008 EU  Camber Gain >
008 EU Camber Gain
008 EU Camber Gain
Old 01-10-2009, 04:28 PM
Akhor's Avatar
Default 008 EU Camber Gain
Hi,
I've just completed setting all the 008 EU setup as per the carpet racing specs.
However, I've noticed that the left side of my vehicle has more camber gain then the right.
Is there something that should be adjusted so that this does not happen?
Currently the left is about 3 degrees where the right is 1 degree.
Again.. Everything is as the EU rubber tire setup.
Akhor is offline
Old 01-10-2009, 05:38 PM
todd8603's Avatar
Default tweak?
Is it possible you are checking wihtout the battery in the car?
These are VERY addected by weight missing from battery side.
Just an idea....
todd8603 is offline
Old 01-10-2009, 08:35 PM
Akhor's Avatar
Just an idea....
Yes I was checking without.. I'll have to put it in and check.
THanks!
Akhor is offline
Old 01-11-2009, 08:18 AM
Akhor's Avatar
K.
I tried this again with the battery in. Same issue. Although it's greatly reduced...
Any other suggestions?
I think I will rebuild my shocks.. Maybe that is affecting this??
Akhor is offline
