Old 01-17-2009, 10:29 PM   #1
Default foam tires on asphalt
how long do they last aprox?
im debating rubber vs foam
macscac is offline   Reply With Quote
Old 01-17-2009, 11:20 PM   #2
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
I've wondered this myself, foam nitro tires would kick ass on an electric TC on asphalt!!
Especially parking lots, where the course asphalt eats away at rubber tires and inserts, yet you can watch nitro guys go for 20 minutes on a set of tires.
Plus, if you aren't carefull you can "cook" a set of rubbers in only a run or two, and that's only with a 10.5!!
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 01-17-2009, 11:57 PM   #3
robk's Avatar
Trader Rating: 22 (100%+)
Nitro tires are great on asphalt. 37s are usually a good tire to start with. Around here, where the asphalt is made with limestone, so it's not too abrasive, the tires last quite a while. Carpet foams will be eaten quickly, however.
Old 01-18-2009, 12:10 AM   #4
stiltskin's Avatar
Trader Rating: 102 (100%+)
We used to save our chunked or damaged foam tires from carpet and run them on asphalt during the outdoor season. They worked well but didn't last very long. Never tried to run nitro shoes with electric.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-18-2009, 02:07 AM   #5
fathead's Avatar
We run foams on asphalt in TC here (no traction additive) and we use the so called nitro foams, normally in a 35shore.
For me in Mod I can get close to 2 full meetings out of a set of foams before they get too small to really be useful.
Slavich Design
fathead is offline   Reply With Quote
Old 01-18-2009, 07:03 AM   #6
32819toon's Avatar
Default nitro foams
Hi,
I use nitro foams indoors on carpet and they work great, quite hardwearing aswell. I use 35 shore on the front, and 37 on the rear.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 01-18-2009, 09:01 AM   #7
ta_man's Avatar
Trader Rating: 151 (100%+)
Originally Posted by 32819toon View Post
Hi,
Do you use traction compound on those nitro foams indoors? I've heard it said that using traction compound on Nnitro foams makes them sticky and gum up because of the different kind of rubber that is used. Is this your experience?
ta_man is offline   Reply With Quote
Old 01-18-2009, 09:33 AM   #8
32819toon's Avatar
I use LRP traction compound and the tyres don't get sticky or gum up. They usually take one run to get bedded in, but they're OK after that. I use Kyosho tyres.
32819toon
Old 01-18-2009, 10:57 AM   #9
Yeah I love foams on asphalt. I have never raced with rubber before so I can't compare. I use paragon ground fx and so far the best compound I've used.
I'm also using Kyosho tires but haven't raced them yet but they feel great so far.
Using a tyre lathe or truer will lengthen the life alot. I currently use 1 set over 2 race days although they wear quite unevenly and I don't have a tyre truer myself...
Yelo is offline   Reply With Quote
Old 01-18-2009, 11:47 AM   #10
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
You will not get good performance with carpet tires on asphalt.
Instead of thinking electric and nitro tires think electric/carpet and nitro/asphalt.
Run the touring cars with your nitro shoes without traction compound when running on asphalt.
Don't run your nitro tires on carpet as the foam material is designed for asphalt and will not give good results indoors.
Tire Chunker is offline   Reply With Quote
Old 01-18-2009, 11:06 PM   #11
streetracer745's Avatar
Send a message via AIM to streetracer745
I never personally used them but a guy i race with uses Imex foamys on his losi XXX-s running 3s and VXL. He has gone over a month on one set of tires without truing them... And these are parking lot races so...
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-18-2009, 11:27 PM   #12
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
we have a race next weekend that we are running mod sedan at crystal park (10th and 8th scale onroad track) everyones going to be running 4.5 brushless, I might take some of my old 40 shore tires and check it out. probably only be able to fit fronts, but they are rock hard so they should last a while.. and traction compound is usually not used on nitro shoes for asphalt. they come up to temp and start working in about two laps.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-19-2009, 06:43 PM   #13
Trader Rating: 26 (100%+)
I think foams on asphalt are the only way to go. We run the BSR tires on our pan cars and can get almost an entire season out of them. Also I ran the CRC foams on my TC3 with a 5.5, 2s lipo setup and would get over a month out of them running every wednesday and then practicing every other saturday while the 1/8 late models were running just to prove how slow their nitro cars really were. We did use both jack the gripper and paragon compounds effectively.
racerj3 is offline   Reply With Quote
Old 01-19-2009, 07:47 PM   #14
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Hi,
I am trying to find a set of asphalt donuts for 1/12 scale. Do you know of any that work well on outdoor asphalt?
IIGQ4U is offline   Reply With Quote
Old 03-17-2009, 09:47 AM   #15
My foams lasted 2 full battery charges on asphalt. Then it was literally down to the rim. Rubber from now on.
ThaiM is offline   Reply With Quote
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
New Jaco Rubber Tires yyhayyim Electric On-Road 601 07-07-2009 05:13 PM
Foam Tires on Asphalt Setup? TC5 Jamie007 Electric On-Road 18 01-13-2008 09:43 PM
Reedy Race of Champions EAMotorsports Electric On-Road 901 07-08-2007 10:13 AM
Why cant foams be run on asphalt with electric? bxpitbull Electric On-Road 116 01-03-2007 06:01 AM
rubber touring tires??? JuNK??? burbs Electric On-Road 30 06-15-2006 04:17 PM
Rubber vs Foam Tires - let the battle begin! black-knight Australian Racing 385 09-01-2004 12:59 AM
