Old 01-12-2009, 04:45 AM   #1
rcdude8's Avatar
Default What breaks often on your car?
I was just wondering what breaks on your car often so I know which spares to have handy.
I am guessing tyres are the big thing that you have to replace.
Hot Bodies Cyclone S
LRP A.I. Brushless Reverse Digital
Acoms Technisport 2.4 Ghz Radio System
Mazda/Stratus Cross Body
rcdude8 is offline   Reply With Quote
Old 01-12-2009, 05:44 AM   #2
tc3team's Avatar
Would probably be useful to have a few wishbones and rear uprights and steering arms handy if the worst does happen.
Tyres are more of a consumable thing, if you're in the 540 class and just starting up, I wouldnt see the need to have any more than just one spare set to keep you going, if your budget is tight.
Hopefully with the speed of a 540, you wont be breaking too much. Just focus on getting round the track first without crashing. It doesnt matter if your lap times are slow- its better to be slow and not breaking anything, rather than a few fast laps and you have broken the car with no spare parts to hand...
hope that helps
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 01-12-2009, 05:53 AM   #3
rcdude8's Avatar
I know the track pretty well as I raced slow on it with my old car. Now I am going to try going faster and seen as we have a solid concrete wall on the final corner I want to be prepared as I have seen what happens when you hit that wall even at 540 speed.
Old 01-12-2009, 06:11 AM   #4
Rob Burns's Avatar
I see you have a Cyclone S. Our club has a spec class especially for them so I've seen a lot of what breaks on them.
The C-hubs on those are made of eggshells. First thing I would do is to buy the C-hubs for the regular Cyclone as they are quite a bit stronger (buy a few sets). The part number is 73518 and I believe it's an HPI number rather than a Hotbodies number (being from the Pro 4). The steering knuckles are probably the next weakest thing. They come with a rear hub assembly. Part number is 73507 (again an HPI part number). To reduce the chance of breaking those parts get a kydex bumper. A lot of our racers run the BRP bumper for the TC3 and modify it to fit. It cuts down on a lot of the breakages. The only other things I've seen break of those is the chassis (usually when too strong a bumper is installed) and the steering arm set (HB70708) but not too often.
Apart from that not too much else breaks on those cars. Our track is very hard on cars too so we see the extreme side of things. If you have an open track with forgiving boards then you won't break too much.
www.RCOttawa.com
Rob Burns is offline   Reply With Quote
Old 01-12-2009, 06:24 AM   #5
rcdude8's Avatar
Thanks I'll probably take your advice.
Old 01-12-2009, 07:38 AM   #6
Foxxrocket's Avatar
In short... Anything that's sticking out from the chassis, you should have spares for.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 01-12-2009, 08:15 AM   #7
IndyRC_Racer's Avatar
Don't forget about the bearings if you are buying spares. A hit hard enough to break caster blocks, steering knuckles, or suspension parts can also damage the bearings.
IndyRC_Racer is offline   Reply With Quote
Old 01-12-2009, 10:36 AM   #8
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
+1 for that. And you can get some spares for $1 each here http://www.avidrc.com. The revolutions work well with the rubber seal facing out and the grease removed.
ChristopherKee is offline   Reply With Quote
Mini/Micro RC S-T-R-l-K-E-R Manila Racers 7365 06-03-2017 07:16 PM
What breaks often on your car? rcdude8 Australian Racing 16 01-12-2009 11:40 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 08:13 AM
Indoor Dirt Racing @ RC Performance in Madison squirrel Wisconsin & Illinois Racing 4856 05-11-2008 06:25 PM
AMB Personal Transponders...Too Expensive? Fred Perkins Electric On-Road 240 01-05-2006 08:18 PM
My complaint with this RC message boards, RC Magazines and RC Companies. imjonah Chat Lounge 98 08-09-2004 07:06 AM
