The Best Electric OnRoad Car
#16
Location: Colorado, USA, The land of the free and the home of the brave!
Yup, TC5F. Just got one a few weeks ago, raced it 3 times already and it's definitely gettin' in the groove. I had been a loyal xray "fanatic" ever since the T1 came out and loved that and every other version they came up with after that. One of the most appealing thing to me about that car was the complete ease of setup. It was just so easy to adjust setup changes to the car. I decided to switch to Associated when the new versions came out. I think it's the least expensive of all the next gen race cars, and the parts availability is incredible, comes with pretty much all the different tuning parts you could imagine, even comes with front and rear sway bars (99.9% of the time I never use rear swaybars anyway). In other words....go for the TC5F.
#18
The 416 uses a 2.25mm chassis, which would probably give too much flex for racing with foams.
I use the trf415msxx indoors on foams and although it is OK for club racing, I do feel it definately has more chassis flex than the ta05 I use indoors on foams, which has a 3racing graphite chassis.
This chassis is at least 3 to 3.5mm thick and has quite a few posts joining the top and bottom decks, which make the car respond a lot faster to steering input.
That said, the 3racing chassis and ta05 were a very good budget buy when I got mine a few years back... The only other "problems" with the ta05 is that because of the cheaper cost, you only get plastic shocks (which are prone to leaking) so I changed them for the alloy blue TRF version.
Also, the dogbone driveshafts are not really racing parts, s I changed these for universal driveshafts, which can be taken apart for cleaning and replacing parts.
The foam tyre version TC5 is a good car, and obviously is built especially for foams, so should see you well too.
That was quite a bit of information, but I think I'm pickin up what your layin down. does Kyosho make a good car for this class?
#19
I have no experience of Kyosho's recent cars, but I hear the TF-5 Stallion is the one to look at if you're interested in the most recent on road car Kyosho has made, Google is your friend... as is the image search if you need some pictures some here
http://images.search.yahoo.com/image...sigb=13ou66lsa
#20
If you get a Type R like you mentioned in your earlier post you don't have to worry about getting different chassis's for it like you do other cars. The guys that run for Losi tried different thickness chassis's on them and always went back to the stock chassis. They said it made no difference on that car. The car is good on foam and rubber. It has a thread here on the forum and you can get setup support from the team guys on that thread. As was said before, there is no "Best" TC. It is a matter of presonal preference as well as what you can easily get parts for at your LHS.
#21
It would seem to me that running electric would cost more across the board, as opposed to running nitro. Is that the case?
#23
WHAT IS THAT? IT LOOKS PRETTY SWEET!!
#26
To be competitave, if i'm not running Lipo cells. How often do I need to buy new cells? Here in Colorado there is one track that I know of off the top of my head, and the guys there are just plain rude. They don't want to help. There whole take is if you didn't bring it with you, then your screwed because there is no way in hell there gonna help you out. It was kind of a turn off. However seeing some of the cars that are out, I'm wanting to give it a go.
#27
sounds lik a bunch of jerks which is realyl to ba dbecause this hobby is founded on nice guys willing to help.
Just be real nice to them, don't go in there actling like a total idiot. DO a ton of homework on your own before going in with a million questions. ASk them here or do some reading first.
Im assuming you've never done this before, so don't worry about replacing cells when your new. When you get good NI-MH packs last about a season of racing if you maintain them properly. But a good LIPO pack will last you 3x as long with no care .
#28
