Old 01-17-2009, 09:54 PM   #1
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Measuring Droop
Hi all
What is the correct way to measure droop using droop blocks and a droop guage, I have a idea but want to make sure
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 01-18-2009, 03:03 AM   #2
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
my measuring point may vary...
- detach wheels, shocks and stabilizers
- stand car on droop blocks
- using droop gauge, slide it under the outer hinge pin on the lower arm and measure the reading
- make sure are equal both left and right, setting the required figure on the droop gauge
one thing to note.. 2mm of rear droop does not mean 2mm on the droop gauge, in fact it could be a reading of 5 on the droop gauge to give you 2mm of droop...
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-18-2009, 05:15 AM   #3
Skiddins's Avatar
Like this, only the bit that goes underneath the car in your case is the 'block';
And before you ask, I hadn't finished building it!
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-18-2009, 07:59 AM   #4
Joel Lagace's Avatar
What has been posted by mok is the starting point, this is where u make sure your car is symmetrical from left to right. The numbers at this point dont really mean much or matter. In fact the numbers are most times not at all transferable from chassis to chassis.
STEP ONE: (make your car symmetrical)
STEP TWOTrack side or race ready settings)
-Prep car in race ready condition(ready to hit the track)
-A-measure ride height and set to where u want it front and back
-B-now measure ride height and full suspension extension, lift shock tower up and allow the chassis to rise to its highest position without the wheels lifting the ground.
-Subtract B from A and you will get your DROOP setting. This number is what we use at the track when we talk droop. Dont matter what the chassis if i say i run 2mm of droop you can also run 2mm by adjusting your brand XYZ in the same manner.
-EXample A=5mm and B=7mm then DROOP=2mm
It can get confusing with many correct ways of explaining it, but the bottom line is Ride height is subtracted from the chassis at fully extended shock position.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-18-2009, 09:23 AM   #5
Joel explained it as well as any I have read before. However is there anything wrong/inaccurate with using a droop guage like the ones Associated supplied with the TC3/4?
outlandr91 is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 11:42 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 02:42 PM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
tc5 setup question bigemike Electric On-Road 12 05-04-2009 01:45 PM
