Old 01-19-2009, 03:26 AM   #1
dameetz's Avatar
Default Lipo race batt, how much mAh?
Hi I m new to electric touring scene, I m in a market of buying batts for my new sedan. I want a batt that can last 5 mins or more, thats the duration of races in my country. I ll be using EZrun 5.5T motor and will race it indoor as well as outdoor(on an asphalt track meant for nitro car). At the moment I m looking towards Intellect 3800mAh 35C and 5000mAh 30C. Hope you guys can point me to the right direction.
Thanks.
dameetz is offline   Reply With Quote
Old 01-19-2009, 03:32 AM   #2
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Thanks.
IP3800 35C would be a minimum if you're running modified...
The C rating is adequate for the current draw (3.8*35=133A) and the capacity will be enough for a 5min race with a 5.5T brushless.
Personally I like to have some overhead, so I'd be happier with the 5000 30C (5*30=150A) packs from Intellect.
You've made a good choice with both those packs
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-19-2009, 03:39 AM   #3
dameetz's Avatar
-Mark
Thanks for the info Mok.
Old 01-19-2009, 04:11 AM   #4
mok
mok's Avatar
here's some figures for you from my experiences...
LRP 3.5T brushless, uses approx 2700-2900mAh indoors on carpet (short track 80m) geared around 12.6 FDR whereas at 10.5 FDR outdoors on asphalt (long track 250m) pulls around 3900-4100mAh.
the IP3800 25C packs I used initially didnt quite have the capacity (if it wasnt fully charged i might be 1 lap short of the 5mins) or the C rating to handle the LRP 3.5T brushless.. the packs heated up quite a lot and swelled slightly on their use, never vented or damaged the cells just swelled a little (90% sure this was the air expanding in the pack, not the cells)...
when i switched to the LRP 5300 28C packs (5.3*28=148.4A) i never had any heat issues with the packs and have always made the 5mins... this has ample overhead for the LRP 3.5T brushless - this would be much the same scenario with the IP5000 30C packs
to be honest, a 5.5T brushless and the IP3800 25C packs would be adequate for most tracks but i would consider this the limit for these packs.. the IP3800 35C packs would have ample overhead for the 5.5T and probably be adequate for a 3.5T brushless also..
but as i've said i like to play it safe with C rating and capacity, especially when running low FDRs on low wind brushless motors
IP5000 30C sounds like to way to go to me
Old 01-19-2009, 04:51 AM   #5
Joel Lagace's Avatar
Just for info.. I run SMC4000 with 13.5BL in rubber sedan on carpet. We are pulling out about 2000mah-2500mah. That same motor in a 10th scale buggy pulled 1800-2200mah on a dusty loose track.
I think a 4000 is a good all round pack but would opt for a 5000 if your car can fit it. I did not want to shim my upper deck so passed on using 5000 for 4000 packs. The extra mah i think would be inportant in keeping the average voltage curve higher especially in mod, i think its probably beneficial in 13.5 as well just not as much
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-19-2009, 04:57 AM   #6
dameetz's Avatar
Yeah, thats what i thought after you post your first reply. I ll go with the 5000mAh.
Old 01-19-2009, 05:00 AM   #7
dameetz's Avatar
When you say you are pulling 2000-2500mah, how actually do you calculate this?
