Tamiya 0.4 gears & 64pitch gears
Hi guys... I've got a load of Tam 0.4 pinion gears. But I want to run BL 17.5 and to get the right gearing I need to use a different spur and it doesn't look like tamiya makes a 80T or there about 0.4 spur gear.
Can I use tam 0.4 pinions on a 64 pitch spur gear? If yes, what will happend?? |
Originally Posted by Ricky/C
(Post 5323076)
(Post 5323076)
dont do it!!!
R |
Is Tamiya 0.4 pinion same like 64pitch pinion?
Originally Posted by dameetz
(Post 5324809)
Originally Posted by ultegrasti
(Post 5324151)
dont do it!!!
R |
I have used them by accident in the past and it worked...but it isn't a good idea to. Though they look the same the pitch is different and you will not get good tooth engagement mixing them. Besides the possibility of increased noise you also increase the chances of stripping or damaging a gear.
I have done this with no problem. AreCee I was racing you with a 64 pinion and a 0.4 spur!
Originally Posted by robk
(Post 5325110)
I may still have some of those real soft aluminum pinions Kyosho included with their kits. One of those pinions has teeth pointing backwards.:lol: Bottom line is that it can be used but your experience may differ from that of others. |
Originally Posted by cherokee
(Post 5324905)
Nope. You might think that they are on the bench but when they are in the car your ears will let you know they are very different.
I think that all tamiya kits use metric pitch gears.
(Post 5327858)
Ive been trying to find the 0.4 gears but the part numbers are all jenky.
The instrustions suggest bad part # and I cant find the 26t 27t 28t or thr 29. |
Originally Posted by John St.Amant
(Post 5328587)
The instrustions suggest bad part # and I cant find the 26t 27t 28t or thr 29. I don't see a 28 or 29. I will look up what I want on the tamiya site then send a note off to champ. Several people recomend them for tamiya parts, they are very hard to find around here. |
