Old 01-10-2009, 05:40 AM   #1
rcdude8's Avatar
Default Gear Ratio 540
What is a good gear ratio for 540?
Also I was told that a good rollout is 40-50mm. Is that true?
Also can someone explain to me what people are talking about when they say front spool and one way that and stuff.
Hot Bodies Cyclone S
LRP A.I. Brushless Reverse Digital
Acoms Technisport 2.4 Ghz Radio System
Mazda/Stratus Cross Body
rcdude8 is offline   Reply With Quote
Old 01-10-2009, 06:15 AM   #2
little man's Avatar
40 mm rollout is a good place to start,a spool is a locked front diff meaning that both wheels always turn at the same speed this can make the car corner very agressively,a front one way is a diff that only transmits power on acceleration but will coast or free wheel during braking leaving only the back wheel to do the braking,if you brake agresively the car to hook around but has great on power steering characteristics giving 100% grip during cornering and allowing the wheels to turn a differant ark at differant speeds.the out side wheel always turn further than the inside wheel
hope this helps
tamiya ta05,kyosho tf5,kyosho v1s,ansmann terrier,tamiya lunchbox,hpi cyber 10 b
I JUST WANT TO HAVE FUN ,NOW DAMM IT
little man is offline   Reply With Quote
Old 01-10-2009, 06:19 AM   #3
rcdude8's Avatar
Thanks. I think I understand now.
Old 01-10-2009, 11:40 AM   #4
What capacity batteries are you using? How long are the races? Over here in NZ we run 1500 mah max and a good ratio would be about 4.1-3.9. But it all depends on your batteries because otherwise you will cook your motor because of the extra runtime.
Matt Smith is offline   Reply With Quote
CRAWLER'S CORNER Mang Boy Manila Racers 3390 10-26-2017 09:57 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
NEWS @ RC SMART MARKETING rcsmart Malaysian R/C Racers 88 08-21-2014 09:04 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
2007 Western TAMIYA CANADIAN CHAMPIONSHIP SERIES chrisman Canadian R/C Scene 199 06-05-2007 01:58 PM
Johnson 540 Gear Ratio Needed DTM.inc Australian Racing 15 02-22-2007 04:38 PM
540 gear ratio Tamiya No1 Australian Racing 7 06-17-2005 09:33 AM
