How do you plug this ps into a wall socket?
#76
Originally posted by AE Racer
So If I buy the cord with the rings at the ends of the wires screw them on in the right spots and put some type of silicon oo top to keep anything from shorting it, I should be ok? Is there anyway I could easily make it so I can use the clips of a charger on it?
Connecting to a charger that has clips is problematic at best. For my 75A supply, the one all the pictures are of on the previous page, I have a long skinny project box that has a bunch of binding posts on it, and people can clip to the posts (with the nuts down if the clips are small and with the nuts up/off if they're large). Folks with banana plugs can jack in, and folks with bare wire can play too. I'll see if I can get a picture to illustrate better for you. I use spades on my stuff so I can lock it down on the posts, but there are lots of ways to connect to them.
-dave
#77
Two questions:
1) After one has hacked an extension cord and hooked it up correctly, is there any reason one couldn't pour some epoxy over the three AC terminals and seal them up from unsuspecting hands electricuting them selves by accidently touching them?
2) Is it possible to hook two up in parallel to get 26 amps; and if so what would be the "safe method"
#78
Originally posted by Geek
Two questions:
Two questions:
The safe way is to buy a higher capacity supply, or to distribute the load between them. Paralleling supplies not designed for it will be...bad. The ones listed in this thread are definately not designed for it.
-dave
#79
I got one of the 13 amp power supplies off Ebay. Works good. It says right in the paper work they can be run in parrallel (for 26 amps) or in series (for 24 volts.)
Use some Shoo Goe. It will cover the electrodes, but will peel off if you need it too.
#80
-dave
#81
How long did shipping take for you guys? Is this the same power supply as the others in the thread http://cgi.ebay.com/ws/eBayISAPI.dll...&category=2563 it's from a diffrent guy who has slightly better feedback and since this will be my first ebay purchase Im looking for the best. dpaton where'd how did you attach the lexan to yours? can you post pics? Could somthing like this allow me to use the clips? http://www.rctech.net/forum/attachme...&postid=562372 and what are those things called so I can find them.
edit: Actually the other guy has 10 times as many sales so mabey I should go with him.
#82
Which of these guys do you think I should buy from?
After you buy it and send them the money via paypal, then what? Ive never bought anything on ebay before.
#83
I got mine from the first guy he only charges $9 for shipping the other one want's $10.
#84
The picture is linked in the first page of this thread, but repeated for brevity:
Attaching binding posts to the terminal block is one way to do it, but if you're using clips you need to be careful of them shorting out on the chassis. The posts also let you use bare wire (mildly dangerous, again, shassis shorting) or spade lugs (preferable, more secure, lower resistance than clips) to plug your gear in. Unfortunately, the ones in the picture you linked to are old style Radio Shack posts, and all the stores near me are dropping the parts lines as fast as they can. You'll probably have to special order them.
If you feel like a project, you can build a binding bost box like mine with some dual binding posts and a project box. Just wire up the box to your supply with a 6' cable or so, I used some monster speaker wire because I believe in fat wires.
-dave
#85
Do you guys think Id be better off getting one of these power supplies and a 16x5v6 or a 16x9v6? The only advantage I see in the 16x9v6 is that that has one extra Amp in its power supply, but I like the size and looks of the 16x5 better.
And with those binding posts, does the plastic part screw off revealing a pole that you can put the clips on?
#86
#87
Originally posted by vtl1180ny
Kinda like this???
http://www.rctech.net/forum/attachme...&postid=583845
Kinda like this???
-dave
#88
-dave
#89
Wow dont leave those things plugged in unatended. Fire hazard.
If you look at a outlet the rounded opening is the ground. This is very important (It could save your life) It needs to be connected to the chassis of the power supply. The neutral needs to be connceted to the left slot on the outlet. And finally the hot or black wire needs to be connected to the right slot on the outlet. When it comes to power supplys YOU GET WHAT YOU PAY FOR. The chassis of that pos must be grounded.
#90
