Old 01-11-2009, 05:37 PM   #1
mtbboy's Avatar
Default Traction roll cures?
Hey guys.
I am running on what has become a high traction tight carpet track.
I am traction rolling hard in the middle of the high speed sweeper.
Very entertaining to watch at 45 kph I,m sure.
Would putting on a stiffer roll bar and lowering my inner link location help? Or is there another cure I,m just overlooking?
Come on guys, throw me a bone here.
The barrel roll king, Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-11-2009, 05:40 PM   #2
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by mtbboy View Post
Hey guys.
if your traction rolling try giving your car more droop and also try different tires or even try trueing them down to almost nothing that will help also
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 01-11-2009, 05:41 PM   #3
racersnow's Avatar
Trader Rating: 37 (100%+)
Send a message via AIM to racersnow
are you useing traction compound?
Dave's Decals, Cheapest decals on the web!
racersnow is offline   Reply With Quote
Old 01-11-2009, 05:51 PM   #4
mtbboy's Avatar
Sorry Gentlemen, I should have specified.
Jaco prism blue.
Paragon.
Old 01-11-2009, 05:55 PM   #5
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
a bar (or thicker bar), axle spacers/offset (wider track), or less downtravel.
R
UltegraSTI is offline   Reply With Quote
Old 01-11-2009, 06:01 PM   #6
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Stiffer springs/bar, lower the roll center, decrease downtravel, a smaller holed piston (not common but worst case senario), more front ride height, less dual rate, etc.
These are some of many suggestions.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 01-11-2009, 06:10 PM   #7
imprsme's Avatar
Trader Rating: 74 (99%+)
You can also add more camber or even going up in front shock oil 5-10 wt.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 01-11-2009, 06:23 PM   #8
mtbboy's Avatar
Perhaps I,m very misguided here but does lowering the roll center not increase chassis roll thus worsening the roll issue?
D.
Old 01-11-2009, 06:26 PM   #9
D.
Ah yes, roll center...
When i say a low rollcenter i mean a higher hinge pin height relitive to the chassis, thus reducing body roll.
Sorry for any confusion.
Old 01-11-2009, 06:27 PM   #10
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default Too much Traction??
Jaco prism blue.
Paragon.
I like less traction compound first, then stiffer sway bars or camber added, oil thicker last. no ride height adjustments up.
I wish our local track had traction like that, I cannot remember the last time I traction rolled at Fastlane
Jaz406 is offline   Reply With Quote
Old 01-11-2009, 06:57 PM   #11
mtbboy's Avatar
Very good gentlemen!
I shall decrease chassis roll (by whatever means) and use less compound on the outside half of my front tires first.
Rc tech rules!
Who won the novak?
10.5 rubber and 13.5 rubber anyhow?
Dave.
Old 01-12-2009, 07:39 AM   #12
DIALED 1's Avatar
LEAVE YOUR SETUP THE WAY IT IS
GO DOWN IN TYRE SIZES UNTILL U STOP ROLLING (LESS TYRE WALL LESS SIDE GRIP)
IF THE TRACTION IS SUPER HIGH U CAN GO DOWN TO LIKE RUBBER BANDS
SO TO SPEAK, AND U WILL GET HARDLY NO TYRE WEAR (MORE TRACTION LESS WEAR)AND THE CAR WILL FEEL DIALED
THE TYRES ALSO BECOME ALOT HARDER WHEN THEY ARE SMALLER
U WILL NOT ROLL IF U RUN TINY TYRES
DIALED 1 is offline   Reply With Quote
Old 01-12-2009, 07:52 AM   #13
poochy's Avatar
heres 1 way.
1. lower your roll center--the inner hinger pin is closer to the chassis when you lower the roll center, also raising NOT lowering the inner camber link actually lowers the roll center (trust me on this-i have a cad drawing to prove this)-but it does not work as pronounced as lowering the inner hinge pin.
2. tires with less side wall--for example jaco blues has less side grip then rp's.
but the number one thing to do imo is to lower those inner hinge pin first.
poochy is offline   Reply With Quote
Old 01-12-2009, 08:27 AM   #14
DIALED 1's Avatar
TYRES ARE THE MOST IMPORTANT ASPECT IN THE CARS HANDLING
THEY ARE WHATS TOUCHING THE GROUND!
EVEN IF YOU CHANGE THE INNNER PIN TO THE LOWER SETTING U WILL TRACTION ROLL IF YOUR TYRES ARE TOO BIG
TINY TYRES BUD! JUST DO IT
I RAN ON A TRACK WITH INCREDIBLE HIGH TRACTION LIKE IVE NEVER SEEN BEFORE (I WAS ROLLING FOR THE FIRST TIME)
I TRIED CHANGING EVERYTHING ON THE CAR SO IT WONT ROLL
NOTHING WORKED!
EXCEPT RUNNING RUBBER BAND TYRE SIZES!
ALL THE LOCAL GUYS WERE FLYING ROUND THE TRACK AND SOMEONE
ACTUALLY OFFERED TO GIVE ME A SET OF TYRES WHICH LOOKED LIKE JUST RIMS (I DECLINED AND THOUGHT HE WAS JOKING)
ON THE WAY HOME AFTER THE MEET I WORKED IT OUT
THE NEXT TIME I RACED THERE MY CAR WAS DIALED
Old 01-12-2009, 08:33 AM   #15
heretic's Avatar
also I found that putting CA on the edge of the front tires helped A LOT getting rid of the problem without altering the handling of the car. good luck.
heretic is offline   Reply With Quote
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
VTA tuning Q&A liljohn1064 Electric On-Road 500 06-06-2011 01:21 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
