Old 01-08-2009, 12:26 AM   #1
Guest
Send a message via Yahoo to T4-RC8 RACER77
Questions?? novak brushless motor timming
i need help? how do i adjust the timming on a 13.5 10.5 motor????
T4-RC8 RACER77 is offline   Reply With Quote
Old 01-08-2009, 08:47 AM   #2
The Evicerator
Loosen the three 1/16" flat head screws on the back endcap of the motor.
Look to the back edge of the motor to the orange or blue colored ring... you should note some slots on that ring.
Take a small flat head screw driver and rotate that ring clockwise to reduce timing, and counter-clockwise to advance the timing.
Please note that the ring can only be adjusted so far and then it will stop...pushing harder will not advance the timing more... it will just break the timing ring!
You know when you've advanced as far as you go when the slot nearest to the motor solder tabs tucks up right next to the tab.
Hope this helps!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Team Orion Vortex Brushless motor Aku-Man Electric On-Road 719 05-27-2011 03:46 PM
