Old 03-30-2002, 10:14 AM   #121
Dragon's Avatar
Send a message via ICQ to Dragon
Woo...interesting....
Dragon is offline   Reply With Quote
Old 04-01-2002, 09:31 AM   #122
Aluma's Avatar
everyone, where do i buy a set of new front HUBS?
I crashed and the bottom step screw got ripped out...i did superglue fix but want to replace as soon as possible....is there an aluminum replacement? where can i buy it?
i found the carriers, but not the hubs.
Aluma is offline   Reply With Quote
Old 04-02-2002, 08:30 AM   #123
Dragon's Avatar
From what people told me, these Tao4 parts from integy can fit on the evos....however, in not sure if the steering bell cranks may be used on an Evo 2 or not, because the lower part of the bell crank tower differs between the 2 cars, where the evo 1 uses 4 screws while the evo 2 uses only 2 screws.
6pcs Ball Bearing Bell Crank for TG10 & TB01 (NEW)
1448
$39.99
Front Castor Block for TA04 (NEW)
1474
$19.95
Front Steering Block for TA04 (NEW)
1473
$19.95
Rear Hub Carrier for TA04 (NEW)
1476
$19.95
Old 04-03-2002, 01:16 PM   #124
Aluma's Avatar
that sounds good , BUT, are you sure? I'd hate to buy a set of $20 hubs and then have them not fit... :P
then what would i do withem? I'd hate send them back and lose more money on shipping.
has anyone tried this? I wanna see pics!
Old 04-03-2002, 01:53 PM   #125
superk's Avatar
I just pick up my EVO II the other day !! the car looks really nice!! Don't know..if I should skip my TC3 to this car! LOL I use Keyence V and S9304 servos! can't wait to hit the track!
Any one with any setup idea indoor carpet and outdoor?? gearing setup?? stock and mod??
superk is offline   Reply With Quote
Old 04-10-2002, 07:49 PM   #126
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I have a TB01 and would like to get some more steering. If I go to lighter front springs would this help some. I know my TA03 gets more traction the stiffer I make it. When I go to softer springs is loosens the car up and harder springs will make it stick more. That worked like that on both ends of the car. Can I expect the TB01 to be the same.
I have 60wt front and rear with Tamiya Type A's front and rear. I run the stiffer series Tamiya springs. I have the red springs in the front and the dark blue in the rear.
Old 04-11-2002, 07:34 AM   #127
Aluma's Avatar
you can always toe out the front a bit for more steering
and add a rear sway bar always gives you a bit more steering too
or you can also go with white Hard springs at the back.
Old 04-12-2002, 07:56 AM   #128
Aluma's Avatar
okay, I got the TA04 front hubs and NO they do not fit right.
they sort of work, but its off in several places.... toe link, length of hub itself is shorter and needs a different size bearing inside the hub....
Anyone wanna buy a set of aluminum front hubs for a TA04?
Old 04-14-2002, 04:01 AM   #129
Dragon's Avatar
the different size berring is ok, can be easily replaced, but the toe in, i think u just have to change the length steering arms right?
they told me that the angle of this o4 hub is better.....
Old 04-14-2002, 12:46 PM   #130
Aluma's Avatar
i know bout that stuff, but what you dont understand is that, the length of the hub(horizonatl width) its much smaller and leaves a big gap between the aluminum hex hub and the ta04 hub... the wheel might rub the arm if its turned too much as well.
Old 04-18-2002, 04:19 AM   #131
JohnA's Avatar
What sort of battery connectors is everyone running in there evo's? I've allways used corally's but the cells dont fit.
JohnA is offline   Reply With Quote
Old 04-18-2002, 08:23 PM   #132
Aluma's Avatar
Thumbs up
I use deans plugs
Old 04-18-2002, 08:28 PM   #133
TRF-Powered's Avatar
what I do is I bent a battery bar into right angle and then solder it onto the cells, and then just use wires do direct soldering. doing this makes all kinds of cell fit in to the slot.
Also, if you wan to use connector, still, bent a battery bar and solder it to the cell positve and negtive ends and then solder the connector of choice on it. Then you can fit any kinds of connectors.
TRF-Powered is offline   Reply With Quote
Old 04-19-2002, 09:17 PM   #134
when you guys run the TB evoII, did you notice that the rear gear box makes a sound that sounds like the gear is kinda jumping around in the gear box?
Old 04-20-2002, 07:02 AM   #135
wyd
Tech Legend
wyd's Avatar
Could be your outdrives as they do have alot of slop. My friends has more slop than my standard TB01 with the plastic tub. It still runs fine but I would check to make sure you didn't strip the outdrive cup at all.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
