WORLD GT?? Who, What, Why?
I keep hearing about the WORLD GT Spec class, but WHO is sanctioning it? What are the specific rules, and WHY?
I've heard the class is aimed at 13.5/4 cell (why are they building NEW chassis' and using 1970's style batteries)
I'm looking for more info on this type of class (World GT or other rules) and what's working where...
Here are the rules:
http://www.worldgtrc.com/WGT_2008_Rules.pdf
The guys that thought this up were looking for a specific power to handling ratio and 4 cell 13.5 is perfect. There are new, easy to maintain cells readily available.
ROAR is set to adopt the above rules almost in their entirety for 2009
I am running a Novak GTB with the Novak 21.5, and am truly happy with this setup. The only thing I may toy with is the drag brake setting. The chassis' seem to roll forever beofre they come to a full stop. Gearing is still something that I need to test, but right now, I am rolling a 2.2" rear and an 31/88.
The 21.5/Lipo is quicker the a 4 cell/13.5, but the ease of setup, charging & balancing, allows me to run a third class without a lot of fuss. I truly beleive the guys who drew up the WGT rules really dropped the ball when they did not allow for the Lipo/21.5 combination in the rule set.
For OVAL we gear the 21.5/LIPO combo TO THE MOON. (Like a 88/53) on a 270 ft. oval w/ 2.2's
I figured to run on the On-Road portion of the same track, I'd probably drop about 10 teeth....but we do have one really long stretch where you'll go wide opened for almost 100 ft.
The car I'm building is probably 12-15 years old...
Built by HPI, with a floating pod, and 6 cell battery slot 'Up the Middle', this car has been sitting waiting for a class like this...(Too bad some won't allow the original HPI Full Movement "Independant" Pan Car Front end...but it WILL get used locally)
This class seems like it had the chance to fix the things that were driving people away from foam tire sedan racing, but fell a little short. Hopefully that gets sorted out, 'cause it's definitely got my interest as well. The NiMH thing has to go, though. And where's the spec tire?
I think several companies are making spec tires intended for World GT
CRC
http://teamcrc.com/crc/images/empori...edia/52324.jpg
I have tried these on my wide pan and they were very good.
BSR
http://www.lefthander-rc.com/catalog...sort=3a&page=2
(I think) Jaco may be making a spec tire (lilac)? I don't see it on their main web site.
I have recent experience with 4 cell. This is not the way to go. Two of four new packs were deteriorated on purchase. Could not get a reliable supply of good cells. One supplier, Trinity, still has a weak four cell pack return after 5 months and has not sent a replacement.
John
CRC
BSR
John
Jaco does make Lilac Spec tires, here is a link to Stormer Hobbies:
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
CRC
BSR
John
CRC
BSR
John
http://www.promatchracing.com/products.php?cat=6
