Old 01-13-2009, 07:59 PM   #1
Default TRF416 pulls to one side when on throttle. Need help!
My TRF416 pulls to one side during acceleration, but can go straight off throttle.
Anyone can help to advise the things I should check?
yokfans is offline   Reply With Quote
Old 01-13-2009, 08:02 PM   #2
Trader Rating: 68 (100%+)
Send a message via AIM to joey
check the outdrives on the spool or front cvds..
=Joe Wright=
joey is offline   Reply With Quote
Old 01-13-2009, 08:03 PM   #3
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Also check if you have any crack on the rims.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-13-2009, 08:13 PM   #4
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
many things can cause this. Bad bearings, really bad tweak, shot diff,bad or sticking cvd, and so on...
ALBERTO is offline   Reply With Quote
Old 01-13-2009, 09:03 PM   #5
Thanks all.
I think I'll replace all arms, hubs, uprights, and pins first and see if there's any improvement.
Old 01-13-2009, 09:19 PM   #6
Trader Rating: 23 (100%+)
Originally Posted by yokfans View Post
Thanks all.
well look is anything doesn't look right. i found my pins for the cvd's were loose causing it to hit the carrier.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 01-13-2009, 10:38 PM   #7
also chk your shocks and bearings ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 01-13-2009, 10:46 PM   #8
STLNLST's Avatar
Trader Rating: 21 (100%+)
I bet the problem is your rear diff. I just experienced the same thing a couple of weeks ago. Car didn't track straight on power. Tighten the diff and I'm sure the problem will go away.
STLNLST is offline   Reply With Quote
Old 01-14-2009, 04:19 AM   #9
Tpg racer's Avatar
Let me guess, are you running front one-way diff?
If so, check ur one-way bearings... u need to lube the one-way bearings from time to time coz its has a mechanism that opens up and bites the outdrives upon acceleration....
Happens to my Pro4 before....
Tpg racer is offline   Reply With Quote
Old 01-14-2009, 04:40 AM   #10
Graham Kenny's Avatar
Hey Its a very anojing problem to have especially when you cant locate the problem, First thing i would do is to go over my set up and make sure all my shock lenghts, Downstops droop, ride height, Un-Tweek the chassis and everything else is bang on what is should be. If that does not solve the problem next setup would be to check all the bearings and replace or lube up any that didnt feel right. That for me usually solves the problem
Other things i would look for are
-One-way bearings
-Clean and regrease CVD's
-Rebuild the Diff's
-broken parts
Cheers
Team Schumacher UK - GM Racing - TIR - Boultspeed RC Paint
Graham Kenny is offline   Reply With Quote
Old 01-14-2009, 04:45 AM   #11
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
as silly as this may sound... make sure you dont have a wheel nut that keeps coming loose. I had this problem a few weeks ago and it drove me insane!!!
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 01-14-2009, 07:21 AM   #12
mickrcarver's Avatar
Trader Rating: 99 (99%+)
Im going with STLNLST on this one I had the same prob and found my rear diff had loosened up alot, I retightened it and the pull was gone
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
