the Gen X. In one heat I was the last car rolling out of 5 due to each CRC breaking or losing its battery.
The springs in the R5 compress after a while and need to be shimmed. Other than that it seems to take major abuse and keep on ticking.
One advantage the CRC has over the AE is the installation of a BL motor with their open rear pod. But it isn't very hard to remove four screws from the R5 and how often do you need to change BL motors?
AreCee is offline   Reply With Quote
Old 01-23-2009, 09:17 AM   #4
Price:
Racing:
Handle:
Overall:
Price: R5 ($50 less)
Racing: Either can win in the right hands.
Handle: Either one
Overall: Either one
Which one is better? They're both excellent platforms.
Old 01-23-2009, 09:25 AM   #5
rcterp's Avatar
Trader Rating: 35 (100%+)
The beautiful thing about 1/12th that I've seen in a very short amount of time is this: the car is mostly personal taste, the better car is driven by the better driver.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 01-23-2009, 09:31 AM   #6
Default gen x
to me there are 5 things that i think makes the gen x stand apart from others.
1- the rear springs sit on flat graphite, not a link that can move and effect tweak
2- the front king pins are adjustable, no need to play with shims
3- the lower pivot ball can be tightened or loosened. when i had a 12r5 the lower balls would never be th esame left to right, one always had more slop. i tried different balls, new arms, never seemed to be perfect.
4- genx offers a long front ball set up that just gives you more tunebility in your front end.
5- no battery tape!!!
and i believe the car is on sale on crcs website, so i dont think there is a 50 dollar difference. just my opinion..
nazman01 is offline   Reply With Quote
Old 01-23-2009, 09:39 AM   #7
Trips's Avatar
Trader Rating: 16 (100%+)
Handle: Either one
Overall: Either one
I'm not so sure of the $50 price gap... Stormer lists the 12R5 for $199 and the GenX for $224.
I just bought a new GenX at 360 Speedway for $199, and they threw in the wide rear pod kit with it. I'm pretty sure they still have one left on the wall at that price.
As far as:
Racing: completely agree with AreCee
Handle: completely agree with AreCee
Overall: completely agree with AreCee
Which one is better? I have to say the GenX is WAY better, because I just bought one. Seriously, just like AreCee said, both cars are excellent, I doubt you'd go wrong with either one. If I were going to choose one right now, I'd look at which car had better parts support locally. Actually, I can think of one other factor... If you have all metric tools, go for the 12R5. If you have all Imperial sized tools, go for the GenX. If you have both, or don't mind buying some tools, it's back to both are great cars, take your pick.
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-23-2009, 09:55 AM   #8
Stormer used to price them like: R5 $199.99 and Gen X $249.99 which is what I based the $50 difference on.
If I had to buy another today I would be tempted to go with the CRC because that is the most pervasive car at the track I race at. At another one I race at it is the BMI and at a third it's the R5. What that means is that the track owner sells the most of whatever they can make a better margin on rather than the better car.
Old 01-23-2009, 09:57 AM   #9
Trader Rating: 16 (94%+)
I had a Gen-X before switching to the SpeedMerchant Rev.5, and a few guys at my track have the 12r5, so are a few plus and minuses of each:
Gen-X
- Plastic side links
- Aluminum ball studs for side links
- Brass set screw in Aluminum Steering Block for King Pin
- Aluminum Steering blocks not very durable, bend and strip
- pivot balls bend
+ Carbon Fiber is top quality and cut very clean
+ Bulkheads are strong and true
+ good support and optional parts direct from CRC
12R5
- motor bulkhead weak aluminum, bends easily
- aluminum front suspension parts bend easily
- damper shock pain can be a PITA
- Metric screws - no aluminum screws kits available yet
+ good parts support
+ low cost
kn7671 is offline   Reply With Quote
Old 01-23-2009, 10:15 AM   #10
Regional Moderator
CarbonJoe's Avatar
If you're just starting out in 1/12 scale, if you get a chassis that relies on a large O-ring to hold the batteries in (CRC, BMI), do yourself a favor and still use tape. As a beginner, you *will* hit things, and the O-ring alone will still allow the batteries to move in the event of a crash. This will cause bent or broken center shocks. My son did this quite a few times, until I added tape to hold the batteries in. A roll of tape is a lot cheaper than replacing one or two shock bodies/shafts per week.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-23-2009, 10:24 AM   #11
Plus w/o tape your batteries will get all banged up, tear the shrink wrap quicker, and stress the battery bar soldering connection.
Old 01-23-2009, 10:40 AM   #12
Another minor point in favor of the R5: You do not need to detach the shock to put the battery in place.
Old 01-23-2009, 10:40 AM   #13
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
One of the reasons I went with the CRC Gen X is because I didn't want to build saddle pack nimh batteries. The other reason is many local racers run it so I can get setup tips.
RCJunkie3000 - Gonzo69 Paints / Lex Tyler Paints / Norcal Hobbies
http://www.rctech.net/forum/r-c-items-sale-trade/344416-rcjunkie3000s-garage-sale-batteries-escs-chargers-cars-accessories-etc.html
rcjunkie3000 is offline   Reply With Quote
Old 01-23-2009, 10:45 AM   #14
Gen-X
- pivot balls bend
12R5
+ low cost
Wow!! How hard are you hitting the walls to bend theR5 motor mount and front bulkheads??
The worst that ever happens to my R5's rear pod is the motor mount screws loosening up and the motor slides forward (13.5 BL) losing the gear mesh. Including hitting hard enough to break a wheel at the hub with no damage to the car.
The worst that ever happen in the front is the loss of a kingpin e-clip and ultimately the spring. I did finish the race in third with one side of the chassis dragging on the ground because the other four CRCs all broke something.
Old 01-23-2009, 11:20 AM   #15
Trips's Avatar
Amen. The tape is your friend. Use the tape. Love the tape.
MARSHAL!!
