Old 01-22-2009, 10:10 AM   #16
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Savage03 View Post
Ok thanks. How about my springs? Ones i have ok?
Silvers up front, greens in the rear. 40 wt. oil, #2 piston in the shocks. Camber -1 rear, -1 to -1.5 up front. 0 toe up front, stock 3 deg in back. (edit) If the rear end slides out too much in corners increase camber by -.5 until it goes away.
Mill just enough of the webbing out of the chassis under the pinion so it doesn't rub the oversized pinion you'll need for BL. Your internal drive ratio is 2.5, and you'll want your FDR set right for your motor. Typically, the lower the number of turns for a Brushless Motor the higher the FDR will go. Most guys around here run 13.5s and FDRs in the low to mid 4s.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-22-2009, 10:18 AM   #17
Trader Rating: 36 (97%+)
What pinion are we talking? Memory serves thing theirs a 16 on it now with stock spur.
THanks for that info to.
Savage03 is offline   Reply With Quote
Old 01-22-2009, 10:53 AM   #18
I run a 64p and have an 88 tooth spur. To get the FDR to a 4.0 you'll need a 55 tooth pinion (88/55). While you're at it, get a temp gauge. You'll want to know the temp of the motor after every run until you reach an acceptable heat range. I think the stock 48p is a 72 tooth spur, but you'll have to find a smaller one.
Old 01-22-2009, 02:15 PM   #19
I just ordered this 48p 69t spur for my BL setup in the TC3
If you need large pinions, you can get them from SpeedTech.
http://www.speedtechrc.com/store/ebp...?catmainid=502
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 01-22-2009, 02:19 PM   #20
I see Robinson makes 60s and 70s for 48p now. Very cool!
Old 03-10-2009, 01:04 AM   #21
Hey guys
Got the bl system finally and gave it a go today and its pretty slow compared to the 8t brushed motor I was running, this is a sidewinder 5700 combo and right now it has a stock 71 spur and 19 pinion. Wondering for those running bl how much larger can I go on the pinion? I only have that spur right now so trying to get more speed with this one for right now.
Thanks!
Old 03-10-2009, 12:09 PM   #22
rced1's Avatar
I am running a 69 spur and 33 pinion with a 13.5 brushless for a 40 by 80 track. I think you can use a 32 pinion with a stock 72 spur without any modifications. The VTA setup thread has a mod for using larger pinions on the TC3.
Slow is fast.
rced1 is offline   Reply With Quote
Old 03-10-2009, 03:53 PM   #23
Got a link to that thread?
Is a 69 the smallest spur you can fit? Looking at a 66t why I ask. Thanks!
Old 03-10-2009, 08:59 PM   #24
rced1's Avatar
Here is the link: http://www.rctech.net/forum/electric...uning-q-7.html
Robinson makes a 60 tooth spur in 48 pitch that will fit.
Slow is fast.
BMI Racing Discussions protc3 Team and Company Discussions 10674 02-05-2017 07:24 PM
Tamiya TB-Evolution III rc-zombies Electric On-Road 7237 11-16-2016 06:09 AM
Cheese City Xtreme RC carpet 08-09 yuk17bandit Wisconsin & Illinois Racing 779 10-09-2009 11:32 PM
Help rcwarrior1 Electric On-Road 19 06-16-2008 07:15 PM
AMB Personal Transponders...Too Expensive? Fred Perkins Electric On-Road 240 01-05-2006 08:18 PM
WHY the TC3??? myk505 Electric On-Road 55 07-26-2004 07:11 AM
